Rev D with teensy 4.1
First run the microphone test from the audio tutorial using headphones to listen. No point diving into the software if the problem is with hardware, so check that your mic really is working first.
If the mic is good and the problem is with the software, we can't help much unless you show us the code.
That microphone is not packaged with any amplifier. The video on the thinkrobotics website shows a simple transistor circuit. @rahulkumar what did you use for an amplifier?
