remko@thesetcompany.nl
Is there a temporary workaround to detect clipping?
"Because the clipped waveform has more area underneath it than the smaller unclipped waveform, the amplifier produces more power than its rated (sine wave) output when it is clipping. This extra power can damage the loudspeaker. It may cause damage to the amplifier's power supply or simply blow a fuse."I dont understand why a "clipped" Signal should damage speakers just by being "clipped", whatever clipped means.
I think that's supposed to be from the greater high-frequency content -- which entails greater power levels. It's only going to be a factor at levels already near the physical limits of the speaker to dissipate heat.If a clipped audio signal is send to the amplifier this will damage the speakers.
Use the Peak object... it's not averaging but returning the highest level in the processing block of samples.We now use the RMS module of the library to detect a high audio signal.
how can one detect signals that will overload speakers (no matter how they were created)?
