It seems that the Encoder library linked from PJRC won't compile. Here are the errors using the example from the library:
Any ideas?
...\libraries\Encoder/Encoder.h:59: error: ISO C++ forbids declaration of 'IO_REG_TYPE' with no type
...\libraries\Encoder/Encoder.h:59: error: expected ';' before '*' token
...\libraries\Encoder/Encoder.h:60: error: ISO C++ forbids declaration of 'IO_REG_TYPE' with no type
...\libraries\Encoder/Encoder.h:60: error: expected ';' before '*' token
...\libraries\Encoder/Encoder.h:61: error: 'IO_REG_TYPE' does not name a type
...\libraries\Encoder/Encoder.h:62: error: 'IO_REG_TYPE' does not name a type
...\libraries\Encoder/Encoder.h: In constructor 'Encoder::Encoder(uint8_t, uint8_t)':
...\libraries\Encoder/Encoder.h:80: error: 'struct Encoder_internal_state_t' has no member named 'pin1_register'
...\libraries\Encoder/Encoder.h:80: error: 'PIN_TO_BASEREG' was not declared in this scope
...\libraries\Encoder/Encoder.h:81: error: 'struct Encoder_internal_state_t' has no member named 'pin1_bitmask'
...\libraries\Encoder/Encoder.h:81: error: 'PIN_TO_BITMASK' was not declared in this scope
...\libraries\Encoder/Encoder.h:82: error: 'struct Encoder_internal_state_t' has no member named 'pin2_register'
...\libraries\Encoder/Encoder.h:83: error: 'struct Encoder_internal_state_t' has no member named 'pin2_bitmask'
...\libraries\Encoder/Encoder.h:90: error: 'struct Encoder_internal_state_t' has no member named 'pin1_register'
...\libraries\Encoder/Encoder.h:90: error: 'struct Encoder_internal_state_t' has no member named 'pin1_bitmask'
...\libraries\Encoder/Encoder.h:90: error: 'DIRECT_PIN_READ' was not declared in this scope
...\libraries\Encoder/Encoder.h:91: error: 'struct Encoder_internal_state_t' has no member named 'pin2_register'
...\libraries\Encoder/Encoder.h:91: error: 'struct Encoder_internal_state_t' has no member named 'pin2_bitmask'
...\libraries\Encoder/Encoder.h:91: error: 'DIRECT_PIN_READ' was not declared in this scope
...\libraries\Encoder/Encoder.h: In static member function 'static void Encoder::update(Encoder_internal_state_t*)':
...\libraries\Encoder/Encoder.h:373: error: 'struct Encoder_internal_state_t' has no member named 'pin1_register'
...\libraries\Encoder/Encoder.h:373: error: 'struct Encoder_internal_state_t' has no member named 'pin1_bitmask'
...\libraries\Encoder/Encoder.h:373: error: 'DIRECT_PIN_READ' was not declared in this scope
...\libraries\Encoder/Encoder.h:374: error: 'struct Encoder_internal_state_t' has no member named 'pin2_register'
...\libraries\Encoder/Encoder.h:374: error: 'struct Encoder_internal_state_t' has no member named 'pin2_bitmask'
Any ideas?
