So the human powered submarine project is in its early stages, we have almost a year to play. Right now we're setting up to play with propeller designs. Available power is about 1/2 horsepower (max, in their dreams). Shaft speed tbd. We're trying to build a test cell to test various propellers for thrust at various speeds. We have the mechanics of it figured out. A battery drill delivers about the right power, is variable speed. Harbor Freight 4.5" RAgrinders ($12!) for right angle ~3:1 gearboxes, etc.
Once we get this in the water it's going to be obvious (these are ~middleschoolers w/o a lot of experience yet) that we need to measure shaft speed and torque, i.e. have a dynamometer. I haven't looked into measuring shaft speed yet but imagine a bike computer setup will work fine. I don't mind them doing the math (power = torque x speed) by hand until we have a lot of experience to imprint it a bit better in their minds. At that point we can probably use the same magnet/sensors, maybe w/o even any signal conditioning to feed the Teensy.
But torque has me wrapped around the axle :- ) . One idea is to measure the static torque on the drill as it's driving the whole mess. A simple load cell in that case, but the controlling hand might accidentally apply some torque as it squeezes the trigger. I'd actually love to have an actual rotating torque measurement. A purely/largely mechanical solution would also be fine. High accuracy is not needed, good repeatability is a good thing, tho. Shaft speed is limited to that of the drill (less than 600 rpm, 10 cps). I could have a whole rotating Teensy torque sensor with wireless talking to another wireless Teensy. That seems awkward. Any ideas? Thanks in advance, btw.
