RPM from rotary encoder also used for stepper control
MorryStu
I am wanting to get an RPM value from a quadrature encoder that is used to control a stepper motor driving a lead screw on my lathe
Full project
Unfortunately I am tight for spare pins on the Teensy4 so I would like to be able to derive the RPM and the encoder position from a single pin if possible
Section
C++:
    long RPM;
    long newPosition = SpindleEnc.read();
    if (newPosition != oldPosition) {
      oldPosition = newPosition;
      //Serial.println(newPosition);
RPM = (newPosition/?); // some code that involves millis.  STRICTLY NO  Delay(); EVER...anywhere
display1.clear();
display1.showNumberDec(RPM, false, 2, 1);
  readButton();  // read button and update mode
  switch (mode) {
    case MM:
      mm();
    case TPI:
Full code
C++:
MM Pin0 = MMButt
   Pin1 = MMLed
TPI Pin2 = TPIButt
    Pin3 = TPILed
Feed Pin4 = FeedButt
     Pin5 = FeedLED
STOP Pin6 = STOPButt
     Pin7 = STOPLed
FWD Pin8 = FWDButt
    Pin9 = FWDLED
REV Pin10 = REVButt
    Pin11 = REVLED
DISP1 Pin16 = DISP1Clk
      Pin17 = DISP1Dat
DISP2 Pin18 = DISP2Clk
      Pin19 = DISP2Dat
ENC Pin20 = ENCClk
    PIN21 = ENCDat
SPINDLE Pin22 = SPINDLE_A
        Pin23 = SPINDLE_b
#include <RotaryEncoder.h>  //Rotary_Encoder_KY-040_Fixed-main/RotaryEncoder.h https://github.com/ownprox/Rotary_Encoder_KY-040_Fixed.....NOTE. this installs as RotaryEncoder.h, so make sure to remove any existing library
#include <Bounce2.h>
#include <TM1637Display.h>
//#include <QuadEncoder.h>
#include <Encoder.h>
#define MMButt_PIN 0  // WE WILL attach() THE BUTTON TO THE FOLLOWING PIN IN setup()
#define MMLed_PIN 1   // DEFINE THE PIN FOR THE LED :
#define TPIButt_PIN 2
#define TPILed_PIN 3
#define FEEDButt_PIN 4
#define FEEDLed_PIN 5
#define STOPButt_PIN 6
#define STOPLed_PIN 7
#define FWDButt_PIN 8
#define FWDLed_PIN 9
#define REVButt_PIN 10
#define REVLed_PIN 11
#define CLK1 16  //Display 1 Clk
#define DIO1 17  // Display 1 data
#define CLK2 18  // Display 2 Clk
#define DIO2 19  // Display 2 data
TM1637Display display1(CLK1, DIO1);
TM1637Display display2(CLK2, DIO2);
Encoder SpindleEnc(22, 23);
Bounce MMdebouncer = Bounce();
Bounce TPIdebouncer = Bounce();
Bounce FEEDdebouncer = Bounce();
Bounce STOPdebouncer = Bounce();
Bounce FWDdebouncer = Bounce();
Bounce REVdebouncer = Bounce();
int ledState = LOW;  // SET A VARIABLE TO STORE THE LED STATE
int Counter = 100, LastCount = 0;
float Countermm = Counter;
float Countertpi = 0;
float Counterfeed = 0;
long oldPosition = -999;  // for spindle
float Pitchmm;            // used for metric leadscrew calculation and stepper config
float Pitchtpi;
enum MODE  // available modes
  MM,
  TPI,
  FEED,
MODE mode = MM;
void RotaryChanged();
RotaryEncoder Rotary(&RotaryChanged, 20, 21, 28);  // Pins 20 (DT), 21 (CLK), 28 (SW) - 28 is just a null number as the (SW) is not used
void RotaryChanged() {
  const unsigned int state = Rotary.GetState();
  if (state & DIR_CW)
    Counter++;
  if (state & DIR_CCW)
    Counter--;
  Serial.println("T.I.S.M");  // Death to ART tour, featuring Great Trucking Songs of The Renaissance
  display1.setBrightness(0x0f);
  display2.setBrightness(0x0f);
  display1.clear();
  display2.clear();
  display1.showNumberDecEx(8888, 0b01000000, false, 4, 4);  //Displays 10.11
  display2.showNumberDec(1234, false, 4, 0);                // shows 10 on far left
  MMdebouncer.attach(MMButt_PIN, INPUT_PULLUP);  // Attach the debouncer to a pin with INPUT_PULLUP mode
  MMdebouncer.interval(25);                      // Use a debounce interval of 25 milliseconds
  pinMode(MMLed_PIN, OUTPUT);                    // Setup the LED
  digitalWrite(MMLed_PIN, ledState);
  TPIdebouncer.attach(TPIButt_PIN, INPUT_PULLUP);
  TPIdebouncer.interval(25);
  pinMode(TPILed_PIN, OUTPUT);
  digitalWrite(TPILed_PIN, ledState);
  FEEDdebouncer.attach(FEEDButt_PIN, INPUT_PULLUP);
  FEEDdebouncer.interval(25);
  pinMode(FEEDLed_PIN, OUTPUT);
  digitalWrite(FEEDLed_PIN, ledState);
  STOPdebouncer.attach(STOPButt_PIN, INPUT_PULLUP);
  STOPdebouncer.interval(25);
  pinMode(STOPLed_PIN, OUTPUT);
  digitalWrite(STOPLed_PIN, ledState);
  FWDdebouncer.attach(FWDButt_PIN, INPUT_PULLUP);
  FWDdebouncer.interval(25);
  pinMode(FWDLed_PIN, OUTPUT);
  digitalWrite(FWDLed_PIN, ledState);
  REVdebouncer.attach(REVButt_PIN, INPUT_PULLUP);
  REVdebouncer.interval(25);
  pinMode(REVLed_PIN, OUTPUT);
  digitalWrite(REVLed_PIN, ledState);
    long RPM;
display1.clear();
  switch (mode) {
    case MM:
      mm();
    case TPI:
      tpi();
    case FEED:
      feed();
void readButton() {
  MMdebouncer.update();      // Update the Bounce instance
  if (MMdebouncer.fell()) {  // Call code if button transitions from HIGH to LOW
    ledState = !ledState;    // Toggle LED state
    switch (mode)
    case MM:
    default:
  } else
    TPIdebouncer.update();
  if (TPIdebouncer.fell()) {
    switch (mode)
    case TPI:
    default:
  } else
    FEEDdebouncer.update();
  if (FEEDdebouncer.fell()) {
    switch (mode)
    case FEED:
    default:
void mm() {
  Serial.println("void mm");
  if (LastCount != Counter) {
    //Serial.println(Counter);
    Pitchmm = Counter / 100.00;  //Metric threads have dec point values. i.e 1.25mm
    display2.clear();
    display2.showNumberDecEx(Counter, 0b10000000, true, 3, 1);  // Use Counter value for deciml point placement on LED disp
    Serial.println(Pitchmm);
void tpi() {
  Serial.println("void tpi");
    Pitchtpi = Counter;  // value in TPI
    display2.clear();
    display2.showNumberDec(Pitchtpi, false, 2, 1);
void feed() {
  Serial.println("feed tpi");
    display2.clear();
If you only have one pin, you can count edges, but you can't determine direction, so your "position" will not be meaningful. In this application, it's hard to imagine any two pins being more important than these two. Perhaps you can find a way to eliminate another pin? In general, if you have two pins and you're able to keep an accurate quadrature count, you can get speed by periodically reading position computing:
speed = (change in position) / (delta time)
and converting to RPM. Since you're using T4.1, definitely use QuadEncoder, which does all of the quadrature counting in QuadTimer (hardware), so almost no CPU time. Encoder uses interrupts on digital inputs, so the CPU load can be significant if you have a high-res encoder and high speed.
I did find Quadencoder, but it was after I had the PCB made, so it is going to make it very hard to use. grrrr
Direction is not a factor for the RPM, but essential for the leadscrew sync
I am not using the SPI bus at this stage so I might be able to steal one of those pins. I do have an SPI encoder, but it is not that great and have gone with an true optical encoder with a/b pins
If you can't use QuadEncoder, you should just go ahead and use Encoder. The T4.1 is so fast that it can handle quite high interrupts rates. What is the PPR of your encoder and the highest expected RPM?
Let's say your have a 1024-PPR encoder and max 1200 RPM. The total interrupt rate would be
4 * 1024 * 1200/60 = 81920 interrupts/sec
1000PPR and max RPM would be 2,000RPM at most
Quad Enc 1000PPR was selected as it ties in with leadscrew closed- loop stepper encoder
Problem solved.
I used FreqMeasure on pin 22 and QuadEnc on pins 31 & 33 and just shared pin 22 and 31 from the Quad encoder.
works flawless up to 2000rpm and now I get enc posn and RPM and as they use the hardware encoders it lets the program do to what it needs to do
