do you mean CPU clock at 150MHz?FAILS write at 150 MHz.
Use a freshly formatted SD for best performance.
Sketch is :T:\TEMP\arduino_modified_sketch_197682\bench.ino
[COLOR="#FF0000"][B]F_CPU=151200000[/B][/COLOR]
Type any character to start
FreeStack: 441608
Type is FAT32
Card size: 31.91 GB (GB = 1E9 bytes)
Manufacturer ID: 0X3
OEM ID: SD
Product: SU32G
Version: 8.0
Serial number: 0XAC3E2E1C
Manufacturing date: 9/2012
[B][COLOR="#FF0000"]error: open failed
SdError: 0X23,0X1[/COLOR][/B]
Sketch is :T:\TEMP\arduino_modified_sketch_69952\bench.ino
F_CPU=24000000
FreeStack: 441608
begin() failed
Do not reformat the SD.
SdError: 0X17,0X1
I ask as I run T4 +AudioCard-uSD (spi) + sdfat-beta at 24 MHz CPU clock without problems (I think)Yes. Set in the IDE - edited to show F_CPU_ACTUAL in setup {also print __FILE__ so I know what the sketch will do when I type 'Any' char}:
Here is what I have you can probably modify it to suit your needs.Will you have an example?
#include <SdFat.h> // SdFat V "2.0.0"
SdFat SD;
File m_pSource;
const int DIR_max = 250; // [# of Directory - max]
const int max_DIR_name_lenght = 255;
char CURDIRname[max_DIR_name_lenght] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }; // Elements with missing values will be initialized to 0;
uint32_t DIRcount = 1; // COUNT of all DIRs on SD CARD
char DIR_list_array[DIR_max][max_DIR_name_lenght]; // [# of DIRs max][max DIR name lenght];
//------------ setup() -------------
while (!Serial && millis() < 15000) {} // wait for Serial Monitor with 15sec. timeout.
#if defined(SdFat_h)
Serial.print( "SdFat version "), Serial.println( SD_FAT_VERSION ), Serial.println("");
#elif defined(__SD_H__)
Serial.println( "SD - a slightly more friendly wrapper for sdfatlib"), Serial.println("");
if (!SD.begin(SdioConfig(FIFO_SDIO))) { // SdFat.h Ver 2.0.0 Beta only...
Serial.println("m.SD initialization failed!");
Serial.println("m.SD initialization OK");
LISTDIRs();
m_pSource = SD.open("/"); // ROOT
PrintFiles(m_pSource);
m_pSource.close();
//------------ loop() -------------
//------------ LIST ALL DIRs ON SD CARD & SAVE IN DIR_list_array -------------
void LISTDIRs() {
Serial.println("\t**List Directories**");
char dirname[max_DIR_name_lenght]; // SDFAT // max_DIR_name_lenght
if (m_pSource.isDirectory()) {
strcpy(DIR_list_array[DIRcount], "/"); // array
Serial.print("ROOT# ");
Serial.print(DIRcount);
Serial.print("\t");
Serial.println(DIR_list_array[DIRcount]); // SDFAT LIB
DIRcount++;
while (true) {
File DIR = m_pSource.openNextFile();
if (! DIR) {
// no more files
Serial.println("\t **no more Directories** ");
//dir.close();
DIR.getName(dirname, sizeof(dirname));
if (DIR.isDirectory()) {
//DIRcount++;
strcpy(DIR_list_array[DIRcount], dirname); // array
strcat(DIR_list_array[DIRcount], "/");
Serial.print("DIR# ");
Serial.print("\t");
DIRcount++;
DIR.close();
DIRcount --;
Serial.print("\t **Directory count ");
Serial.print(DIRcount), Serial.println(" **"), Serial.println();
m_pSource.close();
// Print Files in Cur. Directory
void PrintFiles(File dir) {
Serial.println("\t**List Files in Cur. Directory**");
char filename[max_DIR_name_lenght]; // SDFAT
while (true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
Serial.println("\t **no more files**"), Serial.println();
entry.getName(filename, sizeof(filename));
if (entry.isDirectory()) {
//Serial.println(" / ");
//printDirectory(entry, numTabs + 1);
Serial.print(filename); // SDFAT LIB
// files have sizes, directories do not
Serial.print(" \t");
Serial.println(entry.size(), DEC);
entry.close();
Thanks so much to Bill Greiman for this library - SDIO on T3 amazing - before I found it 20Mb/sec read from SD was the stuff of mad man's dreams!
Do anyone know for sure if this uses SPI when it in SDIO mode or it all handled with bit banging across the four data lines?
I need to use the SPI bus for shift register filling and need to change speed and data direction (to LSB first).
I know changing settings may conflict if SPI already in use.
Thanks
Dave
FILE_SIZE_MB = 5
BUF_SIZE = 512 bytes
Starting write test, please wait.
write speed and latency
speed,max,min,avg
KB/Sec,usec,usec,usec
10309.28,9846,22,49
10266.94,9300,22,49
Starting read test, please wait.
read speed and latency
speed,max,min,avg
22522.52,480,22,22
22522.52,480,22,22
Type '1' for FIFO SDIO
'2' for DMA SDIO
'3' for Dedicated SPI
'4' for Shared SPI
Error: begin failed
SD_CARD_ERROR_CMD0, ErrorData: 0XFF
The adapter is capable of both protocols and SdFat uses SPI library, so you have to configure SPI library first before initiating SdFat.I presume the error is because SdFat isn't configured to use SPI over the SDIO pins AND the SD module (Pololu) isn't built to read SPI data.
#define USE_SdFat_ // uncomment for SdFat.h, comment for SD.h lib.
#include "SdFat.h"
SdFat sd;
AudioPlayMemory sound0; //xy=257,200
AudioPlaySdWav playSdWav2; //xy=296,375
AudioPlaySdWav playSdWav3; //xy=313,439
AudioPlaySdWav playSdWav1; //xy=324,292
AudioPlaySdWav playSdWav4; //xy=345,516
AudioMixer4 mixer1; //xy=802,203
AudioMixer4 mixer2; //xy=851,322
AudioOutputI2S i2s1; //xy=1069,248
AudioConnection patchCord1(sound0, 0, mixer1, 1);
AudioConnection patchCord2(sound0, 0, mixer2, 2);
AudioConnection patchCord3(playSdWav1, 0, mixer1, 0);
AudioConnection patchCord4(playSdWav1, 1, mixer2, 1);
AudioConnection patchCord5(mixer1, 0, i2s1, 0);
AudioConnection patchCord6(mixer2, 0, i2s1, 1);
// Use these with the Teensy Audio Shield
//#define SDCARD_CS_PIN 10
//#define SDCARD_MOSI_PIN 7
//#define SDCARD_SCK_PIN 14
// SDCARD_SS_PIN is defined for the built-in SD on some boards.
#ifndef SDCARD_SS_PIN
const uint8_t SD_CS_PIN = SS;
#else // SDCARD_SS_PIN
// Assume built-in SD is used.
const uint8_t SD_CS_PIN = SDCARD_SS_PIN;
#endif // SDCARD_SS_PIN
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN 4
//#define SDCARD_MOSI_PIN 11
//#define SDCARD_SCK_PIN 13
int inByte = 0;
byte newDATAin = 1;
#include "AudioSampleCashregister.h" // http://www.freesound.org/people/kiddpark/sounds/201159/
// Audio connections require memory to work. For more
AudioMemory(100);
//SPI.setMOSI(SDCARD_MOSI_PIN);
///SPI.setSCK(SDCARD_SCK_PIN);
if (!sd.begin(SdioConfig(FIFO_SDIO))) {
// stop here, but print a message repetitively
while (1) {
switch (Serial.read()) {
case 's': {
Serial.println("s");
// envelope1.noteOff();
// envelope2.noteOff();tttttttttttt
playSdWav1.stop();
playSdWav2.stop();
playSdWav3.stop();
playSdWav4.stop();
//playSdWav5.stop();
//playSdWav6.stop();
//playSdWav7.stop();
//playSdWav8.stop();
sound0.play(AudioSampleCashregister);
case 't': {
sound0.stop();
playSdWav1.play("10BAB1.WAV");
playSdWav2.play("10BAB2.WAV");
playSdWav3.play("10BAB3.WAV");
playSdWav4.play("10BAB4.WAV");
case 'y': {
sound0.stop();
playSdWav1.play("10BAB2.WAV");
delay(5);
//playSdWav2.play("10BAB2.WAV");
//playSdWav3.play("10BAB3.WAV");
//playSdWav4.play("10BAB4.WAV");
