Searching for FTP Server example on Teensy 4.1 with QNEthernet
Hello All,
I am trying to use the latest TFTP library with USE_QN_ETHERNET = true and testing via winscp.
What I have found is, if I configure winscp to be "Active Mode", then it works.
But for default (Passive mode) it doesn't work.
Teensy Log
[FTP] Client connected!
USER teensy4x
[FTP] processCommand
[FTP] Got USER
[FTP] Stage: cmdStage < FTP_Cmd => unrecognized command
PASS ftp_test
[FTP] Got PASS
[FTP] Authentication Ok. Waiting for commands.
[FTP] Stage: Connection OK, FTP_TIME_OUT = 5 minutes
SYST
[FTP] Got Unknown Command
FEAT
[FTP] Got FEAT
PWD
[FTP] Got PWD or CWD .
CWD /
[FTP] Got CWD
PWD
TYPE A
[FTP] Got TYPE
PASV
[FTP] Got PASV
[FTP] Connection management set to passive
[FTP] Listening at 195.0.0.16 : 2000
227 Entering Passive Mode (195,0,0,16,7,208)
[FTP] Stage: FTP_Init
[FTP] Ftp server waiting for connection on port 21
And Winscp log is below
. 2024-06-05 16:50:55.794 --------------------------------------------------------------------------
. 2024-06-05 16:50:55.795 WinSCP Version 6.3.3 (Build 14916 2024-04-16) (OS 10.0.22631 – Windows 10 Enterprise)
. 2024-06-05 16:50:55.795 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2024-06-05 16:50:55.797 Log level: Normal
. 2024-06-05 16:50:55.797 Local account: RL\Hemant Kapoor
. 2024-06-05 16:50:55.797 Working directory: C:\Program Files (x86)\WinSCP
. 2024-06-05 16:50:55.797 Process ID: 35000
. 2024-06-05 16:50:55.811 Ancestor processes: explorer, ...
. 2024-06-05 16:50:55.811 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2024-06-05 16:50:55.811 Time zone: Current: GMT+1, Standard: GMT+0 (GMT Standard Time), DST: GMT+1 (GMT Summer Time), DST Start: 31/03/2024, DST End: 27/10/2024
. 2024-06-05 16:50:55.811 Login time: 05 June 2024 16:50:55
. 2024-06-05 16:50:55.811 --------------------------------------------------------------------------
. 2024-06-05 16:50:55.811 Session name: teensy4x@195.0.0.16 (Site)
. 2024-06-05 16:50:55.811 Host name: 195.0.0.16 (Port: 21)
. 2024-06-05 16:50:55.811 User name: teensy4x (Password: Yes, Key file: No, Passphrase: No)
. 2024-06-05 16:50:55.811 Transfer Protocol: FTP
. 2024-06-05 16:50:55.811 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec
. 2024-06-05 16:50:55.811 Disable Nagle: No
. 2024-06-05 16:50:55.811 Proxy: None
. 2024-06-05 16:50:55.812 Send buffer: 262144
. 2024-06-05 16:50:55.812 UTF: Auto
. 2024-06-05 16:50:55.812 FTPS: None [Client certificate: No]
. 2024-06-05 16:50:55.812 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2024-06-05 16:50:55.812 Local directory: C:\Users\Hemant Kapoor\Documents, Remote directory: /, Update: Yes, Cache: Yes
. 2024-06-05 16:50:55.812 Cache directory changes: Yes, Permanent: Yes
. 2024-06-05 16:50:55.812 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2024-06-05 16:50:55.812 Timezone offset: 0h 0m
. 2024-06-05 16:50:55.812 --------------------------------------------------------------------------
. 2024-06-05 16:50:55.868 Connecting to 195.0.0.16 ...
. 2024-06-05 16:50:55.868 Connected with 195.0.0.16. Waiting for welcome message...
< 2024-06-05 16:50:56.419 220--- Welcome to FTP_Server_Teensy41 ---
< 2024-06-05 16:50:56.419 220 -- FTP_Server_Teensy41 v1.2.0 --
> 2024-06-05 16:50:56.419 USER teensy4x
< 2024-06-05 16:50:56.636 331 Ok. Password required
> 2024-06-05 16:50:56.636 PASS ********
< 2024-06-05 16:50:56.669 230 Ok
> 2024-06-05 16:50:56.669 SYST
< 2024-06-05 16:50:56.886 500 Unknown command
> 2024-06-05 16:50:56.886 FEAT
< 2024-06-05 16:50:56.919 211-Extensions supported:
< 2024-06-05 16:50:56.919 MLST type*;modify*;size*;
< 2024-06-05 16:50:56.919 MLSD
< 2024-06-05 16:50:56.919 MDTM
< 2024-06-05 16:50:56.919 MFMT
< 2024-06-05 16:50:56.919 SIZE
< 2024-06-05 16:50:56.919 SITE FREE
< 2024-06-05 16:50:56.919 211 End.
. 2024-06-05 16:50:56.934 Connected
. 2024-06-05 16:50:56.934 --------------------------------------------------------------------------
. 2024-06-05 16:50:56.934 Using FTP protocol.
. 2024-06-05 16:50:56.934 Doing startup conversation with host.
> 2024-06-05 16:50:56.950 PWD
< 2024-06-05 16:50:57.166 257 "/" is your current directory
. 2024-06-05 16:50:57.166 Changing directory to "/".
> 2024-06-05 16:50:57.166 CWD /
< 2024-06-05 16:50:57.169 250 Directory changed to /
. 2024-06-05 16:50:57.169 Getting current directory name.
> 2024-06-05 16:50:57.169 PWD
< 2024-06-05 16:50:57.385 257 "/" is your current directory
. 2024-06-05 16:50:57.493 Retrieving directory listing...
> 2024-06-05 16:50:57.493 TYPE A
< 2024-06-05 16:50:57.669 200 TYPE is now ASCII
> 2024-06-05 16:50:57.669 PASV
. 2024-06-05 16:50:57.917 Disconnected from server
. 2024-06-05 16:50:57.917 Could not retrieve directory listing
* 2024-06-05 16:50:57.985 (EFatal) **Lost connection.**
* 2024-06-05 16:50:57.985 Disconnected from server
* 2024-06-05 16:50:57.985 Could not retrieve directory listing
* 2024-06-05 16:50:57.985 Error listing directory '/'.
Can you please help me with this issue.
