Hi all
I have a Ky040 encoder that I want to use for an oven controller and timer.
It has to provide separate values for setting the temperature and the count down timer
My problem is that when moving the encoder to set one value it changes the other due to the common encvalue
int encvalue = k040.read() //ky040 library
int tempvalue = encvalue
int timmrvalue encvalue
I can easily make the timer and temperature work separately
I have individual buttons to select each mode and use the ky040 buttont to start/stop the timer. I have button/bounce library
The temperature needs to be able to be changed without affecting the running timer
I am familiar with enum mode/case switching
Does anyone have any ideas about how to solve this particular problem.
