Hi all, after facing some problems with my serial data transfer between two teensy modules last year, I have decided to restart from scratch with sample programs. I have two Teensy modules - Teensy1 and Teensy2.
Teensy1 is for sending data on Serial 6 and the sketch is as follows:
Teensy2 is for receiving data on Serial 5 and the sketch is as follows:
On checking the serial data received at Teensy2 on the Serial Monitor, I am seeing some random characters every now and then. How can I stop this from happening?
Thanks in advance!
C++:
char tx_arr[22];
#define Teensy2 Serial6
uint8_t count;
static uint32_t CurrTime, PrevTime;
Teensy2.begin(115200);
Serial.begin (9600);
CurrTime = millis();
if((CurrTime-PrevTime) > 1000)
Serial.print("TX Prog --->");
Serial.println(count);
sprintf(tx_arr,"Hi my name Teensy1 %u",count);
Serial.println(tx_arr);
PrevTime = CurrTime;
Teensy2.print(tx_arr);
Teensy2.print('\r');
memset(tx_arr, '\0', sizeof tx_arr);
count++;
C++:
#define Teensy1 Serial5
char rx_arr[90];
static uint8_t ndex;
Teensy1.begin(115200);
while(Teensy1.available())
char datachar = Teensy1.read();
rx_arr[ndex] = datachar;
//Serial.print(datachar);
if(datachar=='\r')
rx_arr[ndex]='\0';
Serial.println(rx_arr);
ndex=0;
memset(rx_arr, '\0', sizeof rx_arr);
ndex = ndex + 1;
Thanks in advance!
