onehorse
I just got my first Teensy (3.1) and hooked it up to my current project--- a Nokia 5110 display showing sensor fused AHRS from a MPU-9150. The Teensy 3.1 replaces a 3.3 V 8 MHz Pro Mini. When I start the sketch, the display shows the header info but when I get to the first serial write it seems like the sketch stops, no further output of any kind. I verified I can get serial out using the blink program, and that I set the proper serial port (COM9) showing as the Teensy USB Serial port in the device manager, but I get nothing from the Arduini IDE serial monitor. Here is the first (functional) part of the sketch:
#include "I2Cdev.h"
#include "MPU6050_9Axis_MotionApps41.h"
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
// Using NOKIA 5110 monochrome 84 x 48 pixel display
// pin 9 - Serial clock out (SCLK)
// pin 8 - Serial data out (DIN)
// pin 7 - Data/Command select (D/C)
// pin 5 - LCD chip select (CS)
// pin 6 - LCD reset (RST)
Adafruit_PCD8544 display = Adafruit_PCD8544(9, 8, 7, 5, 6);
// Declare device MPU6050 class
MPU6050 mpu;
// global constants for 9 DoF fusion and AHRS (Attitude and Heading Reference System)
#define GyroMeasError PI * (60.0f / 180.0f) // gyroscope measurement error in rads/s (shown as 60 deg/s)
#define GyroMeasDrift PI * (0.0f / 180.0f) // gyroscope measurement drift in rad/s/s (shown as 0.0 deg/s/s)
// There is a tradeoff in the beta parameter between accuracy and response speed.
// In the original Madgwick study, beta of 0.041 (corresponding to GyroMeasError of 2.7 degrees/s) was found to give optimal accuracy.
// However, with this value, the LSM9SD0 response time is about 10 seconds to a stable initial quaternion.
// Subsequent changes also require a longish lag time to a stable output, not fast enough for a quadcopter or robot car!
// By increasing beta (GyroMeasError) by about a factor of fifteen, the response time constant is reduced to ~2 sec
// I haven't noticed any reduction in solution accuracy. This is essentially the I coefficient in a PID control sense;
// the bigger the feedback coefficient, the faster the solution converges, usually at the expense of accuracy.
// In any case, this is the free parameter in the Madgwick filtering and fusion scheme.
#define beta sqrt(3.0f / 4.0f) * GyroMeasError // compute beta
#define zeta sqrt(3.0f / 4.0f) * GyroMeasDrift // compute zeta, the other free parameter in the Madgwick scheme usually set to a small or zero value
#define Kp 2.0f * 5.0f // these are the free parameters in the Mahony filter and fusion scheme, Kp for proportional feedback, Ki for integral
#define Ki 0.0f
int16_t a1, a2, a3, g1, g2, g3, m1, m2, m3; // raw data arrays reading
uint16_t count = 0; // used to control display output rate
uint16_t delt_t = 0; // used to control display output rate
uint16_t mcount = 0; // used to control display output rate
uint8_t MagRate; // read rate for magnetometer data
float pitch, yaw, roll;
float deltat = 0.0f; // integration interval for both filter schemes
uint16_t lastUpdate = 0; // used to calculate integration interval
uint16_t now = 0; // used to calculate integration interval
float ax, ay, az, gx, gy, gz, mx, my, mz; // variables to hold latest sensor data values
float q[4] = {1.0f, 0.0f, 0.0f, 0.0f}; // vector to hold quaternion
float eInt[3] = {0.0f, 0.0f, 0.0f}; // vector to hold integral error for Mahony method
Serial.begin(9600); // Start serial at 38400 bps
display.begin(); // Initialize the display
display.setContrast(58); // Set the contrast
display.setRotation(0); // 0 or 2) width = width, 1 or 3) width = height, swapped etc.
// Start device display with ID of sensor
display.clearDisplay();
display.setTextSize(2);
display.setCursor(0,0); display.print("MPU9150");
display.setTextSize(1);
display.setCursor(0, 20); display.print("9 DOF sensor");
display.setCursor(0, 30); display.print("data fusion");
display.setCursor(20, 40); display.print("AHRS");
display.display();
delay(2000);
// Set up for data display
display.setTextSize(1); // Set text size to normal, 2 is twice normal etc.
display.setTextColor(BLACK); // Set pixel color; 1 on the monochrome screen
display.clearDisplay(); // clears the screen and buffer
display.display();
// initialize MPU6050 device
Serial.println(F("Initializing I2C devices..."));
I see the Nokia display but do not see the first Serial print. I'm not sure it should matter but do I have to define SDA and SCL as A4 and A5 for I2C? I hope there is something obvious I am overlooking. Thanks for any help!
mpu.initialize();
#include "I2Cdev.h"
MPU6050 mpu;
#define Ki 0.0f
display.display();
delay(2000);
display.display();
mpu.initialize();
