For a project, the Teensy is conncted to 2 devices with serial ports. But the Teensy should show the 2 physical serial ports and 2 "virtual" serial ports to a PC. On the PC, 4 standard COM port should be present, to be used by existing software.
It work on the desk using tripe serial on USB, but the 4th port is missing. And the final application require 20 meters long cable. Which eliminates USB.
Is there an existing standard ethernet protocol to do that ??? But more important, no application/driver on Windows is required.
How to declare COM ports routed to TCP/IP ????
And on Teensy ????
Thanks for the help
And on Teensy ????
Thanks for the help
