Setting momentary button array with latching functionality. Teensy 4.0 content
chris@home
Hello all.
My first post here because almost any issue I ever have can usually be answered with a good search of this forum. This time I can't find exactly what I want, likely due to the search terms I'm using and my lack of knowledge in describing exactly what I want in a technical manner for the search engine.
I'm working on a MIDI controller that I would like to use with an organ I'm building using a Teensy 4.0. The ultimate goal is to have 12 latching buttons, 9 faders (organ drawbars) and 9 or so analog rotary knobs. I'm familiarizing myself with each chunk as I go just so I don't overwhelm myself with too much at once. So I'm learning to build each part in phases and learn from my mistakes as I go. I've figured out that baby steps helps me understand what I'm doing. I know I'll likely need to incorporate a MUX at some point, but so far I feel like I've learned a bunch on this journey.
In one of my searches, I did see a thread with code posted that was pretty close to what I needed... but didn't have the latching functionality. Here's a link to the original post MIDI footswitch for Guitar
I changed a few things around to get the latching functionality, but now I see that I've overlooked something in my inexperience. While it latches based on the last value of 0 or 127... the lookback is agnostic. If I have two buttons and the last value of one is 127 and the last value of the other is 0, when I press again the next value entered will be 0 regardless of the value of that specific button. So it's applying that last read value for any press even if it's not what I'm wanting.
Example:
DirectionMessageMIDI ChValueExpected ValueHex
outController Sustenuto Pedal (on/off): 0100B0 42 00
outController Soft Pedal (on/off): 1271127127B0 43 7F
outController Sustenuto Pedal (on/off): 010127B0 42 00
In this example you can see that the message outController Sustenuto Pedal (on/off) sent a value of 0 twice, but the expectation would have been a value of 127. However it looks like it was polling that last value of 127 set by the Controller Soft Pedal (on/off) and therefore sent a value of 0.
Honestly, I don't feel too bad about this because I'm amazed I made it this far.
I'm also seeing a similar issue with the LED's. My initial goal was to have a latching LED option assigned to each button so I would have a visual indicator of the state of each associated button. But it's merely turning on the LED associated with the button, then turning off when I press the next button. This one isn't an absolute, but I figured since I was being all fancy I might as well see if I could get that to do something neat as well.
Maybe I've just boy-coded too close to the sun and I need to lower my expectation and just use toggle switches instead of a momentary button?
Maybe I need to use something like control surface? I've only lightly dabbled with it so I'm not super comfortable with it. Also I feel like what I'm learning here can be ported to non-MIDI workflows as I get better so that's a consideration I've had too.
I would love some guidance and input on where I'm going wrong and if there's a better way to do this... let me know. I can take it.
Also, if I'm missing some detail please let me know and I'll add it.
Thanks!
Here's my code.
// select MIDI from the "Tools > USB Type" menu
// Create an option to use momentary switch with latching functionality.
// Optimally, this will allow multiple MIDI Control Change messages to be read as 0 or 127
// with button presses.
#include <Bounce.h>
// Set up the pins for buttons and LED's
const int channel = 1;
const int buttonPins[] = { 2, 3, 4, 5, 20, 21, 22, 23 };
const int ledPins[] = { 6, 7, 8, 9, 16, 17, 18, 19 };
// Configured buttons with 15 ms debounce time because my test buttons are so jittery. Final version
//should be around 5-10ms
Bounce buttons[8] = {
  Bounce(buttonPins[0], 15),
  Bounce(buttonPins[1], 15),
  Bounce(buttonPins[2], 15),
  Bounce(buttonPins[3], 15),
  Bounce(buttonPins[4], 15),
  Bounce(buttonPins[5], 15),
  Bounce(buttonPins[6], 15),
  Bounce(buttonPins[7], 15)
int lastButtonPressed = -1;  // Variable to track the last button pressed
  // Set button pins as input with internal pullup
  for (int i = 0; i < 8; i++) {
    pinMode(buttonPins[i], INPUT_PULLUP);
    pinMode(ledPins[i], OUTPUT);
    digitalWrite(ledPins[i], LOW);  // Turn off all LEDs initially
// /Stores the value of Control Change state sent as high or low in the loop
uint8_t cc_value = 0;
// Stores the value of the last LED state as off or on in the loop
uint8_t led_value = LOW;
  // Update the state of the buttons
    buttons[i].update();
  // Check if any button was pressed and updates based on the last state
    if (buttons[i].fallingEdge()) {
          if( cc_value == 127) cc_value = 0;
    else cc_value = 127;
      usbMIDI.sendControlChange(60 + i, cc_value, channel);  // Send Control Change message (60 + i is the MIDI CC)
      lastButtonPressed = i;                    // Update the last button pressed
  // Turn on only the LED of the last button pressed and turn off the others
    if (i == lastButtonPressed) {
          if( led_value == LOW) led_value = HIGH; // This should be looking to the current state and
    else led_value = LOW;                         // responding appropriately like a latching switch, but doesn't.
      digitalWrite(ledPins[i], led_value);
  // Read and discard incoming MIDI messages
  while (usbMIDI.read()) {
    // read and discard incoming messages
you need to hold all the cc_values at the moment you are just using one variable, something like:
// Store the value of Control Change for each button (0 or 127)
uint8_t cc_value[8] = {0, 0, 0, 0, 0, 0, 0, 0};
// Toggle CC value between 0 and 127
if (cc_value[i] == 127) {
  cc_value[i] = 0;
  digitalWrite(ledPins[i], 0);
  cc_value[i] = 127;
  digitalWrite(ledPins[i], 1);
First off. Thanks so much for that info. I don't know why I didn't think of the need for storing the values. Seems sort of obvious in hindsight. Also, that suggestion is so much cleaner than what I was using before.
After the update I'm having success with the LED's, however now I'm only sending a single value of 116 on all CC messages. They're sending the correct message, but not updating the value (edited for clarity). I keep staring at the sketch thinking that will help me understand it, but enlightment keeps eluding me. I've tweaked a few things, but mostly get error messages with any change I make.
In the Output monitor here is what I'm seeing when compiling. I can successfully compile with no error messages, but it looks like we're not a happy family right now.
/Arduino/Teensy_latching_MIDI_with_array/Teensy_latching_MIDI_with_array.ino: In function 'void loop()':
/Arduino/Teensy_latching_MIDI_with_array/Teensy_latching_MIDI_with_array.ino:59:41: warning: invalid conversion from 'uint8_t*' {aka 'unsigned char*'} to 'uint8_t' {aka 'unsigned char'} [-fpermissive]
59 | usbMIDI.sendControlChange(60 + i, cc_value, channel); // Send Control Change message (60 + i is the MIDI CC)
| uint8_t* {aka unsigned char*}
In file included from /Arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4/WProgram.h:58,
from /Library/Caches/arduino/sketches/994EAD4FC8A9B2F6E97F909E43FCBD95/pch/Arduino.h:6:
/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4/usb_midi.h:152:57: note: initializing argument 2 of 'void usb_midi_class::sendControlChange(uint8_t, uint8_t, uint8_t, uint8_t)'
152 | void sendControlChange(uint8_t control, uint8_t value, uint8_t channel, uint8_t cable=0) __attribute__((always_inline)) {
Memory Usage on Teensy 4.0:
FLASH: code:10424, data:3048, headers:9052 free for files:2009092
RAM1: variables:4576, code:8640, padding:24128 free for local variables:486944
RAM2: variables:6272 free for malloc/new:518016
Here's the updated loop:
  cc_value[i] = 0;
  cc_value[i] = 127;
you need to reference to the element in the array:
from -
to -
usbMIDI.sendControlChange(60 + i, cc_value[i], channel);
Cheers, Paul
Oh my gravy. How did I miss that one? I think I was so engrossed thinking I made a mistake in the updates that I neglected that part.
Thank you again.
For posterity, here's the updated sketch and output table. In addition to the working bits we've already discussed, I updated it to allow users to call out specific CC messages for each button press. For my use case that is much better than the linear setup that I started with, but I didn't want to get too deep into the weeds until I worked through the on/off thing. I feel so fancy now.
OutController 1141127127B0 72 00
OutController 1151127127B0 73 00
OutController 114100B0 72 00
OutController 1171127127B0 75 7F
OutController 117100B0 75 7F
OutController 115100B0 73 00
#include <Bounce.h>
// Set up the pins for buttons,  LED's, and the Control Change messages that correspond with each
//Change values as needed for different CC messages
const int cc_message[] = {110, 111, 112, 113, 114, 115, 116, 117};
// Configured buttons with 25 ms debounce time because my test buttons are so jittery. Final version
  Bounce(buttonPins[0], 25),
  Bounce(buttonPins[1], 25),
  Bounce(buttonPins[2], 25),
  Bounce(buttonPins[3], 25),
  Bounce(buttonPins[4], 25),
  Bounce(buttonPins[5], 25),
  Bounce(buttonPins[6], 25),
  Bounce(buttonPins[7], 25)
  cc_value[i] = 0;
  cc_value[i] = 127;
      usbMIDI.sendControlChange(cc_message[i], cc_value[i], channel);  // Send MIDI message.
