TheSoupMasta
As the title says, we are facing an issue where something keeps killing our teensy 4.1s. They are not able to run code that was uploaded, and they reach insanely high temps while running. In fact, we once misplaced a multimeter lead that had plastic insulation around it onto the chip and it melted though the whole plastic casing... That would have had to be over 150 degrees C for it to melt like that. We added heatsinks so we could keep one running long enough to diagnose the problem, but that was little use.
A few things we noted:
- Teensies would disappear from the list of devices in the Arduino 2.0 IDE.
- The program pin reads 0V in comparison to ground, and the button seems to have no effect.
- Button has no effect after some use, LED just no longer blinks after pressing and we are noticing no effect on the mode of the teensy after pressing.
- The 3.3V to ground reads 0.12V. From what I've read, this is indicative of a short circuit somewhere - but where exactly? We've checked all of our connections and new teensy 4.1s just die after half an hour of use.
- We made sure the VIN is max 3.3V.
- We have a regulated 3.3V going into teensy.
- Even if we keep the teensy plugged in, it just no longer uploads after a bit of the heat.
- Teensy experiences this phenomenon just plugged into the USB, but this only happens after we run it plugged into our main board.
We mount this teensy onto our main board as a sort of central brain. The main board is included below and exported from Fusion 360 Electronics and placed into a zip folder. JP9 and JP13 are 5V and 3.3V regulators respectively, JP 1, 2, 3, 4 are motor drivers from pololu, JP 15-19 is just some I/O leading to other boards. The diode array is just a color-sensing system for detecting white lines against a different colored background. VCC is 12V.
As far as I can tell, we don't have any short circuits, and we have no clue why this is happening. This also coincides with the fact that our motor drivers don't work, so that's another issue.
