KurtE
Senior Member+
I have been thinking about making a simpler rev for the Teensy LC... But wondering about what I currently do for sound output.
My boards typically have a simple speaker. (http://www.digikey.com/product-search/en/audio-products/buzzers/720967?k=102-1155-ND), which I have a jumper that I optionally connect up to IO pin and use code like tone to make sounds. I like this with my robots as to know state changes and the like.
The buzzer is hooked up like:
Wondering if I rev board, would it make more sense to optionally connect to DAC? Could I then use some of teensy sound library? On setups with Linux boards, I at times generate PCM sounds or use Espeak...
If I do hook up to DAC, should I change the sound circuit?
Thanks
Kurt
Thanks
Kurt
