Sparkfun BNO080 - Teensy 3.6 >> 4.0
As Paul mentioned, hard to know, what is happening, without additional information. Like which BNO080 and how is it configured. Example, just recently we just tested a BNO080 running in SPI mode. There are I believe 4 different ways that they can be configured to talk to the external world. So again pictures would help.
Short answer is yes. Several of us have tested the BNO080 in I2C mode. There was an issue but as Paul mentioned in post #71 that has been fixed since Teensyduino 1.49. We are up to 1.53 (latest). With out further information its hard to speculate, like whats your hook-up, what breakout board are you you using, etc. First I would check the wiring and run the scanner that is under examples in Wire.
Hi. Thanks for the reply!
The scanner to run needs to be modified to run the bno080 on the teensy? Would you please be able to share your i2c scanner code.
At this point i am simply directly wiring the bno080 with the teensy 4.0, connecting
A4
A5
Gnd
3.3v
A4
A5
Gnd
3.3v
I can confirm those are the correct pins to use.
Maybe there's a mistake or misunderstand which could become apparent if we could actually see photos of the wiring?
Ok. Thanks! Do i need to just uncomment and change the pin # to 18 and 19
Wire.setSCL(19);
Wire.setSDA(18);
I will send a picture as soon as i arrive home today
Do i need to use any 10k resistors on sda and scl ?
Thanks!
It defaults to pins 18 and 19 which are A4 A5... So no it should see the board... Again assuming the board works, is configured for I2C
Note: The Sparkfun BNO080 has Pull UP resistors on the SCL/SDA pins, which I believe are 2.2K... Question again is, which unit are you using? configured for I2C? Have PU resistors?
What do you mean by "unit" ?
I am using a teensy 4.0
So it looks like you have the same one
I moved mine that is not part of test board to breadboard with T4 and hooked up with default wiring:
And it works for me:
Scanning...
Device found at address 0x4B  (ADS1115,TMP102,BNO080,Qwiic Keypad)
done
Scanning...
done
Scanning...
done
So the main thing would be to double check your wiring and make sure you did not swap SCL and SDA or obb by one pin or???
Would you please be able to share the i2c code?
I have no clue why my two bno080 do not work. The bno055 have no issue
Possible that the bno080 is frozen in some sort of pre initialization status?
The code I ran was simply File->Examples->Wire->Scanner
Next question, when you compile where is it finding the Wire library? Mine is non-standard, so the build shows:
Multiple libraries were found for "Wire.h"
 Used: C:\Users\kurte\Documents\Arduino\libraries\Wire
 Not used: C:\arduino-1.8.13\hardware\teensy\avr\libraries\Wire
But that is because I have a git clone of the official project that I make updates to. Mine is currently in sync with Paul's master branch (as he pulled in my last change...)
But if you have one in your documents\arduino\libraries directory you may need to see if it is in sync or if you can just delete it and use the one released with Teensyduino.
Also make if you are running an older version of Teensduino I would probably try updating to the current released version.
Ok. Tx. Going to post the screen with what is loaded.
Another question I have is does the 3.3v of the teensy fine for the bno080?
Hi! i am back home.
This is what gets loaded with my arduino program
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\MARCOB\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\MARCOB\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\MARCOB\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10813 -build-path C:\Users\MARCOB\AppData\Local\Temp\arduino_build_734743 -warnings=none -build-cache C:\Users\MARCOB\AppData\Local\Temp\arduino_cache_163131 -verbose C:\Users\MARCOB\AppData\Local\Temp\arduino_modified_sketch_992997\sketch_sep30a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\MARCOB\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\MARCOB\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\MARCOB\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10813 -build-path C:\Users\MARCOB\AppData\Local\Temp\arduino_build_734743 -warnings=none -build-cache C:\Users\MARCOB\AppData\Local\Temp\arduino_cache_163131 -verbose C:\Users\MARCOB\AppData\Local\Temp\arduino_modified_sketch_992997\sketch_sep30a.ino
Using board 'teensy40' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy4' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\sketch\\sketch_sep30a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Wire.h: [Wire-master@1.0 Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire-master@1.0 Wire@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\sketch\\sketch_sep30a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\Wire.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\WireIMXRT.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\WireKinetis.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility\\twi.c" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\sketch\\sketch_sep30a.ino.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch/Arduino.h" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch/Arduino.h.gch"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\sketch\\sketch_sep30a.ino.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\sketch\\sketch_sep30a.ino.cpp.o"
Compiling libraries...
Compiling library "Wire"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\Wire.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\libraries\\Wire\\Wire.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\WireKinetis.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\libraries\\Wire\\WireKinetis.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\WireIMXRT.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\libraries\\Wire\\WireIMXRT.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility\\twi.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\libraries\\Wire\\utility\\twi.c.o"
Compiling core...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\memcpy-armv7m.S" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\memcpy-armv7m.S.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\memset.S" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\memset.S.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\clockspeed.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\clockspeed.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\interrupt.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\interrupt.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\analog.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\analog.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\digital.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\digital.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_desc.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_desc.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\delay.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\delay.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\startup.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\startup.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\pwm.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\pwm.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\tempmon.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\tempmon.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\nonstd.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\nonstd.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\rtc.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\rtc.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\bootdata.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\bootdata.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\keylayouts.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\keylayouts.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\eeprom.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\eeprom.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\debugprintf.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\debugprintf.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_joystick.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_joystick.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_keyboard.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_keyboard.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_midi.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_midi.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_mouse.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_mouse.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_seremu.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_seremu.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_serial.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_serial.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_rawhid.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_rawhid.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_serial2.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_serial2.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_serial3.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_serial3.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_touch.c" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_touch.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\HardwareSerial4.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial4.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\Stream.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\Stream.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\HardwareSerial7.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial7.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\AudioStream.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\AudioStream.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\HardwareSerial2.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial2.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\HardwareSerial8.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial8.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\HardwareSerial5.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial5.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\HardwareSerial3.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial3.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\DMAChannel.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\DMAChannel.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\Print.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\Print.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\EventResponder.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\EventResponder.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\HardwareSerial6.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial6.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\IPAddress.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\IPAddress.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\HardwareSerial1.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial1.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\IntervalTimer.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\IntervalTimer.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\HardwareSerial.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\Tone.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\Tone.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\WMath.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\WMath.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\WString.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\WString.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\serialEvent.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\main.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\main.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\new.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\new.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\serialEvent1.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent1.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\serialEvent2.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent2.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\serialEvent3.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent3.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\serialEvent4.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent4.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\serialEvent5.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent5.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\serialEvent6.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent6.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\serialEvent7.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent7.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\serialEvent8.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent8.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\serialEventUSB1.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEventUSB1.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\serialEventUSB2.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEventUSB2.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_audio.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_audio.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\yield.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\yield.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_flightsim.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_flightsim.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4\\usb_inst.cpp" -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_inst.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\memcpy-armv7m.S.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\memset.S.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\analog.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\bootdata.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\clockspeed.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\debugprintf.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\delay.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\digital.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\eeprom.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\interrupt.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\keylayouts.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\nonstd.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\pwm.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\rtc.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\startup.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\tempmon.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_desc.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_joystick.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_keyboard.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_midi.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_mouse.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_rawhid.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_seremu.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_serial.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_serial2.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_serial3.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_touch.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\AudioStream.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\DMAChannel.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\EventResponder.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial1.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial2.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial3.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial4.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial5.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial6.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial7.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\HardwareSerial8.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\IPAddress.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\IntervalTimer.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\Print.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\Stream.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\Tone.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\WMath.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\WString.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\main.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\new.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent1.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent2.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent3.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent4.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent5.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent6.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent7.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEvent8.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEventUSB1.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\serialEventUSB2.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_audio.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_flightsim.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\usb_inst.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\core.a" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\core\\yield.cpp.o"
Archiving built core (caching) in: C:\Users\MARCOB\AppData\Local\Temp\arduino_cache_163131\core\core_88a2d4dfef9509c3677628f3762a6fb0.a
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/sketch_sep30a.ino.elf" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\sketch\\sketch_sep30a.ino.cpp.o" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\libraries\\Wire\\WireIMXRT.cpp.o" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\libraries\\Wire\\WireKinetis.cpp.o" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/core\\core.a" "-LC:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743" -larm_cortexM7lfsp_math -lm -lstdc++
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/sketch_sep30a.ino.elf" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/sketch_sep30a.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/sketch_sep30a.ino.elf" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/sketch_sep30a.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/sketch_sep30a.ino.lst" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/sketch_sep30a.ino.elf"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/sketch_sep30a.ino.sym" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/sketch_sep30a.ino.elf"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/teensy_post_compile" -file=sketch_sep30a.ino "-path=C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743" "-tools=C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/" -board=TEENSY40
Multiple libraries were found for "Wire.h"
 Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
 Not used: C:\Users\MARCOB\Documents\Arduino\libraries\Wire-master
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-size" -A "C:\\Users\\MARCOB\\AppData\\Local\\Temp\\arduino_build_734743/sketch_sep30a.ino.elf"
Sketch uses 18336 bytes (0%) of program storage space. Maximum is 2031616 bytes.
Global variables use 41660 bytes (7%) of dynamic memory, leaving 482628 bytes for local variables. Maximum is 524288 bytes.
C:\Program Files (x86)\Arduino\hardware\teensy/../tools/teensy_post_compile -file=sketch_sep30a.ino -path=C:\Users\MARCOB\AppData\Local\Temp\arduino_build_734743 -tools=C:\Program Files (x86)\Arduino\hardware\teensy/../tools -board=TEENSY40 -reboot -port=usb:0/140000/0/8/2 -portlabel=hid#vid_16c0&pid_0478 Bootloader -portprotocol=Teensy
I have tested with the code that is here:
https://github.com/PaulStoffregen/Wire/blob/master/examples/Scanner/Scanner.ino
one bno080 is recognized and I get this message:
Scanning...
Device found at address 0x4B  (ADS1115,TMP102,BNO080,Qwiic Keypad)
done
The 2nd bno080 gets this message:
Scanning...
No I2C devices found
This is my wiring
https://ibb.co/Sy3S4fT
https://ibb.co/gM5fFX9
No idea why only 1 works.
Maybe the arduino mega where I originally mounted it on broke it? I used the mega 3.3v, but I guess the mega 3.3v damage the bno080?
Now the next step is trying to mount two bno055 and one bno080 on the teensy 4.0
Would you think would work on 1 bus only ?
Is there any scanner for 3 accelerometers on 1 bus only and a scanner for two bno050 on one bus and one bno080 on the other bus?
Do I need to use resistrors on the bno055 sda and scl ?
When you connect 2 or more I2C devices, each needs a unique address. This requirement is common to all I2C chips, not just the BNO080. If you connect 2 chips with the same address, they will conflict and neither will work. I'm pretty sure that's the cause of the trouble you're seeing. Of course you can check this by testing each 1 at a time with the Scanner example. If they each appear as the same address, you can be sure they won't work when both are connected!
Here is Sparkfun's page with wiring instructions.
https://learn.sparkfun.com/tutorials/qwiic-vr-imu-bno080-hookup-guide#hardware-overview
Scroll down to "I2C Jumper". There you can find instructions to reassign one of your boards to use a different address.
I mounted on 1 of the 2 bno055 the adr wire and on the other bno055 I do not mount the adr wire, so the 2 bno055 get different address. The bno080 get automatically its own unique address because works differently than the two bno055 (its chip is different).
Tried that experiment with the arduino uno and worked, for example.
When we were having some issues with I2C, Paul made a few test boards which has on it some of the problematic and common devices to test...
So I plugged in with T4.1...
With this I have most all of them configures to be on SPI buss:
Where in this case you see results per pass of:
Scanning...
Device found at address 0x09  (unknown chip)
Device found at address 0x29  (TSL2561,VL6180,TSL2561,TSL2591,BNO055,CAP1188)
Device found at address 0x3C  (SSD1306,DigisparkOLED)
Device found at address 0x50  (EEPROM,FRAM)
Device found at address 0x62  (LidarLite,MCP4725,AtlasEzoORP)
Device found at address 0x68  (DS1307,DS3231,MPU6050,MPU9050,MPU9250,ITG3200,ITG3701,LSM9DS0,L3G4200D)
Device found at address 0x7C  (FRAM_ID)
done
Scanning...
done
As for two of them. You need to change the I2C address of one of them off of the default:
You can see where the solder jumper is to change it on their site: https://learn.sparkfun.com/tutorials/qwiic-vr-imu-bno080-hookup-guide#hardware-overview
Did you read Sparkfun's "I2C Jumper" info? (link on msg #91)
I'm pretty sure you need that to get these working. They put that jumper on the PCB and went to the trouble of documenting it for a reason....
seems working on teensy using 1 bus only !
Scanning...
Device found at address 0x28 (BNO055,EM7180,CAP1188)
done
Still a mystery what I have done to the 2nd bno080 I have :-(
Does the Sparkfun's "I2C Jumper" , needs to be considered also in my case?
I have 2 ways to answer this question.
1: Maybe, probably yes. All I'm going to say is read and follow the instructions Sparkfun published on their website, which seem to imply you need to use the jumper (why else would they put it on the PCB?)
2: Sparkfun made this product, not PJRC. At this point, I believe we can be quite certain Teensy's I2C port and Wire library are working correctly. The question about what you specifically need to do with Sparkfun's board is really a question to ask of people at Sparkfun.
As Paul said, you might want to ask Sparkfun... But yes if you wish to use two of them on the same buss you need to update the I2C address of one of them.
If you set their jumper that one should have the address 4A.
But again Maybe you fed it 5v instead of 3.3v... Or maybe some of the other jumpers appear are some how shorted (did not see it in your earlier pictures). But if PS0 and PS1 are both set high, than the BNO080 will run using SPI instead of Wire... With the one that is currently not working you might try connecting it up as an SPI device and use one of their SPI examples and see if it works that way or not...
Another option for multiple devices on the same address is to use some form of I2C MUX, like: https://www.sparkfun.com/products/16784
Optional Features
Pull-Up Resistor Jumper
The Qwiic VR IMU has onboard I2C pull up resistors; if multiple sensors are connected to the bus with the pull-up resistors enabled, the parallel equivalent resistance will create too strong of a pull-up for the bus to operate correctly. As a general rule of thumb, disable all but one pair of pull-up resistors if multiple devices are connected to the bus. If you need to disconnect the pull up resistors they can be removed by removing the solder on the corresponding jumpers highlighted below.
But do they infer if we use multiple bno080 or also a mixing of bno080 and bno055? Because then do we have the same jumper option on the bno055?
https://learn.adafruit.com/adafruit-bno055-absolute-orientation-sensor/pinouts
Going to write on their forum.
If you get a definitive answer, please make sure to post a link to it here, so anyone who later finds this conversation by search can get the answer.
