SPI compiler error with ILI9341_t3 (Teensy 3.1)
Hello,
I have been using the Teensy 3.1 with the Adafruit ILI9341 display library for a while without any problems. I have been trying to run the graphicstest example for the new ILI9341_t3 library and am unable to because of some compiler errors related to SPI. I have verified that I am using the newest version of the Arduino environment and Teensyduino. I feel I might just be doing something stupid.
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::setAddrWindow(uint16_t, uint16_t, uint16_t, uint16_t)':
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:47:6: error: 'class SPIClass' has no member named 'beginTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:47:64: error: 'SPISettings' was not declared in this scope
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:50:6: error: 'class SPIClass' has no member named 'endTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::pushColor(uint16_t)':
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:55:6: error: 'class SPIClass' has no member named 'beginTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:55:64: error: 'SPISettings' was not declared in this scope
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:57:6: error: 'class SPIClass' has no member named 'endTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::drawPixel(int16_t, int16_t, uint16_t)':
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:64:6: error: 'class SPIClass' has no member named 'beginTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:64:64: error: 'SPISettings' was not declared in this scope
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:68:6: error: 'class SPIClass' has no member named 'endTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::drawFastVLine(int16_t, int16_t, int16_t, uint16_t)':
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:76:6: error: 'class SPIClass' has no member named 'beginTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:76:64: error: 'SPISettings' was not declared in this scope
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:83:6: error: 'class SPIClass' has no member named 'endTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::drawFastHLine(int16_t, int16_t, int16_t, uint16_t)':
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:91:6: error: 'class SPIClass' has no member named 'beginTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:91:64: error: 'SPISettings' was not declared in this scope
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:98:6: error: 'class SPIClass' has no member named 'endTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::fillRect(int16_t, int16_t, int16_t, int16_t, uint16_t)':
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:117:6: error: 'class SPIClass' has no member named 'beginTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:117:64: error: 'SPISettings' was not declared in this scope
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:126:6: error: 'class SPIClass' has no member named 'endTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'uint8_t ILI9341_t3::readcommand8(uint8_t, uint8_t)':
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:211:9: error: 'class SPIClass' has no member named 'beginTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:211:67: error: 'SPISettings' was not declared in this scope
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:255:9: error: 'class SPIClass' has no member named 'endTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'uint16_t ILI9341_t3::readPixel(int16_t, int16_t)':
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:263:9: error: 'class SPIClass' has no member named 'beginTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:263:67: error: 'SPISettings' was not declared in this scope
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:282:9: error: 'class SPIClass' has no member named 'endTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::begin()':
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:314:10: error: 'class SPIClass' has no member named 'pinIsChipSelect'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:315:18: error: 'class SPIClass' has no member named 'setCS'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:316:32: error: 'class SPIClass' has no member named 'setCS'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:344:6: error: 'class SPIClass' has no member named 'beginTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:344:64: error: 'SPISettings' was not declared in this scope
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:355:6: error: 'class SPIClass' has no member named 'endTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:358:6: error: 'class SPIClass' has no member named 'beginTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:360:6: error: 'class SPIClass' has no member named 'endTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::drawLine(int16_t, int16_t, int16_t, int16_t, uint16_t)':
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:555:6: error: 'class SPIClass' has no member named 'beginTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:555:64: error: 'SPISettings' was not declared in this scope
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:596:6: error: 'class SPIClass' has no member named 'endTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::drawRect(int16_t, int16_t, int16_t, int16_t, uint16_t)':
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:602:6: error: 'class SPIClass' has no member named 'beginTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:602:64: error: 'SPISettings' was not declared in this scope
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:608:6: error: 'class SPIClass' has no member named 'endTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::drawChar(int16_t, int16_t, unsigned char, uint16_t, uint16_t, uint8_t)':
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:850:7: error: 'class SPIClass' has no member named 'beginTransaction'
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:850:65: error: 'SPISettings' was not declared in this scope
/Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:880:7: error: 'class SPIClass' has no member named 'endTransaction'
Thanks!
Yes, the SPI transaction stuff is brand new (hence the errors for beginTransaction etc that you got).
