lucamacavero
Hi all,
I'm using a teensy 4.1 as an SPI slave to sniff SPI transactions. The same master writes to two different slaves in two different moments:
I want to sniff the two transactions from the master. CS1 is connected to SPI CS (pin 10) and it works fine. CS2 is connected to SPI1 CS (LPSPI3, pin 0). In order to configure the peripherals as SPI slaves, I'm using a modified version of this fork of the SPISlave_T4 library. I put here my changes, together with a minimum reproducible example.
In the example below, you can switch between SPI or SPI1 by uncommenting the commented line in
Main comments:
Thanks,
Luca
EDIT:
The solution is reported here.
main.ino
. Below you can find my issue.
C++:
// SPISlave_T4.h
#if !defined(_SPISlave_T4_H_)
#define _SPISlave_T4_H_
typedef enum SPI_BITS {
SPI_8_BITS = 8,
SPI_16_BITS = 16,
SPI_32_BITS = 32,
} SPI_BITS;
typedef void (*_SPI_ptr)();
class SPISlave_T4 {
public:
SPISlave_T4(unsigned portnum, SPI_BITS bits);
void begin(uint8_t bitOrder = MSBFIRST, uint8_t dataMode = SPI_MODE0);
uint32_t transmitErrors() { return transmit_errors; }
void onReceive(_SPI_ptr handler) { _spihandler = handler; }
bool active();
bool available();
void pushr(uint32_t data);
uint32_t popr();
protected:
IMXRT_LPSPI_t *_lpspi; // Book chapter 48; p2799
SPI_BITS _bits;
_SPI_ptr _spihandler = nullptr;
virtual void SLAVE_ISR();
IRQ_NUMBER_t nvic_irq;
uint32_t transmit_errors = 0;
bool sniffer_enabled = 0;
friend void lpspi4_slave_isr();
friend void lpspi3_slave_isr();
friend void lpspi1_slave_isr();
C++:
// SPISlave.cpp
#include "imxrt.h"
#include <Arduino.h>
#include "SPISlave_T4.h"
// Static pointers to the instances. The numbers are the LPSPI port numbers,
// not the Arduino / Teensy port numbers that are printed on the pinout
// card from PJRC. The static pointers are needed so the interrupt service
// routines know which instance of our class to call.
// Note: LPSPI 2 is not available.
static SPISlave_T4* _LPSPI1 = nullptr; // Arduino / Teensy port 2
static SPISlave_T4* _LPSPI3 = nullptr; // Arduino / Teensy port 1
static SPISlave_T4* _LPSPI4 = nullptr; // Arduino / Teensy port 0
void lpspi1_slave_isr() {
_LPSPI1->SLAVE_ISR();
void lpspi3_slave_isr() {
_LPSPI3->SLAVE_ISR();
void lpspi4_slave_isr() {
_LPSPI4->SLAVE_ISR();
SPISlave_T4::SPISlave_T4(unsigned portnum, SPI_BITS bits) {
_SPI_ptr isr = nullptr; // Interrupt service routine address
uint32_t cg = 0; // Clock gate value
volatile uint32_t *iomuxc_base = nullptr; // IO multiplexer registers for SCK/SDI/SDO/PCS0
_bits = bits;
switch(portnum)
// The order of the Arduino SPI port numbers doesn't correspond to the
// LPSPI port numbers
// See e.g.: https://forum.pjrc.com/threads/61234-Teensy-4-1-and-SPI2
case 0: _LPSPI4 = this; _lpspi = &IMXRT_LPSPI4_S; nvic_irq = IRQ_LPSPI4; isr = lpspi4_slave_isr; cg = CCM_CCGR1_LPSPI4(CCM_CCGR_ON); iomuxc_base = &IOMUXC_LPSPI4_PCS0_SELECT_INPUT; break;
case 1: _LPSPI3 = this; _lpspi = &IMXRT_LPSPI3_S; nvic_irq = IRQ_LPSPI3; isr = lpspi3_slave_isr; cg = CCM_CCGR1_LPSPI3(CCM_CCGR_ON); iomuxc_base = &IOMUXC_LPSPI3_PCS0_SELECT_INPUT; break;
case 2: _LPSPI1 = this; _lpspi = &IMXRT_LPSPI1_S; nvic_irq = IRQ_LPSPI1; isr = lpspi1_slave_isr; cg = CCM_CCGR1_LPSPI1(CCM_CCGR_ON); iomuxc_base = &IOMUXC_LPSPI1_PCS0_SELECT_INPUT; break;
// Clock gating register, see 14.7.22 p1085
// Oddly, changing from CG3 to CG2 causes hang on init.
// There appears to be a need for coordination between setting this register and CCM_CBCMR, as per the thread:
// https://forum.pjrc.com/threads/59254-SPI-Slave-Mode-on-Teensy-4
// "CCM_CBCMR |= CCM_CCGR1_LPSPI4(CCM_CCGR_ON); //Clock reaktivieren (reactivate)". Note he also appears to
// set SION on the CS pin as we also did below.
CCM_CCGR1 |= cg;
attachInterruptVector(nvic_irq, isr);
/* Alternate pins not broken out on Teensy 4.0/4.1 for LPSPI4 */
// 11.7.323 LPSPI4_PCS0_SELECT_INPUT DAISY Register (IOMUXC_LPSPI4_PCS0_SELECT_INPUT) 401F_851Ch (Baseaddr + (_portnum * 0x10))
iomuxc_base[0] = 0; // IOMUXC_LPSPIx_PCS0_SELECT_INPUT. For LSPCI4: (401F_851Ch) 0=GPIO_B0_00_ALT3 1=GPIO_B1_04_ALT1
iomuxc_base[1] = 0; // IOMUXC_LPSPIx_SCK_SELECT_INPUT . For LSPCI4: (401F_8520h) 0=GPIO_B0_03_ALT3 1=GPIO_B1_07_ALT1
iomuxc_base[2] = 0; // IOMUXC_LPSPIx_SDI_SELECT_INPUT . For LSPCI4: (401F_8524h) 0=GPIO_B0_02_ALT3 1=GPIO_B1_05_ALT1
iomuxc_base[3] = 0; // IOMUXC_LPSPIx_SDO_SELECT_INPUT . For LSPCI4: (401F_8528h) 0=GPIO_B0_02_ALT3 1=GPIO_B1_06_ALT1
switch (portnum) {
case 0:
// These are the primary SPI mux control registers.
IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_03 = 0x3; // LPSPI4 SCK (CLK) 13 ALT3
IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_01 = 0x3; // LPSPI4 SDI (MISO) 12 ALT3
IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_02 = 0x3; // LPSPI4 SDO (MOSI) 11 ALT3
IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_00 = 0x3; // LPSPI4 PCS0 (CS) 10 ALT3
case 1:
// These are the primary SPI2 mux control registers (unverified -- JG).
IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_15 = 0x12; // LPSPI3_SCK1 (CLK) 27 ALT2
IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_02 = 0x17; // LPSPI3_SDI (MISO1) 1 ALT7
IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_14 = 0x12; // LPSPI3_SDO (MOSI1) 26 ALT2
IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B0_03 = 0x17; // LPSPI3_PCS0 (CS1) 0 ALT7 + SION. See: https://forum.pjrc.com/archive/index.php/t-59893.html
case 2:
// These are the primary SPI3 mux control registers (unverified -- JG).
IOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_00 = 0x14; // LPSPI2_SCK1 (CLK2) 37 ALT4
IOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_03 = 0x14; // LPSPI2_SDI (MISO2) 34 ALT4
IOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_02 = 0x14; // LPSPI2_SDO (MOSI2) 35 ALT4
IOMUXC_SW_MUX_CTL_PAD_GPIO_SD_B0_01 = 0x14; // LPSPI2_PCS0 (CS2) 36 ALT4 + SION. See: https://forum.pjrc.com/archive/index.php/t-59893.html
bool SPISlave_T4::active() {
return !(_lpspi->SR & LPSPI_SR_FCF); // returns 1 if frame transfer not completed
bool SPISlave_T4::available() {
return !(_lpspi->RSR & LPSPI_RSR_RXEMPTY); // returns 1 if Rx FIFO is not empty
void SPISlave_T4::pushr(uint32_t data) {
_lpspi->TDR = data;
uint32_t SPISlave_T4::popr() {
uint32_t data = _lpspi->RDR;
//_lpspi->SR = LPSPI_SR_WCF; /* Clear WCF */
return data;
void SPISlave_T4::SLAVE_ISR() {
if ( _spihandler ) {
_spihandler();
_lpspi->SR = LPSPI_SR_DMF | LPSPI_SR_REF | LPSPI_SR_TEF | LPSPI_SR_TCF | LPSPI_SR_FCF | LPSPI_SR_WCF;
asm volatile ("dsb");
return;
void SPISlave_T4::begin(uint8_t bitOrder, uint8_t dataMode) {
_lpspi->CR = LPSPI_CR_RST;// Reset Module
_lpspi->CR = 0; // Disable Module
_lpspi->FCR = LPSPI_FCR_RXWATER(0) | LPSPI_FCR_TXWATER(0); // x10001; // Watermark for RX and TX
_lpspi->IER = LPSPI_IER_RDIE; // RX Interrupt
_lpspi->CFGR0 = 0; // Verify HRSEL. Should be 1?
_lpspi->CFGR1 = 0; // slave, sample on SCK rising edge, !autoPCS (must raise CS between frames), FIFO will stall, CS active low, match disabled,
_lpspi->CR |= LPSPI_CR_MEN /*| LPSPI_CR_DBGEN*/; /* Enable Module, Debug Mode */
_lpspi->SR = LPSPI_SR_DMF | LPSPI_SR_REF | LPSPI_SR_TEF | LPSPI_SR_TCF | LPSPI_SR_FCF | LPSPI_SR_WCF; // Clear status register
_lpspi->TCR = LPSPI_TCR_FRAMESZ(_bits - 1)
| (!!(dataMode & 2) ? LPSPI_TCR_CPOL : 0)
| (!!(dataMode & 1) ? LPSPI_TCR_CPHA : 0)
| (!!(bitOrder == LSBFIRST) ? LPSPI_TCR_LSBF : 0);
_lpspi->TDR = 0x0; // dummy data, must populate initial TX slot
NVIC_ENABLE_IRQ(nvic_irq);
NVIC_SET_PRIORITY(nvic_irq, 1);
C++:
// main.ino
SPISlave_T4 my_spi(0, SPI_8_BITS);
// SPISlave_T4 my_spi(1, SPI_8_BITS);
while (!Serial);
Serial.println("Hello World!");
my_spi.begin();
my_spi.onReceive(myHandler);
delay(5000); Serial.print("millis: "); Serial.println(millis());
void myHandler() {
while ( my_spi.available() ) {
Serial.print(my_spi.popr(), HEX);
Serial.print(" ");
Main comments:
- SPI peripheral works as expected, for example, an output is the following:
Code:Hello World! millis: 6528 millis: 11528 millis: 16528 A4 A4 F 80 0 40 0 55 2C 2F
- SPI1 peripheral does not work as expected. It seems the interrupt is not raised correctly. In order to fix this issue, this post suggests to set SION bit to 1 when setting
, which is done in the SPISlave_T4 class constructor (SPISlave_T4.cpp). AD_B0_03, according to teensy pinout diagram is pin 0, CS of SPI1 peripheral. - In the case of SPI1 peripheral used, if IER (Interrupt Enable Register) is set to
LPSPI_IER_FCIE
(Frame Complete Interrupt Enable), it seems that CS is read correctly and the interrupt is raised but data on SDI line are not read, for example:
Code:Hello World! ISR. Data read:
Thanks,
Luca
EDIT:
