// Advanced Microcontroller-based Audio Workshop
// http://www.pjrc.com/store/audio_tutorial_kit.html
// https://hackaday.io/project/8292-microcontroller-audio-workshop-had-supercon-2015
// Part 3-3: Add a TFT Display
// Pick your TFT here:
//#include <ILI9341_t3.h>
#include <ST7796_t3.h>
* Pick an update mode:
* 0 = immediate, 1 = frame buffer
* 2 = async frame buffer
#define UPDATE_MODE 0
#if defined ST77XX_BLACK // see which TFT we're using
#include <st7735_t3_font_Arial.h>
#else
#include <font_Arial.h> // from ILI9341_t3
#define ST7735_BLACK ILI9341_BLACK
#define ST7735_RED ILI9341_RED
#define ST7735_YELLOW ILI9341_YELLOW
#define ST7735_GREEN ILI9341_GREEN
//#define ST7735_BLACK ILI9341_BLACK
#endif // defined ST77XX_BLACK
//#include <Adafruit_FT6206.h>
#define COUNT_OF(a) ((int)(sizeof a / sizeof a[0]))
// copy the Design Tool code here
AudioPlaySdWav playSdWav1; //xy=136,65
AudioAnalyzePeak peak2; //xy=348,219
AudioAnalyzePeak peak1; //xy=358,171
AudioOutputI2S i2s1; //xy=380,92
AudioConnection patchCord1(playSdWav1, 0, i2s1, 0);
AudioConnection patchCord2(playSdWav1, 0, peak1, 0);
AudioConnection patchCord3(playSdWav1, 1, i2s1, 1);
AudioConnection patchCord4(playSdWav1, 1, peak2, 0);
AudioControlSGTL5000 sgtl5000_1; //xy=155,192
// Use these with the Teensy 4.x and Audio Shield Rev D or D2
// these are h4yn0nnymou5e pin assignments - you may need to change them
#define TFT_DC 9
#define TFT_CS 22
//#define TFT_CS 10
#define TFT_RST 255 // 255 = unused, connect to 3.3V
#define LED_PWM 4 // used to set brightness of LED backlight
ST7796_t3 tft = ST7796_t3(TFT_CS, TFT_DC);
#else
ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC);//, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
// Use this with the Teensy 3.5 & 3.6 & 4.1 SD card
#define SDCARD_CS_PIN BUILTIN_SDCARD
#define SQ 80
DMAMEM uint16_t save1[SQ*SQ], save2[SQ*SQ];
void makeSave(uint16_t* sv, int n)
uint16_t bg = ST77XX_BLACK;
const char* msg;
switch (n)
default:
tft.setTextColor(ST77XX_RED);
msg = "on";
case 1:
tft.setTextColor(ST77XX_GREEN);
bg = ST77XX_BLUE;
msg = "off";
tft.fillRect(0,0,SQ,SQ,bg);
tft.setFont(Arial_24);
tft.setCursor(25,25);
tft.print(msg);
tft.readRect(0,0,SQ,SQ,sv);
//delay(500);
pinMode(LED_PWM, OUTPUT);
//analogWrite(LED_PWM, 64);
digitalWrite(LED_PWM,1);
//tft.setClock(16000000);
// Setup the LCD screen
tft.init(320, 480);
tft.setRotation(1); // Rotates screen to match the baseboard orientation
#else
tft.begin();
//tft.invertDisplay(true); // LCD requires colors to be inverted
tft.fillScreen(ST7735_BLACK);
tft.setTextColor(ST7735_YELLOW);
//tft.setTextSize(3);
tft.setCursor(40, 8);
//tft.println("Peak Meter");
tft.useFrameBuffer(true);
makeSave(&save1[0],0);
makeSave(&save2[0],1);
tft.useFrameBuffer(false);
tft.freeFrameBuffer();
AudioMemory(10);
//sgtl5000_1.setAddress(HIGH);
sgtl5000_1.enable();
sgtl5000_1.volume(0.3);
while (!(SD.begin(SDCARD_CS_PIN)))
//tft.setMaxTransaction(100000); // deliberately break SD playback!
tft.setMaxTransaction(2000); // default is 1000, but this should be OK
tft.enableYieldInMidTransaction(true); // does a bonus yield() if a mid-transaction break occurs
switch (UPDATE_MODE)
default:
case 0:
elapsedMillis msecs;
* We need to check a number of functions which can result
* in long-running transactions
elapsedMicros checkMicros;
uint16_t colours[] = {ST7735_RED, CL(255,128,0), ST7735_YELLOW, ST7735_GREEN, ST7735_BLUE, ST7735_MAGENTA, ST7735_WHITE};
uint16_t nextColour(void)
static int idx;
uint16_t result = colours[idx];
if (++idx >= COUNT_OF(colours))
idx = 0;
return result;
uint32_t check_(void)
checkMicros = 0;
return checkMicros;
uint32_t check_fillRect(void)
checkMicros = 0;
tft.fillRect(0,0,SQ,SQ,nextColour());
return checkMicros;
uint32_t check_drawChar(void)
tft.fillRect(SQ+96,0,96,SQ,nextColour());
checkMicros = 0;
tft.setFont();
tft.setTextSize(8);
tft.setTextColor(nextColour());
tft.setCursor(SQ+96,0);
tft.print("qb");
return checkMicros;
uint32_t check_drawChar_bg(void)
checkMicros = 0;
tft.setFont();
tft.setTextSize(8);
tft.setTextColor(nextColour(),ST77XX_BLACK);
tft.setCursor(SQ,0);
tft.print("t8");
return checkMicros;
uint32_t check_drawFontChar(void)
tft.fillRect(SQ+96,SQ,96,90,nextColour());
checkMicros = 0;
tft.setFont(Arial_60);
tft.setCursor(SQ+96,SQ);
tft.print("qb");
return checkMicros;
uint32_t check_drawFontChar_bg(void)
checkMicros = 0;
tft.setTextColor(nextColour(),0x38E7);
tft.setCursor(SQ,SQ);
tft.print(" t8 ");
return checkMicros;
uint32_t check_writeRect(void)
checkMicros = 0;
static int which;
uint16_t* wr = (which&16)?save1:save2;
tft.writeRect(0,SQ,SQ,SQ,wr);
which++;// = !which;
return checkMicros;
uint32_t check_writeSubImageRect(void)
tft.fillRect(0,SQ*2,SQ,SQ,nextColour()); // don't count this
checkMicros = 0;
static int which;
int off = 8;
uint16_t* wr = (which&32)?save1:save2;
tft.writeSubImageRect(off,SQ*2+off,SQ-off*2,SQ-off*2,
off, off, SQ, SQ,
wr);
return checkMicros;
uint32_t check_writeSubImageRectBytesReversed(void)
tft.fillRect(0,SQ*3,SQ,SQ,nextColour()); // don't count this
checkMicros = 0;
static int which;
int off = 8;
uint16_t* wr = (which&8)?save1:save2;
tft.writeSubImageRect(off,SQ*3+off,SQ-off*2,SQ-off*2,
off, off, SQ, SQ,
wr);
return checkMicros;
uint32_t check_updateScreen(void)
checkMicros = 0;
tft.updateScreen();
return checkMicros;
#define RUN_CHECK(n) Serial.printf("Check " #n ": %d\n", check_##n())
uint32_t lastCheck;
elapsedMicros asyncTime;
bool asyncStarted;
if (playSdWav1.isPlaying() == false)
Serial.println("Start playing");
//playSdWav1.play("SDTEST1.WAV");
//playSdWav1.play("SDTEST2.WAV");
//playSdWav1.play("SDTEST3.WAV");
playSdWav1.play("SDTEST4.WAV");
delay(10); // wait for library to parse WAV info
if (millis() - lastCheck >= 100)
lastCheck = millis();
Serial.println("========================");
RUN_CHECK(fillRect);
RUN_CHECK(drawChar_bg);
RUN_CHECK(drawChar);
RUN_CHECK(drawFontChar_bg);
RUN_CHECK(drawFontChar);
RUN_CHECK(writeRect);
RUN_CHECK(writeSubImageRect);
RUN_CHECK(writeSubImageRectBytesReversed);
default:
case 1:
RUN_CHECK(updateScreen);
case 2:
Serial.printf("Async start was %sOK\n",tft.updateScreenAsync()?"":"not ");
asyncTime = 0;
asyncStarted=true;
if (asyncStarted && !tft.asyncUpdateActive())
asyncStarted = false;
Serial.printf("Async update took %dus\n",(uint32_t) asyncTime);
