ST7796 Teensyduino support
Right, OK, so I now have a demo. And have fixed a bug. And the DMAChannel fixes needed updating. It's just amazing (and a bit embarrassing...) how the software has rotted since last summer.
  • new DMAChannel code attached;
    • the source repo is here, and should be regarded as definitive - the zip file is just today's snapshot
    • copy the DMAChannel.* and imxrt.h files to your Teensy 4 cores
  • the dev/big-screen-T4 branch has had a bug fix
And here's a demo that works for me; you will need to modify to suit your setup (audio hardware, SPI pins):
C++:
 * Example of correct setup of ST7796 DMA to avoid audio conflicts
 * during asynchronous partial updates
#include <ST7796_t3.h>
AudioSynthWaveform       wav1;      //xy=672,229
AudioSynthWaveform       wav2; //xy=698,269
AudioOutputI2S           i2sOut;           //xy=950,241
AudioConnection          patchCord1(wav1, 0, i2sOut, 0);
AudioConnection          patchCord2(wav2, 0, i2sOut, 1);
AudioControlSGTL5000     audioShield;     //xy=943,324
void randomWav(AudioSynthWaveform& wav)
  wav.begin(0.5f,110.0f*random(1,7),WAVEFORM_SINE);
// Change pin numbers to suit your hardware!
//                        CS DC RST
ST7796_t3 tft = ST7796_t3{29,10,33};
#define TFT_BL 34 // backlight pin
void randomRect(void)
  if (!tft.asyncUpdateActive())
    // choose new rectangle dimensions
    int16_t x=999,y=999,w,h;
    w = random(tft.width() / 2);
    h = random(tft.height() / 2);
    while (x+w >= tft.width())
      x = random(tft.width());
    while (y+h >= tft.height())
      y = random(tft.height());
    // write to frame buffer
    tft.clearChangedArea();
    tft.fillRect(x,y,w,h,random(65536));
    tft.changeAsyncClipArea();
    // update changed area only to screen
    tft.updateScreenAsync(false,true);
  AudioMemory(20);
  audioShield.enable();
  audioShield.volume(0.05f); // low volume
  // standard TFT display setup
  tft.begin();
  pinMode(TFT_BL,OUTPUT);
  digitalWriteFast(TFT_BL,HIGH);
  tft.fillScreen(0);
  tft.setRotation(1);
  tft.print("Hello world");
  // now prepare to use async area updates
  tft.setAsyncInterruptPriority(224);
  tft.useIntermediateBuffer(tft.width() * 2 * 2);
  tft.useFrameBuffer(true);
  tft.updateChangedAreasOnly(true);
elapsedMillis audioTimer;
  if (audioTimer >= 250)
    audioTimer = 0;
    if (random(2))
      randomWav(wav2);
      randomWav(wav1);
  randomRect();
  • pre-emptible DMA v2.zip
Great thanks for your help. I didn't understand what I was supposed to do with the file pre-emptible DMA v2.zip :unsure:
I copied the files DMAChannel.* and imxrt.h into the Teensy 4 cores folder under Win11 and copied the new library ST7735_t3/tree/dev/big-screen-t4 into the Lib folder of my platformIO project. Unfortunately, I'm not getting any sound.
Have you successfully run my example using the Arduino IDE? I know, from admittedly limited experience, that getting PlatformIO to pick up cores and library changes is not trivial. Though maybe it’s easier for you with your greater experience of that.
If you can get the example working OK, using Arduino, and with changes made to suit your audio and display hardware, then we know it should be possible also to get it working with PlatformIO.
Sorry. Its my bug. I used my old example. Your example works fine. I'll try it in my project :)
Display ST7796S FrameBuffer and Audio Test
Houston, i have a problem!
I'm using Wire.h and the Adafruit_MCP23X17.h library for my key and encoder query. The system crashes after initializing Adafruit_MCP23X17.h.
C:
Test with Display ST7796S FrameBuffer with DMA and Audio
#include <Arduino.h>
#include <ST7796_t3.h> // Hardware-specific library
#include <st7735_t3_font_OpenSans.h>
#include <Adafruit_MCP23X17.h>
// TFT Display ST7796S
#define TFT_MISO 12
#define TFT_MOSI 11
#define TFT_SCK 13
#define TFT_DC 8
#define TFT_CS 10
#define TFT_RST 9
#define TFT_BL 28 // TFT Backlight
#define TFT_height 320
#define TFT_width 480
// For 3.5" TFT with ST7796S
ST7796_t3 tft = ST7796_t3(TFT_CS, TFT_DC, TFT_RST);
// GPIO Expander for Encoders and Keys
Adafruit_MCP23X17 mcp0;     // 1st MCP Key 1-16
uint8_t PIN_KEY_INT = 25;   // Keys Interrupt
// TFT FrameBuffer is located in Teensy4.1 512MB Ram2
DMAMEM uint16_t FrameBuffer[TFT_height * TFT_width];
void randomWav(AudioSynthWaveform &wav)
  wav.begin(0.5f, 110.0f * random(1, 7), WAVEFORM_SINE);
// random rectangle ------------------------------------------
    int16_t x = 999, y = 999, w, h;
    while (x + w >= tft.width())
    while (y + h >= tft.height())
    tft.fillRect(x, y, w, h, random(65536));
    tft.updateScreenAsync(false, true);
// Setup -------------------------------------------------------
void setup(void)
  AudioMemory(20);
  // Waveform-Einstellungen
  wav1.amplitude(0.5); // Lautstärke 0.0 - 1.0
  wav2.amplitude(0.5); // Lautstärke 0.0 - 1.0
  wav1.frequency(440); // Frequenz in Hz (A4)
  wav2.frequency(440); // Frequenz in Hz (A4)
  // init TFT Backlight
  pinMode(TFT_BL, OUTPUT);    // TFT Backligth
  digitalWrite(TFT_BL, HIGH); // TFT_BL on
  // init TFT ST7796S
  tft.begin();
  // tft.setFrameBuffer(FrameBuffer);
  tft.setRotation(1);
  tft.invertDisplay(true);
  tft.useIntermediateBuffer(tft.width() * 20 * sizeof(uint16_t)); // intermediate buffer
  // tft.useIntermediateBuffer(tft.width() * 2 * 2);
  // init Wire1 for Keys
    Wire1.begin();
    Wire1.setClock(400000UL); // I2C speed 400KHz
    // init MPC23017 GPIO Expander
    mcp0.setupInterrupts(true, false, LOW);
    for (size_t i = 0; i < 16; i++)
        mcp0.pinMode(i, INPUT_PULLUP);
        mcp0.setupInterruptPin(i, CHANGE);
    mcp0.getCapturedInterrupt();
    mcp0.readGPIOAB();
    mcp0.clearInterrupts();
// Main loop
    audioTimer = 0;
    if (random(2))
      randomWav(wav2);
      randomWav(wav1);
  randomRect();
Crash report
:unsure:
Small objects with a black background are flickering. Is that normal
Another thing I've noticed: I can no longer disable the frame buffer by setting it to false.
One more thing. If I turn off (comment out) all audio, then the screen output no longer works.
Screen flickering bar
C:
// init TFT ST7796S
  tft.begin();
  tft.setRotation(1);
  tft.useIntermediateBuffer(tft.width() * 8 * sizeof(uint16_t)); // intermediate buffer
// draw Envelope delay-time ------------------------------------
void draw_env_delay(int value)
        tft.fillRect(16, 193, 129, 12, ST7735_BLACK);
        tft.drawRect(16, 193, 129, 12, light_grey);
        tft.fillRect(17, 194, value + 1, 10, bar_color_1);
        tft.setCursor(80, 181);
        tft.setTextColor(ST7735_GREEN);
        tft.setFont(OpenSans_8);
        tft.print(F("time"));
        // print values
        tft.fillRoundRect(102 + 45 - 91, 220, 35, 25, 2, tab_color_3);
        tft.setTextColor(ST7735_BLACK);
        tft.setFont(OpenSans_13);
        tft.setCursor(102 + 50 - 91, 226);
        tft.print(Enc_Pos[4][0]);
        // screen update
        tft.updateScreenAsync(false, false);
Not that I’m aware of. Obviously I can’t run the code you posted because it’s incomplete, but I wouldn’t expect that flickering. I’d expect screen updates to be quite slow because you’ve called updateScreenAsync(false,false) rather than (false,true), so it should be updating the whole screen, not just the area you’ve changed.
No code … no idea
Still no code … still no idea
Flickering with horizontal bargraph. ST7796S framebuffer and dma is enabled. Audio is on.
Automatic fading without encoder.
My code
C:
#define TFT_MISO 12
#define TFT_MOSI 11
#define TFT_SCK 13
#define TFT_DC 8
#define TFT_CS 10
#define TFT_RST 9
// init Audio
// draw horizontal bargraph. -----------------------------------
void draw_bar(int value)
        tft.drawRect(16, 193, 129, 12, ST7735_WHITE);
        tft.fillRect(17, 194, value, 10, ST7735_RED);
        tft.setCursor(65, 170);
        tft.setTextColor(ST7735_WHITE);
        tft.setFont(OpenSans_12);
        tft.print(F("value"));
        // print values
        tft.fillRect(76, 220, 35, 25, ST7735_BLACK);
        tft.setCursor(76, 226);
        tft.print(value);
        // screen update
void setup(void)
    AudioMemory(20);
    // Waveform settings
    // init TFT ST7796S
    tft.begin();
    tft.setRotation(1);
    // clear screen
    tft.fillScreen(ST7735_BLACK);
    tft.updateScreenAsync();
// Main loop
elapsedMillis barTimer;
    static int value = 0;
    if (barTimer >= 25)
        barTimer = 0;
        draw_bar(value++);
        if (value == 127)
            value = 0;
TFT_SCK Signal with audio
No screen flickering without audio. ST7796S framebuffer and dma is enabled.
My code
C:
Test with Display ST7796S FrameBuffer with DMA. Audio is disabled
#define TFT_MISO 12
#define TFT_MOSI 11
#define TFT_SCK 13
#define TFT_DC 8
#define TFT_CS 10
#define TFT_RST 9
// init Audio
        // print values
        tft.print(value);
        // screen update
void setup(void)
    AudioMemory(20);
    // init TFT ST7796S
    tft.begin();
    tft.setRotation(1);
    // clear screen
// Main loop
    if (barTimer >= 25)
        barTimer = 0;
        draw_bar(value++);
        if (value == 127)
            value = 0;
TFT_SCK Signal without audio
I don't understand why the TFT_CLK signal is longer when audio is disabled ?
OK, I'm looking at this now.
It looks as if there's something weird that's triggering async updates on every write to the frame buffer, not just when we ask for them. The longer TFT_CLK is probably because you're updating the whole area of "value" / bar / number, whereas the buggy auto update is writing them separately (though the bar is getting updated three times).
Leave it with me, though it may be a while as I'm struggling to understand what on earth is going on here!
OK, found it. You don't have a frame buffer, so actually all the screen updates are synchronous.
But, I hear you say, I called tft.useFrameBuffer(true);! Indeed you did, but you failed to tell it that you'd already allocated the frame buffer, so it tried to allocate one from the heap. Which failed, because a frame buffer for a 320x480 screen is 307200 bytes, and you can't fit two of those into RAM2...
Try adding tft.setFrameBuffer(FrameBuffer); just before tft.useFrameBuffer(true);, and things will look a lot better.
Sorry.. I've changed it now. Screen without flickring but no sound :unsure:
C:
#define TFT_MISO 12
#define TFT_MOSI 11
#define TFT_SCK 13
#define TFT_DC 8
#define TFT_CS 10
#define TFT_RST 9
// init Audio
        // print values
        tft.print(value);
        // screen update
void setup(void)
    AudioMemory(20);
    // init TFT ST7796S
    tft.begin();
    tft.setRotation(1);
    // clear screen
// Main loop
    if (barTimer >= 25)
        barTimer = 0;
        draw_bar(value++);
        if (value == 127)
            value = 0;
Well, it's working here, so there shouldn't be a problem with audio. I did have to add a couple of lines to enable my audio adaptor, but I'm guessing you're using something which doesn't need that.
On a slightly different note, your example's update strategy is terrible. You end up re-writing a lot of unchanged pixels, whereas if you broke the draw_bar() function into three separate asynchronous updates, you'd get a much shorter total update time. I just tried, and it went from 11ms down to 3.5ms - and that's leaving in the continuous re-drawing of "value", which never changes...
I can actually see an opportunity for improving the FB performance further; if we read back a pixel's value just before we write it, and it's going to end up the same colour, then it needn't expand the changed area.
You're right. It's just a simple example. But it should work with audio. Unfortunately, it doesn't.
I have no audio with tft.useFrameBuffer(true)
I don't know if this is the right way to go. So many problems with the graphics. And the audio processing for ADSR, filters, LFOs, and other things has to work too.. I'm considering using a second Teensy 4.0 for drawing graphics and menus on the display. I plan to send commands for drawing graphics and text from the first Teensy 4.1 (audio processing, filters, envelope) to the second Teensy 4.0 via a fast serial data bus. I'm also unsure if the DMA memory in the Teensy 4.1 is sufficient for both audio processing and graphics. Many questions :unsure:
Hallo again..
Okay. Back to the roots. But first, a big thanks on 'h4yn0nnym0u5e' for your great support 🙏
For my touchscreen (ST7796S 480 x 320 pixels), I'm now using the standard ST7796 library from Teensyduino, version 1.60. The display works very well with this library :)
What I don't quite understand logically is why the framebuffer is activated with `tft.useFrameBuffer(false)` and not with `true`.
C:
ST7735_SPICLOCK 60 MHz #define in ST7735_t3.h
#define TFT_MISO 12
#define TFT_MOSI 11
#define TFT_SCK 13
#define TFT_DC 8
#define TFT_CS 10
#define TFT_RST 9
void setup(void)
    // set audio Memory
    AudioMemory(20);
    // set Waveform and Amplitude
    wav1.amplitude(0.5); // Level 0.0 - 1.0
    wav2.amplitude(0.5); // Level 0.0 - 1.0
    // init TFT ST7796S
    tft.init(TFT_height, TFT_width);
    tft.setRotation(1);
    tft.useFrameBuffer(false);
    // clear screen
    // set TFT Backlight on
// Main loop
        audioTimer = 0;
        if (random(2))
            randomWav(wav2);
            randomWav(wav1);
    randomRect();
Audio and Graphics Demo ST7796S TouchDisplay
I'm using the ST7796_t3 library in Teensyduino, Version 1.60 for an ST7796S display (320x480 Pixel). When I set FrameBuffer to true, the image output doesn't work. When I set FrameBuffer to false, the image output works.
C:
#define TFT_MISO 12
#define TFT_MOSI 11
#define TFT_SCK 13
#define TFT_DC 8
#define TFT_CS 10
#define TFT_RST 9
void setup(void)
    // init TFT ST7796S
    tft.init(320,480);
    tft.setRotation(1);
    tft.updateScreen();
// Main loop
elapsedMillis loopTimer;
  if (loopTimer >= 250)
    loopTimer = 0;
      int w = random(TFT_width);
      int h = random(TFT_height);
      if (w >= 380) w = 380;
      if (h >= 220) h = 220;
      tft.fillRect(w, h, 100, 100, random(65535));
I need help. I don't understand why FrameBuffer isn't working. I'm using the ST7796_t3.h library.
Because, if you’ve gone back to the Teensyduino 1.60 version of the library, the async updates are broken, as I found out last May.
It just occurred to me … can you try some different pin choices with my fixed library? It might be worth avoiding pin 8 as it’s used by I2S; I’ve been using 10 for DC as it’s an optimised choice for the LPSPI hardware, but it’ll just be slightly slower if you pick another pin instead. Anything will do for /CS, as long as it doesn’t clash with other peripherals you’re using. SCK and MOSI are obviously fixed; does MISO do anything? I seem to recall that it’s not functional on the ST7796.
I'm now using your corrected ST7735_t3-dev-big-screen-t4 library with the pinout you suggested and Teensyduino version 1.60 with the original DMA files. Graphics and sound are now working perfectly.
C:
Test mit Display ST7796S FrameBuffer mit DMA und Audio
#include <ST7796_t3.h> // Hardwarespezifische Bibliothek
// TFT-Display ST7796S
#define TFT_MISO 12
#define TFT_MOSI 11
#define TFT_SCK 13
#define TFT_DC 10
#define TFT_CS 27
#define TFT_RST 9
#define TFT_BL 28 // TFT-Hintergrundbeleuchtung
// Für 3,5"-TFT-Bildschirme mit ST7796S
// Audio initialisieren
// Der TFT-Framebuffer befindet sich im Teensy4.1 512MB RAM2
  AudioMemory(20);
  // Wellenform-Einstellungen
  wav1.amplitude(0.5); // Lautstärke 0,0 - 1,0
  wav2.amplitude(0.5); // Lautstärke 0,0 - 1,0
  // TFT-Hintergrundbeleuchtung initialisieren
  pinMode(TFT_BL, OUTPUT); // TFT-Hintergrundbeleuchtung
  digitalWrite(TFT_BL, HIGH); // TFT_BL an
  // Standard-TFT-Display-Konfiguration
  tft.begin();
  tft.setRotation(1);
  tft.fillScreen(ST7735_WHITE);
  tft.setCursor(200,150);
  tft.setTextSize(2);
  tft.print("Hallo Welt");
  delay(2000);
      loopTimer = 0;
      falls (w >= 380)
        w = 380;
      falls (h >= 220)
        h = 220;
Drawing a 100 x 100 pixel rectangle takes 2.69 ms. A fillScreen() operation takes approximately 41 ms.
TFT_CLK signal with PCI speed of 60 MHz
