KurtE
Senior Member+
Suggestion for Simple sound setup for Teensy 3.5/3.6, but maybe also 3.2....
As many of you can probably tell, I like playing around with building my own boards, that I threaten to put into a robot and sometimes they actually make it on one. I typically like to have some form of sound generation on the board, as I typically like to have some form of audio feedback when I am running the robot. Typically not very complicated, but simple beeps, to acknowledge when a button has been pressed on the remote control or some form of alert when the battery power is getting low. On many of these earlier boards I put on simple RC circuit with buzzer and did my own version of sound command.
However with some of my Linux based boards, I have extended the sound a little bit by using things like Espeak (or ROS festival), and so for example when I choose a new walking gait, it might tell me what gait was selected.
What I think I want is probably the capabilities of the prop wit-out board, as I actually also have support on my current board for neopixel or APA102 like LEDS. But would be nice to have it on my main board, Thought about simply using the prop shield, but that would cover over some of the internal pins, like USB host pins.
I thought about using the same chip as is used in the prop shield: LM48310, but I think it is too small for me to personally hand solder.
Wish they had a larger version of it.
On a current board, I am trying to use an: LM4862M, but I think I screwed up something, either on the circuit itself or my parts or my soldering... Anyway when I try using it, no sound, and when it is enabled, I feel the speaker heating up...
Suggestions? Maybe I should try the setup that Frank has on the flexboard? Is the only source of them from Ebay?
Thanks
Thanks
