TCA 8418 freezing after input, i2c problem
I am trying to make key matrix using TCA8418. So far I have managed to set the chip up, I am able to read, but whenever I press button, which is part of the matrix the chip freezes. The interupti is not aserted and I recieve NACK when I try to talk to it. I am includig the code and schematics. I am using teensy 3.2. And I am not using the diodes, that are in the schematics.
Do someone have any idea what is going on? The chip is soldered well.
#include <WireKinetis.h>
#include "Wire.h"
#define adress 0x34
#define row 0x07
#define col 0x0F
pinMode(11, INPUT_PULLUP);
pinMode(13, OUTPUT);
  Serial.println("setup begin");
  Wire.begin();
  Wire.beginTransmission(0x34);
            Serial.println("setup");
  Wire.write(0x01);
  Wire.write(0x81);   //initial setup of the chip
int n = Wire.endTransmission();
Serial.println(n);
   Wire.beginTransmission(adress);
   Wire.write(0x1D);
   Wire.write(row); // set row 1
  Serial.println(n);
    Wire.write(0x1E);
    Wire.write(col); //set colum 1-4
   Wire.write(0x29);
   Wire.write(row); // set debounce for row 1
  Serial.println(n);
   Wire.write(0x2A);
   Wire.write(col); // set row 1
  Serial.println(n);
     Serial.println("setup done");
    Serial.println(n);
byte REG;
  int INTERUPPT = digitalRead(11);
  if(INTERUPPT == LOW)
     digitalWrite(13, HIGH);
    Wire.write(0x1E);
    Serial.print("prenos: ");
   int m = Wire.endTransmission();
   Serial.println(m);
    Wire.requestFrom(0x34, 1);        // request 1 byte(s) from slave device.
    while(Wire.available())             // slave may send less than requested.
      REG = Wire.read();
      Serial.print("reg: ");
      Serial.println(REG);
 // delay(1000);
I hope someone will have some idea about what is going on.
