Hello,
I'm in a project that uses all (yes, even the E4 & E5) the teensy 2 ++ pins, so I needed a reference table to remember
all the pins while soldering.
It's based on the Pins PDF + the Wire & SPI application notes. as it's a Excel file (I use OpenOffice) you can modify and
sort it as you want. Useful if you want your output on one side and the inputs on another, or want to know if you have
a PWM pin available for example.
View attachment Pins Tensy 2.0++.pdf 134ko
View attachment Pins Tensy 2.0++.zip 732ko
I post those in the event it would be useful to anybody.
