stefanmader1984
Hi, i am trying to connect a Nokia 5110 Display to a Teensy 2.0 but i can't get it to work to show something on the display. Maybe someone could help me? Am i using the wrong pins or somethin?!
i am using the libraries:
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
The Display hase this pins:
RST --> Teensy 2.0 Pin 8
CE --> Teensy 2.0 Pin 6
DC --> Teensy 2.0 Pin 5
DIN --> Teensy 2.0 Pin 2
CLK --> Teensy 2.0 Pin 1
VCC --> 3.3 Volt with 5 to 3.3V Converter
Light --> connected to GND to turn on light
GND --> Teensy 2.0 GND
i am using the libraries example code and changed the pins to this:
// pin 1 - Serial clock out (SCLK)
// pin 2 - Serial data out (DIN)
// pin 5 - Data/Command select (D/C)
// pin 6 - LCD chip select (CS)
// pin 8 - LCD reset (RST)
Adafruit_PCD8544 display = Adafruit_PCD8544(1, 2, 5, 6, 8);
and the example code is attached.
