HopWorks
I thought I would post for clarification before I blow anything up on my bread board.
I have a teensy 3.0 and want to connect it to an Adafruit OLED 128x32 and I am stuck on pin designations. I looked at a diagram for the teensy 3.0, and another for an Arduino Uno, and picked a connection referred to on this page http://learn.adafruit.com/monochrome-oled-breakouts/wiring-128x32-spi-oled-display, specifically the text
I have looked and looked, and looked some more and I cannot find a connection diagram for the teensy 3.0 and this neat little display. I also have failed to find a diagram showing what the teensy 3.0 pins refer to on an arduino. So if a hookup tutorial like the page mentioned above says "digital 10" I would know what that would refer to on a Teensy 3.0.
I hope someone can help. I love these little teensy boards, and have a 3.1 on the way. I figure if you can write sketches that use arduino libraries and can run on the teensy, there would be a guide to show what pins refer to as it would on an Arduino Uno or whatever.
Thank you so very much for your time!
RST to digital 13 - On the teensy 3.0, that is CS2. On the Uno, it is SCK. SCK is digital pin 12 on the teensy 3.0."Finally, connect the pins to your Arduino - GND goes to ground, Vin goes to 5V, DATA to digital 9, CLK to digital 10, D/C to digital 11, RST to digital 13 and finally CS to digital 12."
