Hi all, first post here
I am planning a quadrocopter project, and have decided to use Teensy 3.0 as the brains of the quad, since it's much more powerful and capable than any other similarly-sized Arduino-esque microcontrollers I've found (Pro Mini, Pro Micro, Nano, etc...). Also, I just think the Teensy is a wonderful board and haven't gotten the chance to play with it yet, so maybe this will be a good opportunity. Also, my first quad project
I want to use the FreeIMU v0.4 board together with the Teensy 3.0. On the software side, I want to use the FreeIMU library designed for this board. I had come across this thread: http://freeimu.varesano.net/node/34 in which Fabio (designer of FreeIMU) and Paul discussed getting Teensy3.0 to work with FreeIMU, and from that I got the impression that the FreeIMU library would indeed work with Teensy 3.0.
But I'm not sure, so I ask: Does Teensy 3.0 currently work with the latest FreeIMU library/software? As well as interfacing hardware-wise with the FreeIMU v0.4 board?
And what if I instead use a different IMU board that's supported by the FreeIMU library?
And how should I configure the FreeIMU library/software specifically for the Teensy?
I know the best way to find the answer would be to pick up a Teensy and IMU myself, but I'm on a limited budget
So hopefully someone here has experience with this.
Thanks.
Thanks.
