Teensy 3.0: How much longer?
waterfox
Does anyone know how much longer the TEENSY 3.0 will be sold? I have a project which works on the 3.0 and not on the 3.1. I see Adafruit no longer sells the 3.0. Considering the implications of trying to fix stuff (or more realistically waiting for fixes (CC3000, NEO pixels)) for the 3.1 vs. just continuing on with the 3.0?
Thanks!
At the current (slow) rate they're selling, I expect PJRC will run out of Teensy 3.0 in May or June 2014. It seems likely that rate will slow even more over time, but it's always difficult to predict the future....
Sometime I can do is investigate and fix anything that isn't working on 3.1. But I can only do that if you post a reproducible bug report.
I worked on NeoPixel some time ago, only days after the 3.1 release. Every indication is it's currently working fine on 3.0 and 3.1 (certainly with the NeoPixels I tested here). If it's not working for you, I need detailed info to investigate.
Please do make sure you're running the latest code.
My apologies Paul,
Everything appears to be working now. I thought I was using the latest libraries but I wasn't. Both the CC3000 and the NEO pixels appear to be working nicely. If I ever meet you in real life I owe you a beer.
-Robbie
