Teensy 3.1 No Serial Port.
SamMoo
Hello,
yesterday i tried to upload a Sketch to my Teensy 3.1 but the serial port is not found by the arduino software. When i try to upload i get this:
Binäre Sketchgröße: 9.696 Bytes (von einem Maximum von 262.144 Bytes)
Estimated memory use: 2.432 bytes (of a 65.536 byte maximum)
C:\Program Files (x86)\Arduino\hardware/tools/teensy_reboot -v -v -v -v -pmk20dx256 -chalfkay -P\\.\COM1 -b12000000 -D -Uflash:w:C:\Users\xxx\AppData\Local\Temp\build1600962227197133737.tmp\Blink.cpp.hex:i
teensy_reboot, verbose mode
trying port 3149
found Teensy Loader, version 1.24
send: status - at Fri Aug 14 13:48:54 2015
status read, retry 0
status read, retry 1
send: status - at Fri Aug 14 13:48:55 2015
status read, retry 2
status read, retry 3
status read, retry 4
status read, retry 5
status read, retry 6
status read, retry 7
status read, retry 8
status read, retry 9
status read, retry 10
send: status - at Fri Aug 14 13:48:56 2015
status read, retry 11
status read, retry 12
status read, retry 13
status read, retry 14
status read, retry 15
status read, retry 16
status read, retry 17
status read, retry 18
status read, retry 19
send: status - at Fri Aug 14 13:48:57 2015
status read, retry 20
status read, retry 21
status read, retry 22
status read, retry 23
status read, retry 24
status read, retry 25
status read, retry 26
status read, retry 27
status read, retry 28
status read, retry 29
send: status - at Fri Aug 14 13:48:58 2015
status read, retry 30
status read, retry 31
status read, retry 32
status read, retry 33
status read, retry 34
status read, retry 35
status read, retry 36
status read, retry 37
status read, retry 38
send: status - at Fri Aug 14 13:48:59 2015
status read, retry 39
status read, retry 40
status read, retry 41
status read, retry 42
status read, retry 43
status read, retry 44
status read, retry 45
status read, retry 46
status read, retry 47
send: status - at Fri Aug 14 13:49:00 2015
status read, retry 48
status read, retry 49
Teensy did not respond to a USB-based request to automatically reboot.
Nothing happens and the Teensy seems to be bricked.
Is there anything i can do to get it back to life?
Greetz,
Sam
PS: the verbose info:
14:11:51: Teensy Loader 1.24, begin program
14:11:51: File "Blink.cpp.hex". 9864 bytes, 15% used
14:11:51: Listening for remote control on port 3149
14:11:51: initialized, showing main window
14:11:51: remote connection opened
14:11:51: remote cmd: "comment: Teensyduino 1.24 - WINDOWS"
14:11:51: remote cmd: "dir:C:\Users\xxx\AppData\Local\Temp\build1969046404649753517.tmp\"
14:11:51: remote cmd: "file:Blink.cpp.hex"
14:11:51: remote cmd: "status"
14:11:51: status data sent
14:11:51: remote cmd: "auto:eek:n"
14:11:51: remote connection closed
14:11:51: HID/win32: vid:187C pid:0521 ver:0000
14:11:52: remote connection opened
14:11:52: remote cmd: "status"
14:11:52: status data sent
14:11:53: remote cmd: "status"
14:11:53: status data sent
14:11:54: remote cmd: "status"
14:11:54: status data sent
14:11:55: remote cmd: "status"
14:11:55: status data sent
14:11:56: remote cmd: "status"
14:11:56: status data sent
14:11:57: remote cmd: "status"
14:11:57: status data sent
14:11:57: Auto Button event
14:11:57: Auto mode: disabled
14:11:57: remote connection closed
14:12:00: Open File event
14:12:04: File "Blink.cpp.hex". 9864 bytes, 15% used
14:12:10: Auto Button event
14:12:10: Auto mode: enabled
14:12:15: Verbose Info event
14:12:41: Open File event
14:12:44: File "Blink.cpp.hex". 9864 bytes, 15% used
14:12:54: Verbose Info event
14:13:08: file changed
14:13:08: File "Blink.cpp.hex". 9864 bytes, 15% used
14:13:08: remote connection opened
14:13:08: remote cmd: "comment: Teensyduino 1.24 - WINDOWS"
14:13:08: remote cmd: "dir:C:\Users\Mooraj\AppData\Local\Temp\build1969046404649753517.tmp\"
14:13:08: remote cmd: "file:Blink.cpp.hex"
14:13:08: remote cmd: "status"
14:13:08: status data sent
14:13:08: remote connection closed
14:13:09: remote cmd: "status"
14:13:09: status data sent
14:13:10: remote cmd: "status"
14:13:10: status data sent
14:13:11: remote cmd: "status"
14:13:11: status data sent
14:13:12: remote cmd: "status"
14:13:12: status data sent
14:13:13: remote cmd: "status"
14:13:13: status data sent
14:13:14: remote cmd: "status"
14:13:14: status data sent
14:13:14: remote connection closed
This is the verbose info:
14:11:51: remote cmd: "dir:C:\Users\Mooraj\AppData\Local\Temp\build1969046404649753517.tmp\"
Looks like you configured the wrong com port in the Arduino IDE. COM1 is a hardware/system port on most systems and can not be mapped to a virtual usb device.
What System are you using, OS X, Linux or Windoof? Which version?
I've tried it on both systems: windows 7 and osx mavericks. On windows the Serial port menu is grey and not accessible, on osx there are just the tty.bluetooth ports.
There is no serial port found when i attach the Teensy to USB.
Is it bricked or complete defective? I cant explain this because yesterday it worked like a charm.
normally there is no serial port creation on the Teensy until your application opens the serial port.
The Teensy downloader does not use a USB serial port... it creates/uses a different mecanism.
Normally when i connect the teensy to usb i can see a serial port in the arduino ide. Now nothing shows up and the leds on the board are dark. Is there a possibillity that the bootloader is defect? Can i do something to restore it?
Try another USB cable. Look in the device manager what happens when you plug in the teensy. Something has to happen in all operating systems. If it doesn't, that simply means that the computer can't see the teensy, either because of a defective use cable or because of a broken teensy.
Well, there's 2 separate issues here.
First is how to check if your Teensy is communicating. I think we've established pretty well that you should *not* necessarily be looking for a serial device.
The main issue is whether this Teensy is dead, for whatever reason. From the non-serial stuff above, it certainly sounds like a hardware failure. :(
This "no serial port displayed" non-problem comes up several times a week.
A clear, concise getting started for T3 is long overdue. Written by someone other than Paul - who's too close to the forest.
