Teensy 3.1 not working with Arduino Wifi101 shield
chensx2012
The official Arduino Wifi101 shield works great on Arduino Uno, Zero or Due. But when I chose the board to be Teensy 3.1, the library was compile with many different errors (many related with the driver). The Wifi101 library was here: https://github.com/arduino-libraries/WiFi101. Is it possible for Teensy to add support for Wifi101 shield?
Please give this a try.
Put this file into your Arduino hardware/teensy/avr/cores/teensy3 folder, replacing the copy which is already there. It will allow the library to compile. I looked at the code briefly and I believe this should be ok. The affected part can never actually run, since digitalPinToInterrupt() always returns a number, so the fallback case never gets used. But it still needs to be able to compile.
Please let me know if this allows the library to actually work?
  • pins_arduino.h
Thanks so much for your quick reply, Paul. I tested your file and the library was compiled successfully. It is big help for me. The Wifi101 shield uses SPI to communicate with Arduino. I was able to get Teensy to send SPI commands to the shield successfully. However, Teensy failed to receive response from the shield. I observed the MISO pin (pin 12), and it was always zero. When I connected the same shield to Arduino Due, it was working perfectly. I was not sure what is the problem. Could you please give me some hint? Thanks. :)
Maybe you need to connect MOSI, MISO, SCK to the 6 pin connector on the shield? Arduino designs their shields to use that 6 pin connector, rather than pins 11, 12, 13 on edge of the shield.
I am pretty sure I made right connections between Teensy and the Wifi shield. Since only the SPI read part was not working, I wonder whether it is the incompacity of the SPI driver caused the problem. I checked that the Wifi101 library used the following driver (WiFi101\src\driver\source\nmspi.h and nmspi.c), is it possible this driver does not work with Teensy? Thank you for your time, Paul. :)
btw, I also attached the spi driver file for your convenience.View attachment nmspi.cView attachment nmspi.h
Also, I found that there is a bus wrapper for samd21 in the path (WiFi101\src\bus_wrapper\source\nm_bus_wrapper_samd21.cpp), is it necessary to make a new wrapper to make the library work with Teensy? Thanks.
View attachment nm_bus_wrapper_samd21.cpp
Their SPI code looks like it should work. They're just using the normal SPI library. They've got a lot of extra abstraction layer stuff, but it ultimately is just the normal SPI library. They're even using SPI transactions! :) (a feature I contributed to Arduino.....)
Yes, they are using SPI transactions you contributed to Arduino world. The reason why I like Teensy so much is because you made powerful functions so easy to use.:) Although the SPI send is working, for example, I can use Wifi.beginAP("WINC1500") to create a new network successfully, the SPI receive is still not working. When I called WiFi.macAddress(), it always returned zeros. I checked all source code according to your tips, but still don't know why. Maybe I have to give up this shield and turn to another Wifi module. :(
Just a final followup, Arduino Wifi101 works with Teensyduino 1.29-beta2 and Arduino 1.6.9 using the Sparkfun adaptor with IOREF to 3.3V fix.
Arduino 1.6.9 has fixes to the Wifi101 library for Teensy, Teensyduino 1.29-beta has fixes in its core library needed by Wifi101, and the Sparkfun board will (hopefully soon) be revised at some point to fix its IOREF problem and other issues.
