I'm using a Teensy 3.1 and running a simple program using the NeoPixel library. On the board I have a push button soldered to the RESET* pin on the bottom of the board. I have a Tektronix scope connected to Pin 6 which is the assigned output for the NeoPixel library. No other hardware (except USB cord) is connected.
Programming the Teensy works just fine. But...
I have to press the RESET button (no, not the Program button, I know the difference!) on average about 15 times -- no exaggeration -- before the program will run and keep running. The other 14 times, the program runs for between 27 to 37 milliseconds according to the scope and then it just hangs. My program does not implement watchdog or any other feature I can think would cause this behavior.
When it does run, the program runs happily for hours... until I pull the power or press the RESET button.
Any ideas what is going on?
