nicolas_soundforce
Hi everybody,
I am working on a MIDI controller project with the Teensy 3.1. I'd like users to connect to the controller into a sturdy USB-B connector like most commercial products. I don't want to have to connect the small micro USB right into the computer. So I need to bridge the micro usb from the teensy to a bigger surdier USB-B connector on the side of the PCB
I do it like this at the moment :
I use a micro-usb/USB-A cable to connect to a USB-A connector that is soldered on the PCB. then I have traces on the PCB that are linking the USB-A connector to the USB-B. It's working perfectly. It's not extremly sofisticated but it's easy, quick and reliable.
I have seen on the pinout that the D+ and D- pads where only available at the back of the Teensy. My project is planned to be sold as a kit and I'd rather not have people solder cables on those.
Is there any other solution out there to make a USB connection to the teensy without its micro-usb header ? Or an easy way to make a reliable connection to the D+ D- pads ?
Thanks in advance everbody!
