I use NetBeans and make on Linux, and the AVR dragon, or other JTAG tools. This works just fine for me, thanks. Glad you like the avatar LOL!
that sounds very nice,Visual Micro plug-in for Visual Studio/Atmel Studio 6.1 works well for Teensy3.x. I've been using it full time for several months. It's terrific. Easily installed. And $0.
Uses the normal Arduino+Teensyduino install. You can use Arduino .ino files and thus use either the Arduino IDE or VisualMicro/VS and flip back and forth. Uses same GCC command line as does Arduino's IDE.
#include <Arduino.h>
~/projects/teensy/without_ardunio_ide $ make
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/analog.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/eeprom.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/keylayouts.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/math_helper.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/mk20dx128.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/nonstd.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/pins_teensy.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/ser_print.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/serial1.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/serial2.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/serial3.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/touch.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_desc.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_dev.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_joystick.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_keyboard.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_mem.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_midi.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_mouse.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_rawhid.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_seremu.c
[CC] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_serial.c
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/AudioStream.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/DMAChannel.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/HardwareSerial1.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/HardwareSerial2.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/HardwareSerial3.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/IPAddress.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/IntervalTimer.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/Print.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/Stream.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/Tone.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/WMath.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/WString.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/avr_emulation.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/main.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/new.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_flightsim.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_inst.cpp
[CXX] /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/yield.cpp
[LD] without_ardunio_ide.elf
build/teensy3/main.o: In function `main':
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/main.cpp:21: undefined reference to `setup'
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/main.cpp:23: undefined reference to `loop'
# This makefile started life as the Makefile from teensy-template, found here:
# https://github.com/apmorton/teensy-template
ifeq ($(v),)
export verbose = 0
export verbose = 1
endif
ifeq ($(verbose),)
export verbose = 0
endif
ifeq ($(verbose),0)
Q = @
MAKEFLAGS += -s
Q =
endif
export Q
# The name of your project (used to name the compiled .hex file)
TARGET = $(notdir $(CURDIR))
# configurable options
OPTIONS = -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH
# options needed by many Arduino libraries to configure for Teensy 3.0
OPTIONS += -D__MK20DX256__ -DARDUINO=105
BUILDDIR = build
ifdef COMSPEC
cygpath-win = $(shell cygpath -w "$1")
cygpath-win = $1
endif
# Location of Teensyduino utilities, Toolchain, and Arduino Libraries.
# To use this makefile without Arduino, copy the resources from these
# locations and edit the pathnames. The rest of Arduino is not needed.
ARDUINO ?= /Applications/Arduino.app/Contents/Java
# path location for Teensy Loader, teensy_post_compile and teensy_reboot
TOOLS_PATH = $(ARDUINO)/hardware/tools
# path location for Teensy 3 core
CORE_PARENT = $(ARDUINO)/hardware/teensy/avr/cores
CORE_PATH = $(CORE_PARENT)/teensy3
# path location for Arduino libraries
LIBRARY_PARENT = ..
LIBRARY_PATH = $(LIBRARY_PARENT)/libraries
# path location for the arm-none-eabi compiler
COMPILER_PATH = $(TOOLS_PATH)/arm/bin
# Settings below this point usually do not need to be edited
# CPPFLAGS = compiler options for C and C++
CPPFLAGS = -Wall -Wno-psabi -g -Os -mcpu=cortex-m4 -mthumb -nostdlib -MMD $(OPTIONS) -Isrc -I$(CORE_PATH)
# compiler options for C++ only
CXXFLAGS = -std=gnu++0x -felide-constructors -fno-exceptions -fno-rtti
# compiler options for C only
CFLAGS =
LDSCRIPT = $(CORE_PATH)/mk20dx256.ld
# linker options
LDFLAGS = -Os -Wl,--gc-sections -mcpu=cortex-m4 -mthumb -T$(LDSCRIPT)
# additional libraries to link
LIBS = -lm
# names for the compiler programs
CC = $(COMPILER_PATH)/arm-none-eabi-gcc
CXX = $(COMPILER_PATH)/arm-none-eabi-g++
OBJCOPY = $(COMPILER_PATH)/arm-none-eabi-objcopy
SIZE = $(COMPILER_PATH)/arm-none-eabi-size
vpath %.c $(LIBRARY_PARENT)
vpath %.cpp $(LIBRARY_PARENT)
vpath %.c $(CORE_PARENT)
vpath %.cpp $(CORE_PARENT)
# automatically create lists of the sources and objects
LC_FILES := $(patsubst $(LIBRARY_PARENT)/%, %, $(wildcard $(LIBRARY_PATH)/*/*.c))
LCPP_FILES := $(patsubst $(LIBRARY_PARENT)/%, %, $(wildcard $(LIBRARY_PATH)/*/*.cpp))
TC_FILES := $(patsubst $(CORE_PARENT)/%, %, $(wildcard $(CORE_PATH)/*.c))
TCPP_FILES := $(patsubst $(CORE_PARENT)/%, %, $(wildcard $(CORE_PATH)/*.cpp))
C_FILES := $(wildcard src/*.c)
CPP_FILES := $(wildcard src/*.cpp)
INO_FILES := $(wildcard src/*.ino)
# include paths for libraries
L_INC := $(foreach lib,$(filter %/, $(wildcard $(LIBRARY_PATH)/*/)), -I$(lib))
OBJS_FILES := $(INO_FILES:.ino=.o) $(C_FILES:.c=.o) $(CPP_FILES:.cpp=.o) $(TC_FILES:.c=.o) $(TCPP_FILES:.cpp=.o) $(LC_FILES:.c=.o) $(LCPP_FILES:.cpp=.o)
OBJS := $(foreach obj,$(OBJS_FILES), $(BUILDDIR)/$(obj))
all: hex
build: $(TARGET).elf
hex: $(TARGET).hex
post_compile: $(TARGET).hex
$(Q)$(TOOLS_PATH)/teensy_post_compile -file="$(basename $<)" -path="$(call cygpath-win,$(CURDIR))" -tools="$(TOOLS_PATH)"
reboot:
$(Q)-$(TOOLS_PATH)/teensy_reboot
upload: post_compile reboot
$(BUILDDIR)/%.o: %.c
@echo "[CC]\t$<"
$(Q)mkdir -p "$(dir $@)"
$(Q)$(CC) $(CPPFLAGS) $(CFLAGS) $(L_INC) -o "$@" -c "$<"
$(BUILDDIR)/%.o: %.ino
@echo "[CXX]\t$<"
$(Q)$(CC) $(CPPFLAGS) $(CXXFLAGS) $(L_INC) -o "$@" -c -x c++ -include Arduino.h "$<"
$(BUILDDIR)/%.o: %.cpp
@echo "[CXX]\t$<"
@mkdir -p "$(dir $@)"
$(Q)$(CXX) $(CPPFLAGS) $(CXXFLAGS) $(L_INC) -o "$@" -c "$<"
$(TARGET).elf: $(OBJS) $(LDSCRIPT)
@echo "[LD]\t$@"
$(Q)$(CC) $(LDFLAGS) -o "$@" -Wl,-Map,$(TARGET).map $(OBJS) $(LIBS)
%.hex: %.elf
@echo "[HEX]\t$@"
$(Q)$(SIZE) "$<"
$(Q)$(OBJCOPY) -O ihex -R .eeprom "$<" "$@"
# compiler generated dependency info
-include $(OBJS:.o=.d)
clean:
@echo Cleaning...
$(Q)rm -rf "$(BUILDDIR)"
$(Q)rm -f "$(TARGET).elf" "$(TARGET).hex" "$(TARGET).map"
Some additional comments...
i have a preference for a OSX based solution and previously invested a significant amount of time into making Xcode and embeddedxcode work. For the most part, it worked on the first project after some back and forth, such as not being allowed to have spaces in file names, and other issues. Implementing libraries is still too convoluted IMO, Xcode seems simply too oriented towards hard-core iOS and OSX development. The recent transition to Xcode 7 went terribly. I spent several hours trying to follow the instructions in the iBooks manual to get my projects transitioned and I have given up for now.
I went back to Visual Studio 2015 (clean install), Arduino 1.6.6 (another clean install), VisualMicro, etc. and so far the whole package seems to install new boards (i.e. mighty 1284, for example), new libraries (i.e. Easy Transfer), etc. with ease. That is, you can use a GUI, select the files of interest or even download them directly from their githubs. More importantly, the documentation that VisualMicro provides to walk a user through the process of getting the IDE, boards, etc. going is leagues ahead of embeddedxcode. Perhaps some day I will go back and try again, for now I am terminally frustrated with the embedxcode experience.
I hope Rob can hire someone who will create a easy-to-follow installation guide that is not just aimed at people who know xCode like the back of their hand. VisualMicro provides a really nice online installation, setup, etc. manual that he should use as a pattern to follow. Is it perfect? Heck no! For instance, the download for the visualmicro code is not on the page one would expect it to be. However, the online visualmicro manual does a much better job of explaining the necessary steps, etc. than the iBook published by Rob.
Additionally, the experience INSIDE the visualmicro plugin is significantly more intuitive than what I am currently getting from embedxcode. It's simply a pleasure to be able to select from the many libraries, boards, etc. that Arduino 1.6.6 serves up or to import a ZIP and have the boards/libraries there, ready to be used. Thus, for anyone looking to transition to a IDE that is a step up from Arduino but who also expects a GUI experience, Visual Studio 2015 and VisualMicro on Windows is a great contender. As Steve points out, there are additional tools you can add like VisualGDB or the higher-end VisualMicro tool to enable debugging. Some day, I may have the skills, experience to use those things. For now, I am simply happy to have a IDE that doesn't get as much in the way of actually programming.
Karl Lunt set up the GNU ARM tool chain for "bare metal" (no Arduino, no IDE, just "make") Teensy 3.1 development on Windows.
I adapted his instructions and Makefile for Ubuntu, which has the pre-built ARM cross tools available, making it real easy to get everything installed. I put a short script on my web site that does everything automatically on a current Ubuntu system.
My page: http://blogs.omnicron.com/ford/2015/06/17/easy-teensy-development-on-ubuntu/
Mike
