Arduino: 1.8.13 (Linux), TD: 1.53, Board: "Teensy 4.0, Raw HID, 600 MHz, Faster, US English"
/tmp/arduino_build_782512/sketch/TouchScreen.cpp: In constructor 'TouchScreen::TouchScreen(uint8_t, uint8_t, uint8_t, uint8_t, uint16_t)':
TouchScreen.cpp:42: error: cannot convert 'volatile uint32_t* {aka volatile long unsigned int*}' to 'RwReg* {aka volatile unsigned char*}' in assignment
xp_port = portOutputRegister(digitalPinToPort(_xp));
TouchScreen.cpp:43: error: cannot convert 'volatile uint32_t* {aka volatile long unsigned int*}' to 'RwReg* {aka volatile unsigned char*}' in assignment
yp_port = portOutputRegister(digitalPinToPort(_yp));
TouchScreen.cpp:44: error: cannot convert 'volatile uint32_t* {aka volatile long unsigned int*}' to 'RwReg* {aka volatile unsigned char*}' in assignment
xm_port = portOutputRegister(digitalPinToPort(_xm));
TouchScreen.cpp:45: error: cannot convert 'volatile uint32_t* {aka volatile long unsigned int*}' to 'RwReg* {aka volatile unsigned char*}' in assignment
ym_port = portOutputRegister(digitalPinToPort(_ym));
In file included from /home/bigguiness/Arduino/test/test.ino:12:0:
/tmp/arduino_build_782512/sketch/ILI9341_t3.h: In member function 'void ILI9341_t3::waitFifoNotFull()':
ILI9341_t3.h:345: error: 'KINETISK_SPI0' was not declared in this scope
sr = KINETISK_SPI0.SR;
/tmp/arduino_build_782512/sketch/ILI9341_t3.h: In member function 'void ILI9341_t3::waitFifoEmpty()':
ILI9341_t3.h:354: error: 'KINETISK_SPI0' was not declared in this scope
/tmp/arduino_build_782512/sketch/ILI9341_t3.h: In member function 'void ILI9341_t3::waitTransmitComplete()':
ILI9341_t3.h:362: error: 'KINETISK_SPI0' was not declared in this scope
while (!(KINETISK_SPI0.SR & SPI_SR_TCF)) ; // wait until final output done
ILI9341_t3.h:362: error: 'SPI_SR_TCF' was not declared in this scope
ILI9341_t3.h:363: error: 'KINETISK_SPI0' was not declared in this scope
tmp = KINETISK_SPI0.POPR; // drain the final RX FIFO word
/tmp/arduino_build_782512/sketch/ILI9341_t3.h: In member function 'void ILI9341_t3::waitTransmitComplete(uint32_t)':
ILI9341_t3.h:370: error: 'KINETISK_SPI0' was not declared in this scope
uint32_t sr = KINETISK_SPI0.SR;
ILI9341_t3.h:371: error: 'SPI_SR_EOQF' was not declared in this scope
if (sr & SPI_SR_EOQF) break; // wait for last transmit
ILI9341_t3.h:374: error: 'KINETISK_SPI0' was not declared in this scope
KINETISK_SPI0.SR = SPI_SR_EOQF;
ILI9341_t3.h:374: error: 'SPI_SR_EOQF' was not declared in this scope
ILI9341_t3.h:375: error: 'SPI0_MCR' was not declared in this scope
SPI0_MCR = mcr;
/tmp/arduino_build_782512/sketch/ILI9341_t3.h: In member function 'void ILI9341_t3::writecommand_cont(uint8_t)':
ILI9341_t3.h:382: error: 'KINETISK_SPI0' was not declared in this scope
KINETISK_SPI0.PUSHR = c | (_pcs_command << 16) | SPI_PUSHR_CTAS(0) | SPI_PUSHR_CONT;
ILI9341_t3.h:382: error: 'SPI_PUSHR_CTAS' was not declared in this scope
ILI9341_t3.h:382: error: 'SPI_PUSHR_CONT' was not declared in this scope
/tmp/arduino_build_782512/sketch/ILI9341_t3.h: In member function 'void ILI9341_t3::writecommand_last(uint8_t)':
ILI9341_t3.h:388: error: 'SPI0_MCR' was not declared in this scope
uint32_t mcr = SPI0_MCR;
ILI9341_t3.h:389: error: 'KINETISK_SPI0' was not declared in this scope
KINETISK_SPI0.PUSHR = c | (_pcs_command << 16) | SPI_PUSHR_CTAS(0) | SPI_PUSHR_EOQ;
ILI9341_t3.h:389: error: 'SPI_PUSHR_CTAS' was not declared in this scope
ILI9341_t3.h:389: error: 'SPI_PUSHR_EOQ' was not declared in this scope
/tmp/arduino_build_782512/sketch/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata8_cont(uint8_t)':
ILI9341_t3.h:395: error: 'KINETISK_SPI0' was not declared in this scope
KINETISK_SPI0.PUSHR = c | (_pcs_data << 16) | SPI_PUSHR_CTAS(0) | SPI_PUSHR_CONT;
ILI9341_t3.h:395: error: 'SPI_PUSHR_CTAS' was not declared in this scope
ILI9341_t3.h:395: error: 'SPI_PUSHR_CONT' was not declared in this scope
/tmp/arduino_build_782512/sketch/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata8_last(uint8_t)':
ILI9341_t3.h:401: error: 'SPI0_MCR' was not declared in this scope
ILI9341_t3.h:402: error: 'KINETISK_SPI0' was not declared in this scope
KINETISK_SPI0.PUSHR = c | (_pcs_data << 16) | SPI_PUSHR_CTAS(0) | SPI_PUSHR_EOQ;
ILI9341_t3.h:402: error: 'SPI_PUSHR_CTAS' was not declared in this scope
ILI9341_t3.h:402: error: 'SPI_PUSHR_EOQ' was not declared in this scope
/tmp/arduino_build_782512/sketch/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata16_cont(uint16_t)':
ILI9341_t3.h:408: error: 'KINETISK_SPI0' was not declared in this scope
KINETISK_SPI0.PUSHR = d | (_pcs_data << 16) | SPI_PUSHR_CTAS(1) | SPI_PUSHR_CONT;
ILI9341_t3.h:408: error: 'SPI_PUSHR_CTAS' was not declared in this scope
ILI9341_t3.h:408: error: 'SPI_PUSHR_CONT' was not declared in this scope
/tmp/arduino_build_782512/sketch/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata16_last(uint16_t)':
ILI9341_t3.h:414: error: 'SPI0_MCR' was not declared in this scope
ILI9341_t3.h:415: error: 'KINETISK_SPI0' was not declared in this scope
KINETISK_SPI0.PUSHR = d | (_pcs_data << 16) | SPI_PUSHR_CTAS(1) | SPI_PUSHR_EOQ;
ILI9341_t3.h:415: error: 'SPI_PUSHR_CTAS' was not declared in this scope
ILI9341_t3.h:415: error: 'SPI_PUSHR_EOQ' was not declared in this scope
In file included from /tmp/arduino_build_782512/sketch/ILI9341_t3.cpp:84:0:
SPI0_MCR = mcr;
/tmp/arduino_build_782512/sketch/ILI9341_t3.cpp: In member function 'uint8_t ILI9341_t3::readcommand8(uint8_t, uint8_t)':
ILI9341_t3.cpp:1358: error: 'KINETISK_SPI0' was not declared in this scope
while (((KINETISK_SPI0.SR) & (15 << 12)) && (--wTimeout)) ; // wait until empty
ILI9341_t3.cpp:1361: error: 'KINETISK_SPI0' was not declared in this scope
KINETISK_SPI0.SR = SPI_SR_TCF; // dlear it out;
ILI9341_t3.cpp:1361: error: 'SPI_SR_TCF' was not declared in this scope
ILI9341_t3.cpp:1372: error: 'SPI_PUSHR_CTAS' was not declared in this scope
KINETISK_SPI0.PUSHR = 0xD9 | (_pcs_command << 16) | SPI_PUSHR_CTAS(0) | SPI_PUSHR_CONT;
ILI9341_t3.cpp:1372: error: 'SPI_PUSHR_CONT' was not declared in this scope
/tmp/arduino_build_782512/sketch/ILI9341_t3.cpp: In member function 'uint16_t ILI9341_t3::readPixel(int16_t, int16_t)':
ILI9341_t3.cpp:1418: error: 'KINETISK_SPI0' was not declared in this scope
KINETISK_SPI0.PUSHR = 0 | (_pcs_data << 16) | SPI_PUSHR_CTAS(0)| SPI_PUSHR_CONT;
ILI9341_t3.cpp:1418: error: 'SPI_PUSHR_CTAS' was not declared in this scope
ILI9341_t3.cpp:1418: error: 'SPI_PUSHR_CONT' was not declared in this scope
ILI9341_t3.cpp:1423: error: 'SPI_PUSHR_EOQ' was not declared in this scope
KINETISK_SPI0.PUSHR = 0 | (_pcs_data << 16) | SPI_PUSHR_CTAS(0)| SPI_PUSHR_EOQ;
ILI9341_t3.cpp:1426: error: 'SPI_SR_EOQF' was not declared in this scope
while ((KINETISK_SPI0.SR & SPI_SR_EOQF) == 0) ;
ILI9341_t3.cpp:1427: error: 'SPI_SR_EOQF' was not declared in this scope
KINETISK_SPI0.SR = SPI_SR_EOQF; // make sure it is clear
/tmp/arduino_build_782512/sketch/ILI9341_t3.cpp: In member function 'void ILI9341_t3::readRect(int16_t, int16_t, int16_t, int16_t, uint16_t*)':
ILI9341_t3.cpp:1451: error: 'KINETISK_SPI0' was not declared in this scope
KINETISK_SPI0.PUSHR = 0 | (_pcs_data << 16) | SPI_PUSHR_CTAS(0)| SPI_PUSHR_CONT | SPI_PUSHR_EOQ;
ILI9341_t3.cpp:1451: error: 'SPI_PUSHR_CTAS' was not declared in this scope
ILI9341_t3.cpp:1451: error: 'SPI_PUSHR_CONT' was not declared in this scope
ILI9341_t3.cpp:1451: error: 'SPI_PUSHR_EOQ' was not declared in this scope
ILI9341_t3.cpp:1452: error: 'SPI_SR_EOQF' was not declared in this scope
ILI9341_t3.cpp:1453: error: 'SPI_SR_EOQF' was not declared in this scope
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
