Teensy 3.2 availability and repair
alexsh1
Dear all,
Unfortunately, I flied Teensy module accidently and LP38691 blown. Now it is getting hot and delivering 1.8V instead of 3.3V.
I cannot use Teensy 4.1 due to pins compatibility. Any idea where I can source Teensy 3.2 (I am based in the UK)? It is obsolete since October 2023.
I will try to repair the blown Teensy 3.2 but it will take some time as I do not have LP38691 available.
Thanks
Alex
When I connect my Teensy 3.2 to USB, I get the following readings:
VUSB = 1.8V
3.3V pin = 0.12V
I suspect this is the LDO blown. Any suggestions?
Vusb should be 5V. Did you check fuse F1?
What voltage do you measure on capacitor C7 (2.2uF)?
Paul
I'm guessing migrating to Teensy 4.0 doesn't count as a suggestion? Just keep in mind that is the long-term solution...
You could desolder the LP38691, if you have a hot air station or other appropriate equipment to desolder a SMT part with bottom side pad.
Then externally (and carefully) apply 3.3V power to the board as the LP38691 would do. If it works, then you can start shopping for a LP38691 chip. Or just continue using it with external 3.3V power.
Yes, I have to re-design the whole PCB and it would take time. This is a project started a few years ago and I was using Teensy 3.2 due to its sign and AREF availability (I am using my own precision voltage source).
So you think its the LDO at fault here? Anything else I would check?
Yes, I can desolder the LP33691, but too many small components around.
Well, that means there is a voltage drop of (5V - 1V8) 3.2V over the fuse...
Did you measure Vusb on the Vusb pad on the Teensy?
By the way, which part got hot?
Paul
Yes, the fuse is working. Otherwise, I would have 0V.
It is a PTC resistor, not a real fuse that blows. During high current, self heating causes the PTC resistance to increase, which tends to limit the current when the power source is a regulated (low impedance) voltage. Use of the word "fuse" or "self resetting" is kinda misleading marketing, but sadly an industry norm. From a purely electrical theory point of view, it's important to understand these PTC devices aren't really fuses that burn. They're just resistors that increase their resistance dramatically during over current conditions.
Paul
I measured VUSB on the VUSB pin. VUSB pin or pad, does not matter, it is the same. VIN and VUSB pads are not cut.
Paul
Yes, as soon as I short the fuse the voltage goes up to 5V
Right, yes, my bad.
Thanks for pointing out
And the LP38691 is still outputing 0.12V?
Paul
I have finally replaced the the LP38691. Nothing
When I apply 3.3V to the Teensy's pin, it goes short and slowly increasing the current I discovered that the MK20DX256VLH7 is getting hot.
I was hopping that one of the caps maybe short, but looks like the IC has been fried.
I can purchase the new IC, but than I need a bootloader I suppose?
Looks like it is easier to find a new Teensy 3.2. Sadly I cannot use Teensy 4.0
