Hello,
I'm currently designing a custom PCB for the teensy in order to create a midi controller.
I would like to use an usb-c connector instead of the usb micro. I am not a usb expert so I would be glad if someone has some answers to these questions ^^
I have been reading that the CCs pins should be pulled-down with a 5.1k resistor. That would initiate the OTG HOST mode on the other side the link (here my computer). Can you confirm that ?
Plus in the schematic the pin PTA1 from MK20 chip and the PTA6 pin from the MKL02 chip are both connected to the 4th pin of the USB-connector which is the ID pin. The latter does not exist in the USB-c. I'm not sure what to do with those pins ? Should they be connected to the ground ?
Thanks for you help !
