Teensy 3.5 - DAC questions.
Good morning. nice to meet you.
I'm curious as to how to do the DAC output.
What if I want to output DAC with coding? Thank you for your library or command.
about Teensy 3.5//
analogWriteResolution(12);
int val = function();
analogWrite(A21, (int)val);
int function(){
return ref;
Right? Is this the correct code method?
I want to get an analog value that keeps the voltage constant, not the audio output.
Is there a simple wrapper to feed the DAC using DMA? I assume this is what the audio library does internally.
Also, is there now a USB mode that lets the Teensy look like a USB audio output class device? That would be spiffy!
(While I have the wish list open: a USB audio output class device and a serial port for SerialUSB in a single composite device would be fantastic.)
And, yes, there is Serial + MIDI + Audio as an option! That is, in fact, fantastic! (And the audio design tool generates the framework of using Teensy as a USB output device, which is nice, too.)
I haven't been able to find any documentation for how to use the different USB modes, though. Is there a page I'm missing?
Like, if I choose for example the "MTP disk" USB mode, or the "Keyboard + Touch Screen" mode, is there documentation for what functions I should be using out of Teensyduino to go with these endpoints? Or do I just read the code and figure it out for myself?
Some of the features (serial, keyboard, etc) are documented in the Teensyduino libs section: https://www.pjrc.com/teensy/td_keyboard.html
MTP Disk, Touchscreen, Audio, and MIDI are not, however.
