I am starting this thread so someone can yell at me if i do something stupid
and share the results of my experiments, or should this be on the Beta Test thread?
I started looking at the SPI library and add comments from the data sheet https://github.com/alex-Arc/SPI/blob/doc/SPI.cpp
on line 166 and 167 CTAR0 and CTAR1 is defined but with frame size 7 and 15 respectively, anyone know why?
is there a good way to measure the speed of the teensy? i tried this:
on at teensy 3.5 at 24 MHz and got:
F_CPU 24000000 F_BUS 24000000
measured time: 1
measured time: 3 without measuretime: 2 singel cycle: 2.484428
that seems quite a bit of, do
not represent one cycle?
unsigned long mics = 0;
unsigned long micsDiff = 0;
Serial.printf("F_CPU %u F_BUS %u \n", F_CPU, F_BUS);
mics = micros();
//delayMicroseconds(1);
micsDiff = micros();
micsDiff -= mics;
unsigned int measureTime = micsDiff;
Serial.printf("measured time: %u \n", micsDiff);
mics = micros();
__asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t"); __asm__("nop\n\t");
micsDiff -= mics;
Serial.printf("measured time: %u without measuretime: %u singel cycle: %f*\n", micsDiff, micsDiff-measureTime, (micsDiff-measureTime)/40);
measured time: 1
__asm__("nop\n\t");
