Teensy 3.6 Custom - Serial Number
TomV
I may be missing something here, but I’m coming up against a problem. I’ve built a board based around a custom teensy 3.6 using the boot loader chip. I’d like to flash my own serial number to the MK66 in the same way Paul does with the teensy’s, for this I’ve got a J-LINK SEGGER to connect via SWD, however, without breaking the links to the bootloader IC this fails to connect, due to the state it holds the lines in I'd imagine. Does anyone know a way to achieve this?
I’ve also noticed that even on my custom one the MAC address reports back as 04:E9:E5:FF:FF:FF, so still contains the PJRC vendor ID, I was expecting it to report back as FF:FF:FF:FF:FF:FF. Is this flashed in by the bootloader IC or is there a way to change it?
Thanks.
Can you put the debug chip into reset?
Seems to me that someone else tried what you are doing and found that putting the debug chip into reset via air rest pin caused the rest of the lines to try-state.
Thanks for the reply. Thats what I've discovered since starting this thread. The RST pin of the MKL04 is now connected to pin5 of the 10-Pin ARM SWD cable, meaning that when the SWD lines are connected the Bootloader IC is held in a reset state freeing up the lines. I've also managed to code the board so I can write to the Program Once Registers via USB and the serial console when its a fresh board, which means I now no longer need to use SWD to do it.
I'm a little confused here. What are the Program Once Registers? Are these on the target MCU or the boot loader chip?
They're on the target MCU, its an area in the flash that each block can only ever be written once. PJRC stores the S/N of each Teensy in here. I wanted to achieve similar for my custom boards for holding a S/N that can be used to create a unique MAC address. Theres not much Documentation on this within the Teensy architecture, but reading the Kinetis reference manual shows where the registers are located and the specific commands needed for writing these registers.
