Hi there,
I'm trying to control 1360 pixels (170pix * 8ports) with Teensy 3.6 with one 74HC245 as level shifter; I'm using W5500 as ethernet controller, and Madrix 5 as Artnet generator.
What I already tested:
-read Artnet UDP packages (so the ethernet library https://www.arduino.cc/reference/en/libraries/ethernet/ and Artnet https://github.com/natcl/Artnet it's fine)
-controlling led with OctoWS2811 Led Library (https://www.pjrc.com/teensy/td_libs_OctoWS2811.html)
-output from Madrix 5 or grandMA2 (checked with The ArtNetominator)
Issue:
If I read from the ArtNet 1 or 2 or 3 universes, all works fine!! 170 pixels over 3 output (510 pixel total). Madrix send ArtNet in unicast at 33.3 FPS, optimized frame.
When I try to read 4 universes, all goes wrong... the led update randomly every 10sec (more or less), even if I use 1 FPS in Madrix.
To ensure that Teensy receive all universes, I added a line to print every number of universe that teensy read from artnet... and I found that I can read only the first 3 universes of the total amount that I'm sending to it. When I change "startUniverse", I just move the problem further on...
I mean, startUniverse=0 read universes 0-1-2, startUniverse=1 read universes 1-2-3, startUniverse=10 read universes 10-11-12... not one more...
Does anyone as got an idea or test to run?
This is the basic example from OctoWs2811 library that I'm using:
Thank you all!
(Sorry for my not fluent English, I'm working on it!
Issue:
C++:
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <Artnet.h>
#include <OctoWS2811.h>
// OctoWS2811 settings
const int ledsPerStrip = 170;
const byte numStrips= 3;
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
const int config = WS2811_GRB | WS2811_800kHz;
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
// Artnet settings
Artnet artnet;
const int startUniverse = 0;
const int numberOfChannels = ledsPerStrip * numStrips * 3;
byte channelBuffer[numberOfChannels]; // Combined universes into a single array
// Check if we got all universes
const int maxUniverses = numberOfChannels / 512 + ((numberOfChannels % 512) ? 1 : 0);
bool universesReceived[maxUniverses];
bool sendFrame = 1;
// Change ip and mac address for your setup
byte ip[] = {2, 0, 0, 201};
byte mac[] = {0x04, 0xE9, 0xE5, 0x00, 0x69, 0xEC};
artnet.begin(mac, ip);
leds.begin();
initTest();
artnet.setArtDmxCallback(onDmxFrame);
artnet.read();
void onDmxFrame(uint16_t universe, uint16_t length, uint8_t sequence, uint8_t* data) {
sendFrame = 1;
//Serial.print("universe:");
//Serial.println(universe, DEC);
// Store which universe has got in
if (universe < maxUniverses) {
universesReceived[universe] = 1;
for (int i = 0 ; i < maxUniverses ; i++) {
if (universesReceived[i] == 0) {
sendFrame = 0;
// read universe and put into the right part of the display buffer
for (int i = 0 ; i < 510 ; i++) {
int bufferIndex = i + ((universe - startUniverse) * 510);
if (bufferIndex < numberOfChannels) // to verify
channelBuffer[bufferIndex] = byte(data[i]);
// send to leds
for (int i = 0; i < ledsPerStrip * numStrips; i++) {
leds.setPixel(i, channelBuffer[(i) * 3], channelBuffer[(i * 3) + 1], channelBuffer[(i * 3) + 2]);
if (sendFrame) {
leds.show();
memset(universesReceived, 0, maxUniverses);
void initTest()
for (int i = 0 ; i < ledsPerStrip * numStrips ; i++)
leds.setPixel(i, 127, 0, 0);
leds.show();
delay(200);
leds.setPixel(i, 0, 127, 0);
leds.show();
delay(200);
leds.setPixel(i, 0, 0, 127);
leds.show();
delay(200);
leds.setPixel(i, 0, 0, 0);
leds.show();
Thank you all!
