I've uploaded the code (as example) here:
https://github.com/FrankBoesing/ILI9341_t3DMA
It still need some work to make it better, but it works.
I've the uploaded pre-processed example-video here:
https://drive.google.com/drive/folders/0Bx2Jw84lqebkelF3MHg2eWVzb0U
So you can use this file without needing to convert it.
You need a) ffmpeg to create the audiofile, and b) Processing to create the videofile.
To create the audio-part, use this command:
ffmpeg -i "BigBuckBunny_512kb.mp4" -f s16le -ar 44100 -acodec pcm_s16le output.raw
ffmpeg is available for windows, too. Apple ? Don't know. Linux ? Yes, of course.
The Sketch works best with max-overclocked F_BUS (i.e. for 72MHz SPI with 144MHz F_CPU) - but still works without that (flickers a bit).
The example uses the Teensy - DAC for Audio, i did not try I2S.
Edit: almost forgotten.. you need the beta of SDFAT by Bill. It will NOT work with the audio-library, so perhaps make a copy of the Arduino-installation and delete the two conflicting audio-objects and references to sd.h
Sorry, it will be better when a "official" sd.h is available. Now, it is kind of hack..
Or, more simple, delete the audio-part from the sketch - you will have no audio but the video still works.
