The pixel-flickering went away when I switched back to "auto" setting.
Seems, that I don't need extra hardware... it's already good enough![]()
With 10 resistors to solder to pins and joins - plus the way I did GND (common across GNDs on middle offset row to pin 5 with 30 ga wire - then trimmed middle row pins to mount on PCB) - lots of room for errors on my end, or it could be low V on the sync lines with the 100E's?
I'll go to a CRT and try . . .
{edit} Found two CRT's - No luck - one does self test and told me "check my PC" . . .
qix67 - what compile options for the github code? 240 or 180 MHz?
Perhaps a multi-meter will tell me how my connections are . . .
Don't you have any problem to clear screen fast enough between frame ?
I plan to add a function to automatically clear screen using DMA at start of Vsync. DMA has a 16 bytes write which can clear screen very fast while CPU does something else and during Vsync, a 2nd DMA channel does not disturb pixel DMA channel.
On two displays connecting VGA:
>C64 code woke monitor - then it found 'Analog No Signal'
>Drawing test also got 'No Signal' but it didn't seem to wake it?
2 quick questions:
Should I include this library with Teensyduino 1.40?
Can someone post a video, showing the hardware used and results running on a monitor? Looking for something showing how it works, not just a close-up of the screen only.
I can see one potential problem with your change. To work properly, DMA channel must be <=15 (see uVGA.cpp line 213) because any other DMA channels belong to what seems to work like a 2nd DMA controller and have a lower priority in case of DMA conflict.
In your code, where are dmachan{1,2,3} declared ? I find them nowhere in teensyduino code.
I fear that the USB-HOST will show the same... i have no idea how to avoid that... and I really need that. No Chance without.
https://github.com/qix67/uVGA/pull/4/commits/c62906b8c8d67aa06f4bcb6d09ca5222455b173d
And yes, only the fist 15 channels are used. So, no problem.
But a problem is the malloc.. esp the first, for the lower sram - I used DMAMEM to make sure that it is at the beginning of RAM (DMAMEM uses a section at the beginning of SRAM_L). Can you support that somehow ? (Best would be to remove that malloc completely.. together with the fixed DMA Channels..but I understand, that dynamic modelines are not possible without that. Who cares ;-) I can't image a situation where a app need to change the resolution - would be no problem to make it at compile-time, not runtime.. with that malloc, it's not possible to use mores than 64K for variables...
One more thing to check: Is the use of your timer compatible to other libs ?
Last wish: move the frame_buffer from private to public.
A minor observation: Serial.print results in pixel-flicker - not only when printing. It's enough to open the Arduino Serial Monitor. The Pixels keep flickering in this case. Ok, not so important in my case.. but nice to know.
Yes. Flickering. :-(
Can you post the schematics for the additional hardware ? I want to make/order testboards..
Multimeter just pointed out that indeed I improperly translated top and bottom rows as presented and soldered on the PCB
Looking at the face I saw it properly - the but when upside down and faced away I treated the true bottom row as the top. So I get to do it again.
#defines would help (?!)Changing the resolution no but using the same library between different projects not using the same resolution.
I really understand your problem. This morning, when upgrading my domotic circuit, I noticed I inverted the wires of all RJ45 connectors which permute 3.3V and GND signalsI still wonder how all components still work.
USB-HOST : Causes flickering.
