Hi all, I'm adapting an old code from Teensy 3.2 + audio board B to Teensy 4 and Audio board D. Before modifying the pins for the new board, I tried to run a SD card test and keep on having the message "SD card is not connected or unusable :-(". At the beginning I found the multiple library issue, which I think I solved by moving the duplicated libraries from Documents/Arduino/ Library folder but still the problem persists. Here what I get from my verbose output:
/Applications/Teensyduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Teensyduino.app/Contents/Java/hardware -tools /Applications/Teensyduino.app/Contents/Java/tools-builder -tools /Applications/Teensyduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Teensyduino.app/Contents/Java/libraries -libraries /Users/patriciareis/pCloud Drive/_ARTIST_WORK/_2025/Node/CODE/libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10819 -build-path /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767 -warnings=default -build-cache /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_cache_770860 -prefs=runtime.tools.teensy-compile.path=/Users/patriciareis/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1 -prefs=runtime.tools.teensy-compile-11.3.1.path=/Users/patriciareis/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1 -prefs=runtime.tools.teensy-tools.path=/Users/patriciareis/Library/Arduino15/packages/teensy/tools/teensy-tools/1.59.0 -prefs=runtime.tools.teensy-tools-1.59.0.path=/Users/patriciareis/Library/Arduino15/packages/teensy/tools/teensy-tools/1.59.0 -verbose /Users/patriciareis/pCloud Drive/_ARTIST_WORK/_2025/Node/CODE/massage_chair_Code/test_sd_card/test_sd_card.ino
/Applications/Teensyduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Teensyduino.app/Contents/Java/hardware -tools /Applications/Teensyduino.app/Contents/Java/tools-builder -tools /Applications/Teensyduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Teensyduino.app/Contents/Java/libraries -libraries /Users/patriciareis/pCloud Drive/_ARTIST_WORK/_2025/Node/CODE/libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10819 -build-path /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767 -warnings=default -build-cache /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_cache_770860 -prefs=runtime.tools.teensy-compile.path=/Users/patriciareis/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1 -prefs=runtime.tools.teensy-compile-11.3.1.path=/Users/patriciareis/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1 -prefs=runtime.tools.teensy-tools.path=/Users/patriciareis/Library/Arduino15/packages/teensy/tools/teensy-tools/1.59.0 -prefs=runtime.tools.teensy-tools-1.59.0.path=/Users/patriciareis/Library/Arduino15/packages/teensy/tools/teensy-tools/1.59.0 -verbose /Users/patriciareis/pCloud Drive/_ARTIST_WORK/_2025/Node/CODE/massage_chair_Code/test_sd_card/test_sd_card.ino
Using board 'teensy40' from platform in folder: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr
Using core 'teensy4' from platform in folder: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr
Detecting libraries used...
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/sketch/test_sd_card.ino.cpp -o /dev/null
Alternatives for SD.h: [SD@1.2.4 SD@2.0.0]
ResolveLibrary(SD.h)
-> candidates: [SD@1.2.4 SD@2.0.0]
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/src /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/sketch/test_sd_card.ino.cpp -o /dev/null
Alternatives for SdFat.h: [SdFat@2.1.2]
ResolveLibrary(SdFat.h)
-> candidates: [SdFat@2.1.2]
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/src -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/sketch/test_sd_card.ino.cpp -o /dev/null
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/src -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/sketch/test_sd_card.ino.cpp -o /dev/null
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/src/SD.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/ExFatLib/ExFatDbg.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/ExFatLib/ExFatFile.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/ExFatLib/ExFatFilePrint.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/ExFatLib/ExFatFileWrite.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/ExFatLib/ExFatFormatter.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/ExFatLib/ExFatName.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/ExFatLib/ExFatPartition.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/ExFatLib/ExFatVolume.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/ExFatLib/upcase.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/FatLib/FatDbg.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/FatLib/FatFile.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/FatLib/FatFileLFN.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/FatLib/FatFilePrint.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/FatLib/FatFileSFN.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/FatLib/FatFormatter.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/FatLib/FatName.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/FatLib/FatPartition.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/FatLib/FatVolume.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/FreeStack.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/FsLib/FsFile.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/FsLib/FsNew.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/FsLib/FsVolume.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/MinimumSerial.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/SdCard/SdCardInfo.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/SdCard/SdSpiCard.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/SdCard/SdioTeensy.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/SpiDriver/SdSpiArtemis.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/SpiDriver/SdSpiChipSelect.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/SpiDriver/SdSpiDue.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/SpiDriver/SdSpiESP.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/SpiDriver/SdSpiParticle.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/SpiDriver/SdSpiSTM32.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/SpiDriver/SdSpiSTM32Core.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/SpiDriver/SdSpiTeensy3.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/common/FmtNumber.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/common/FsCache.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/common/FsDateTime.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/common/FsName.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/common/FsStructs.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/common/FsUtf.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/common/PrintBasic.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/common/upcase.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/iostream/StdioStream.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/iostream/StreamBaseClass.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/iostream/istream.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src/iostream/ostream.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI/SPI.cpp
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/src -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/sketch/test_sd_card.ino.cpp -o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Teensyduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/precompile_helper /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767 /Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/pch/Arduino.h -o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/pch/Arduino.h.gch
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/pch/Arduino.h.gch
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=158 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/pch -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/src -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat/src -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/sketch/test_sd_card.ino.cpp -o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/sketch/test_sd_card.ino.cpp.o
Compiling libraries...
Compiling library "SD"
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SD/SD.cpp.o
Compiling library "SdFat"
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FreeStack.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/MinimumSerial.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatVolume.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatPartition.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatName.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatFile.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatFilePrint.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatDbg.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatFormatter.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/upcase.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatFileWrite.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatFileSFN.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatPartition.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatFilePrint.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatDbg.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatFormatter.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatFile.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatFileLFN.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatName.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatVolume.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FsLib/FsNew.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FsLib/FsFile.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FsLib/FsVolume.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SdCard/SdCardInfo.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SdCard/SdSpiCard.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SdCard/SdioTeensy.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiDue.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiParticle.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiChipSelect.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiSTM32.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiArtemis.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiTeensy3.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiESP.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiSTM32Core.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/upcase.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/FmtNumber.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/FsUtf.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/FsDateTime.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/FsCache.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/PrintBasic.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/FsStructs.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/FsName.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/iostream/StreamBaseClass.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/iostream/StdioStream.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/iostream/istream.cpp.o
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/iostream/ostream.cpp.o
Compiling library "SPI"
Using previously compiled file: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SPI/SPI.cpp.o
Compiling core...
Using precompiled core: /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_cache_770860/core/core_fc57fc92e7726a6589d7ab7730fbf489.a
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc -O2 -Wl,--gc-sections,--relax -T/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/imxrt1062.ld -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/test_sd_card.ino.elf /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/sketch/test_sd_card.ino.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SD/SD.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FreeStack.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/MinimumSerial.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatDbg.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatFile.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatFilePrint.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatFileWrite.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatFormatter.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatName.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatPartition.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/ExFatVolume.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/ExFatLib/upcase.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatDbg.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatFile.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatFileLFN.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatFilePrint.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatFileSFN.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatFormatter.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatName.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatPartition.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FatLib/FatVolume.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FsLib/FsFile.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FsLib/FsNew.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/FsLib/FsVolume.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SdCard/SdCardInfo.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SdCard/SdSpiCard.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SdCard/SdioTeensy.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiArtemis.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiChipSelect.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiDue.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiESP.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiParticle.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiSTM32.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiSTM32Core.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/SpiDriver/SdSpiTeensy3.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/FmtNumber.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/FsCache.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/FsDateTime.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/FsName.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/FsStructs.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/FsUtf.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/PrintBasic.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/common/upcase.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/iostream/StdioStream.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/iostream/StreamBaseClass.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/iostream/istream.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SdFat/iostream/ostream.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/libraries/SPI/SPI.cpp.o /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/../arduino_cache_770860/core/core_fc57fc92e7726a6589d7ab7730fbf489.a -L/var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767 -larm_cortexM7lfsp_math -lm -lstdc++
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/test_sd_card.ino.elf /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/test_sd_card.ino.eep
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy -O ihex -R .eeprom /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/test_sd_card.ino.elf /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/test_sd_card.ino.hex
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/teensy_secure encrypthex TEENSY40 /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/test_sd_card.ino.hex
No key .pem file found, skipping .ehex encryption
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/teensy_post_compile -file=test_sd_card.ino -path=/var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767 -tools=/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/ -board=TEENSY40
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/stdout_redirect /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/test_sd_card.ino.sym /Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objdump -t -C /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/test_sd_card.ino.elf
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/teensy_size /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/test_sd_card.ino.elf
Memory Usage on Teensy 4.0:
FLASH: code:54636, data:7116, headers:8900 free for files:1960964
RAM1: variables:9888, code:52904, padding:12632 free for local variables:448864
RAM2: variables:12416 free for malloc/new:511872
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/stdout_redirect /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/test_sd_card.ino.lst /Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objdump -d -S -C /var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767/test_sd_card.ino.elf
Multiple libraries were found for "SD.h"
Used: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD
Not used: /Applications/Teensyduino.app/Contents/Java/libraries/SD
Using library SD at version 2.0.0 in folder: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD
Using library SdFat at version 2.1.2 in folder: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SdFat
Using library SPI at version 1.0 in folder: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI
/Users/patriciareis/Library/Arduino15/packages/teensy/tools/teensy-tools/1.59.0/teensy_post_compile -file=test_sd_card.ino -path=/var/folders/z2/c9b92rzj1437tk06dwtnj8sw0000gn/T/arduino_build_678767 -tools=/Users/patriciareis/Library/Arduino15/packages/teensy/tools/teensy-tools/1.59.0 -board=TEENSY40 -reboot -port=usb:130000 -portlabel=HID=16c0:0478.ff9c.24 Bootloader -portprotocol=Teensy
Here the code:
Hardware details: brand new teensy 4 and Audio board rev D + brand new SD card Scan Disk 128GB A2 (I also tested with other cards)
Was also wondering which pins need to be changed to adapt my old code with Teensy 3.2 and Audio board B to the new set teensy 4 and Audio board rev D?
Thanks
Pat
Compiling sketch...
Compiling core...
Here the code:
// SD Card Test
// Check if the SD card on the Audio Shield is working,
// and perform some simple speed measurements to gauge
// its ability to play 1, 2, 3 and 4 WAV files at a time.
// Requires the audio shield:
// http://www.pjrc.com/store/teensy3_audio.html
// Data files to put on your SD card can be downloaded here:
// http://www.pjrc.com/teensy/td_libs_AudioDataFiles.html
// This example code is in the public domain.
// Use these with the Teensy Audio Shield
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 11 // Teensy 4 ignores this, uses pin 11
#define SDCARD_SCK_PIN 13 // Teensy 4 ignores this, uses pin 13
// Use these with the Teensy 3.5 & 3.6 & 4.1 SD card
//#define SDCARD_CS_PIN BUILTIN_SDCARD
//#define SDCARD_MOSI_PIN 11 // not actually used
//#define SDCARD_SCK_PIN 13 // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN 4
Sd2Card card;
SdVolume volume;
File f1, f2, f3, f4;
char buffer[512];
boolean status;
unsigned long usec, usecMax;
elapsedMicros usecTotal, usecSingle;
int i, type;
float size;
// wait for the Arduino Serial Monitor to open
while (!Serial) ;
delay(50);
// Configure SPI
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
Serial.println("SD Card Test");
Serial.println("------------");
// First, detect the card
status = card.init(SPI_FULL_SPEED, SDCARD_CS_PIN);
if (status) {
Serial.println("SD card is connected :-)");
Serial.println("SD card is not connected or unusable :-(");
return;
type = card.type();
if (type == SD_CARD_TYPE_SD1 || type == SD_CARD_TYPE_SD2) {
Serial.println("Card type is SD");
} else if (type == SD_CARD_TYPE_SDHC) {
Serial.println("Card type is SDHC");
Serial.println("Card is an unknown type (maybe SDXC?)");
// Then look at the file system and print its capacity
status = volume.init(card);
if (!status) {
Serial.println("Unable to access the filesystem on this card. :-(");
return;
size = volume.blocksPerCluster() * volume.clusterCount();
size = size * (512.0 / 1e6); // convert blocks to millions of bytes
Serial.print("File system space is ");
Serial.print(size);
Serial.println(" Mbytes.");
// Now open the SD card normally
status = SD.begin(SDCARD_CS_PIN);
if (status) {
Serial.println("SD library is able to access the filesystem");
Serial.println("SD library can not access the filesystem!");
Serial.println("Please report this problem, with the make & model of your SD card.");
Serial.println(" http://forum.pjrc.com/forums/4-Suggestions-amp-Bug-Reports");
// Open the 4 sample files. Hopefully they're on the card
f1 = SD.open("001.WAV");
f2 = SD.open("002.WAV");
f3 = SD.open("003.WAV");
f4 = SD.open("004.WAV");
// Speed test reading a single file
if (f1) {
Serial.println("Reading SDTEST1.WAV:");
if (f1.size() >= 514048) {
usecMax = 0;
usecTotal = 0;
for (i=0; i < 1000; i++) {
usecSingle = 0;
f1.read(buffer, 512);
usec = usecSingle;
if (usec > usecMax) usecMax = usec;
reportSpeed(1, 1000, usecTotal, usecMax);
Serial.println("SDTEST1.WAV is too small for speed testing");
Serial.println("Unable to find SDTEST1.WAV on this card");
return;
// Speed test reading two files
if (f2) {
Serial.println("Reading SDTEST1.WAV & SDTEST2.WAV:");
if (f2.size() >= 514048) {
f1.seek(0);
usecMax = 0;
usecTotal = 0;
usecSingle = 0;
f2.read(buffer, 512);
usec = usecSingle;
reportSpeed(2, 1000, usecTotal, usecMax);
Serial.println("Reading SDTEST1.WAV & SDTEST2.WAV staggered:");
f1.seek(0);
f2.seek(0);
usecMax = 0;
usecTotal = 0;
usecSingle = 0;
usec = usecSingle;
Serial.println("SDTEST2.WAV is too small for speed testing");
Serial.println("Unable to find SDTEST2.WAV on this card");
return;
// Speed test reading three files
if (f3) {
Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV:");
if (f3.size() >= 514048) {
f1.seek(0);
f2.seek(0);
usecMax = 0;
usecTotal = 0;
usecSingle = 0;
f3.read(buffer, 512);
usec = usecSingle;
reportSpeed(3, 1000, usecTotal, usecMax);
Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV staggered:");
f1.seek(0);
f2.seek(0);
f3.seek(0);
usecMax = 0;
usecTotal = 0;
usecSingle = 0;
usec = usecSingle;
Serial.println("SDTEST3.WAV is too small for speed testing");
Serial.println("Unable to find SDTEST3.WAV on this card");
return;
// Speed test reading four files
if (f4) {
Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV, SDTEST4.WAV:");
if (f4.size() >= 514048) {
f1.seek(0);
f2.seek(0);
f3.seek(0);
usecMax = 0;
usecTotal = 0;
usecSingle = 0;
f4.read(buffer, 512);
usec = usecSingle;
reportSpeed(4, 1000, usecTotal, usecMax);
Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV, SDTEST4.WAV staggered:");
f1.seek(0);
f2.seek(0);
f3.seek(0);
f4.seek(0);
usecMax = 0;
usecTotal = 0;
usecSingle = 0;
usec = usecSingle;
Serial.println("SDTEST4.WAV is too small for speed testing");
Serial.println("Unable to find SDTEST4.WAV on this card");
return;
unsigned long maximum(unsigned long a, unsigned long b,
unsigned long c, unsigned long d)
if (b > a) a = b;
if (c > a) a = c;
if (d > a) a = d;
return a;
void reportSpeed(unsigned int numFiles, unsigned long blockCount, unsigned long usecTotal, unsigned long usecMax)
float bytesPerSecond = (float)(blockCount * 512 * numFiles) / usecTotal;
Serial.print(" Overall speed = ");
Serial.print(bytesPerSecond);
Serial.println(" Mbyte/sec");
Serial.print(" Worst block time = ");
Serial.print((float)usecMax / 1000.0);
Serial.println(" ms");
Serial.print(" ");
Serial.print( (float)usecMax / 29.01333);
Serial.println("% of audio frame time");
void loop(void) {
// do nothing after the test
Thanks
Pat
