FIFO Disabled
Mailboxes:
MB0 code: RX_EMPTY (Standard Frame)
MB1 code: RX_EMPTY (Standard Frame)
MB2 code: RX_EMPTY (Standard Frame)
MB3 code: RX_EMPTY (Extended Frame)
MB4 code: RX_EMPTY (Extended Frame)
MB5 code: RX_EMPTY (Extended Frame)
MB6 code: RX_EMPTY (Extended Frame)
MB7 code: TX_INACTIVE
MB8 code: TX_INACTIVE
MB9 code: TX_INACTIVE
MB10 code: TX_INACTIVE
MB11 code: TX_INACTIVE
MB12 code: TX_INACTIVE
MB13 code: TX_INACTIVE
MB: 0 ID: 0x321 EXT: 0 LEN: 8 DATA: 1 2 3 4 5 6 7 8 TS: 26722
MB: 1 ID: 0x321 EXT: 0 LEN: 8 DATA: 1 2 3 4 5 6 7 8 TS: 26864
MB: 2 ID: 0x321 EXT: 0 LEN: 8 DATA: 1 2 3 4 5 6 7 8 TS: 6138
MB: 0 ID: 0x321 EXT: 0 LEN: 8 DATA: 1 2 3 4 5 6 7 8 TS: 25427
MB: 0 ID: 0x321 EXT: 0 LEN: 8 DATA: 1 2 3 4 5 6 7 8 TS: 10014
MB: 0 ID: 0x321 EXT: 0 LEN: 8 DATA: 1 2 3 4 5 6 7 8 TS: 60137
MB: 0 ID: 0x321 EXT: 0 LEN: 8 DATA: 1 2 3 4 5 6 7 8 TS: 44724
MB: 0 ID: 0x321 EXT: 0 LEN: 8 DATA: 1 2 3 4 5 6 7 8 TS: 29311
MB: 0 ID: 0x321 EXT: 0 LEN: 8 DATA: 1 2 3 4 5 6 7 8 TS: 13898
MB: 0 ID: 0x321 EXT: 0 LEN: 8 DATA: 1 2 3 4 5 6 7 8 TS: 64021
MB: 0 ID: 0x321 EXT: 0 LEN: 8 DATA: 1 2 3 4 5 6 7 8 TS: 48608
MB: 0 ID: 0x321 EXT: 0 LEN: 8 DATA: 1 2 3 4 5 6 7 8 TS: 33195
MB: 0 ID: 0x321 EXT: 0 LEN: 8 DATA: 1 2 3 4 5 6 7 8 TS: 17782
loglow can you send me a second socket kit for the other set?
@loglow - if I'm seeing this right: View attachment 17144
The one end hits the SDIO pads on the T4 and passes over the USB Host D+/D- and those pads are all soldered through the holes taking the signals to the far end for offboard use? That looks very cool if it works for a 50 cent flex part!
Boy, I'd love to find where you can get those flex boards done for 50 cents each. I just priced a bunch (okay, slightly larger) and they were $25 each.
@loglow - Cannot wait for the launch of this. I will order a fully assembled unit with all the fixin's. Thanks for all yours and the others hard work at getting this done
I had no problems with your T3.6 breakout board and I am still using it.
Warren
So, I think with USB, SD, and CAN all confirmed good, I'm about ready to pull the trigger on the first batch of kits.
Any last-minute thoughts or feedback?
Put the order information on your website![]()
@KurtE
check this post: https://forum.pjrc.com/threads/57122-Teensy-4-0-Breakout-Kit?p=214931&viewfull=1#post214931. Has link for low profile connectors from peconnectors.com
If possible, include an extra screw or 2. I seem to be prone to tiny screws falling on the ground and not being able to find them again. Fortunately, I had some plastic M2 screws that I could use.
@KurtE
PULLDOWN :: TEST to 3.3V << USB Send Enter to Toggle Up/Down Test
d#=31 val=1
d#=30 val=1,
d#=6 val=1,d#=31 val=0,>>> MULTI CHANGE !!
>>> MULTI CHANGE !!
>> Temp during Hi_Lo test was low and good.
>> POWER button : Good
>> Power switch : Good
---- ...\SD\examples\CardInfo\CardInfo.ino
Initializing SD card...Wiring is correct and a card is present.
Card type: SDHC
Volume type is FAT32
---- USBHost Mouse works : a wireless dongle MSFT mouse
