manitou
Senior Member+
Thanks! looks good.I've committed a fix for the eeprom problems after a cold boot.
I'll second what everyone else has said. That looks like it fixed it. Ran 2 tests:I've committed a fix for the eeprom problems after a cold boot.
Calibration Data
Magnetic (Hard Iron) Offsets
17.22 uT
-8.51 uT
64.54 uT
Magnetic Soft Iron Mapping
0.9758 -0.0193 -0.0073
-0.0193 0.9986 -0.0025
-0.0073 -0.0025 1.0267
Expected Magnetic Field Strength
40.01 uT
Calibration Data
17.22 uT
-8.51 uT
64.55 uT
0.9756 -0.0192 -0.0077
-0.0192 0.9985 -0.0026
-0.0077 -0.0026 1.0270
40.01 uT
https://github.com/PaulStoffregen/cores/commit/710f215feec990f15026278be1a2d634ee29c450
The bootloader does indeed fully initialize the FlexSPI LUT memory. Even if a LUT contains a stop instruction, turns out the hardware gets upset if any of LUT's the 8 instructions are invalid, even after a stop. I didn't realize this until now (kind of assumed it didn't read anything after the stop instruction - NXP's manual doesn't really say either way but kind of implied it reads the LUT's instructions in order), so the code was depending on the bootloader leaving the LUTs in a "clean" state. These extra initialization writes should fully solve the problem where the LUT table has unknown garbage after a cold boot.
If the instruction number needed is less than 8 for a flash
transaction, STOP instruction should be programmed for the
unneeded instructions (instruction code 8'h00).
CCM_CCGR6: fcff3fc3 CCM_CCGR7: ffffffff
byte 0 98
FLEXSPI MCR0:ffff8010 MCR1:7736ffff MCR2:200001f7 AHBCR:78 INTEN:0 INTR:40 RFDR0:77f2db4a
LUT60:64bf3240 LUT61:d292adcc LUT62:16f89264 LUT63:865f453b
FLEXSPI MCR0:ffff8010 MCR1:7736ffff MCR2:200001f7 AHBCR:78 INTEN:0 INTR:40 RFDR0:44
LUT60:24010405 LUT61:0 LUT62:0 LUT63:0
input 99 byte 0 99
EEPROM length: 1080
Contents:
0:63 1:1 2:2 3:3 4:4 5:5 6:6 7:7 8:8 9:9 a:a b:b c:c d:d e:e f:f
10:10 11:11 12:12 13:13 14:14 15:15 16:16 17:17 18:18 19:19 1a:1a 1b:1b 1c:1c 1d:1d 1e:1e 1f:1f
20:20 21:21 22:22 23:23 24:24 25:25 26:26 27:27 28:28 29:29 2a:2a 2b:2b 2c:2c 2d:2d 2e:2e 2f:2f
30:30 31:31 32:32 33:33 34:34 35:35 36:36 37:37 38:38 39:39 3a:3a 3b:3b 3c:3c 3d:3d 3e:3e 3f:3f
40:40 41:41 42:42 43:43 44:44 45:45 46:46 47:47 48:48 49:49 4a:4a 4b:4b 4c:4c 4d:4d 4e:4e 4f:4f
50:50 51:51 52:52 53:53 54:54 55:55 56:56 57:57 58:58 59:59 5a:5a 5b:5b 5c:5c 5d:5d 5e:5e 5f:5f
60:60 61:61 62:62 63:63 64:64 65:65 66:66 67:67 68:68 69:69 6a:6a 6b:6b 6c:6c 6d:6d 6e:6e 6f:6f
70:70 71:71 72:72 73:73 74:74 75:75 76:76 77:77 78:78 79:79 7a:7a 7b:7b 7c:7c 7d:7d 7e:7e 7f:7f
80:80 81:81 82:82 83:83 84:84 85:85 86:86 87:87 88:88 89:89 8a:8a 8b:8b 8c:8c 8d:8d 8e:8e 8f:8f
90:90 91:91 92:92 93:93 94:94 95:95 96:96 97:97 98:98 99:99 9a:9a 9b:9b 9c:9c 9d:9d 9e:9e 9f:9f
a0:a0 a1:a1 a2:a2 a3:a3 a4:a4 a5:a5 a6:a6 a7:a7 a8:a8 a9:a9 aa:aa ab:ab ac:ac ad:ad ae:ae af:af
b0:b0 b1:b1 b2:b2 b3:b3 b4:b4 b5:b5 b6:b6 b7:b7 b8:b8 b9:b9 ba:ba bb:bb bc:bc bd:bd be:be bf:bf
c0:c0 c1:c1 c2:c2 c3:c3 c4:c4 c5:c5 c6:c6 c7:c7 c8:c8 c9:c9 ca:ca cb:cb cc:cc cd:cd ce:ce cf:cf
d0:d0 d1:d1 d2:d2 d3:d3 d4:d4 d5:d5 d6:d6 d7:d7 d8:d8 d9:d9 da:da db:db dc:dc dd:dd de:de df:df
e0:e0 e1:e1 e2:e2 e3:e3 e4:e4 e5:e5 e6:e6 e7:e7 e8:e8 e9:e9 ea:ea eb:eb ec:ec ed:ed ee:ee ef:ef
f0:f0 f1:f1 f2:f2 f3:f3 f4:f4 f5:f5 f6:f6 f7:f7 f8:f8 f9:f9 fa:fa fb:fb fc:fc fd:fd fe:fe ff:ff
Raw Data
EEprom Page:0 addresses(601f0000 - 601f1000): first free: 601f008a
000(00)=08 001(01)=09 002(02)=0a 003(03)=0b 060(04)=44 061(05)=45 062(06)=46 063(07)=47 120(08)=80 121(09)=81 122(0a)=82 123(0b)=83 180(0c)=bc 181(0d)=bd 182(0e)=be 183(0f)=bf
240(10)=f8 241(11)=f9 242(12)=fa 243(13)=fa *300(14)=b3 *301(15)=b3 *302(16)=b3 *303(17)=b3 243(13)=fb 000(00)=78 000(00)=0d 000(00)=79 000(00)=0d 000(00)=00 *001(01)=01 *002(02)=02
*003(03)=03 *060(04)=3c *061(05)=3d *062(06)=3e *063(07)=3f *120(08)=78 *121(09)=79 *122(0a)=7a *123(0b)=7b *180(0c)=b4 *181(0d)=b5 *182(0e)=b6 *183(0f)=b7 *240(10)=f0 *241(11)=f1 *242(12)=f2
*243(13)=f3 000(00)=78 000(00)=0d 000(00)=78 000(00)=0d 000(00)=78 000(00)=59 000(00)=31 000(00)=32 000(00)=35 000(00)=31 000(00)=32 000(00)=37 000(00)=38 000(00)=31 000(00)=61
000(00)=63 000(00)=31 000(00)=61 000(00)=62 *000(00)=63
uint8_t eeprom_read_byte(const uint8_t *addr_ptr)
uint32_t addr = (uint32_t)addr_ptr;
uint32_t sector, offset;
const uint16_t *p, *end;
uint8_t data=0xFF;
if (addr > E2END) return 0xFF;
if (!initialized) eeprom_initialize();
sector = (addr >> 2) % FLASH_SECTORS;
offset = (addr & 3) | (((addr >> 2) / FLASH_SECTORS) << 2);
//printf("ee_rd, addr=%u, sector=%u, offset=%u, len=%u\n",
//addr, sector, offset, sector_index[sector]);
p = (uint16_t *)(FLASH_BASEADDR + sector * 4096);
end = p + sector_index[sector];
while (p < end) {
uint32_t val = *p++;
if ((val & 255) == offset) data = val >> 8;
return data;
const uint16_t *p, *begin;
begin= (uint16_t *)(FLASH_BASEADDR + sector * 4096);
p = begin + sector_index[sector] -1;
while (p >= begin) {
uint32_t val = *p--;
if ((val & 255) == offset) return val >> 8;
return 0xff;
SPI.setMOSI(35);
SPI.setSCK(37);
SPI.setSCK(34);
Change drive
A_00001.dat
stat FR_OK 0
opened FR_OK 0
.................................... (3010996 - [B]10.882777 MB/s[/B])
(open: 9016 us; close: 8979 us; write: min,max: 2977 3979 us)
Just got my shiny new Breakout board and new T4 (now calling it T4B2B - last B is for Battery Holder).
Battery holder is on the breakout though … I was calling it Ribbon due to the SD pin spacing change ...
I wondered about a new indicator - but so far the T4 on the newest board - with the Ribbon still has White Wire edit and only the SD ribbon pin spacing was the noted intended change so T4B2m? {or T4B2r if it shows any diffs}
Anyhow it is a really nice looking package - and indeed PCB washed nice and clean on nice base!
Anyone lurking here on the Beta list if you have time to practice some 'Normal Use' - or following the Msg#4 and #6 status/issues list - it would be a good time to send an email if not too late and 'Get Some' - and have a chance to see it early and maybe come across something otherwise unfound that would be a bother later.
In that case I will call it T4B2R = for ribbonHate to just use wire.
I actually meant to add to my post that the quality of workmanship and attention to details on the products that PJRC puts out, example the breakout boards, not to mention the Teensies never ceases to amaze me.
Initializing SD card...initialization done.
Stops - nothing write
Initializing SD card...card initialized.
SdFat version: 1.0.5
Assuming the SD is the only SPI device.
Edit DISABLE_CHIP_SELECT to disable another device.
Assuming the SD chip select pin is: 10
Edit SD_CHIP_SELECT to change the SD chip select pin.
type any character to start
init time: 2 ms
Card type: SDXC
Manufacturer ID: 0X95
OEM ID: SU
Product:
Version: 0.2
Serial number: 0X520AB128
Manufacturing date: 3/2015
cardSize: 128042.66 MB (MB = 1,000,000 bytes)
flashEraseSize: 128 blocks
eraseSingleBlock: true
OCR: 0XC0FF8000
SD Partition Table
part,boot,type,start,length
1,0X0,0XC,8192,250075136
2,0X0,0X0,0,0
3,0X0,0X0,0,0
4,0X0,0X0,0,0
Volume is FAT32
blocksPerCluster: 128
clusterCount: 1953456
freeClusters: 1953455
freeSpace: 128021.63 MB (MB = 1,000,000 bytes)
fatStartBlock: 10436
fatCount: 2
blocksPerFat: 15262
rootDirStart: 2
dataStartBlock: 40960
Indeed, at this moment I have 5 more beta+breakout boards ready to go, and parts to build 10 more. After those 15 are claimed, the beta will be officially closed
#define SD1_CONFIG SdSpiConfig(36, DEDICATED_SPI, SD_SCK_MHZ(18), &SPI1)
The production PCB are being fabricated now, so I can say with absolute confidence we will not have any more hardware changes. It's all software-only testing from here.
Hi Paul, is it the same form factor as the Teensy 3.2? Are there any photos or images? I just went through the last 30 pages of the thread but couldn't see any
Steve
During this beta, I'd like to ask everyone to follow a few simple rules.
No photos!
Keep all conversations & info on this forum thread
(1052 only) Don't mess with the OTP fuses... On the 1062 boards, do mess with the fuses.
I would volunteer that it's fair to call it "Pin Compatible" with 3.2 (with a few differences)
No, and there won't be any photos until the official release. That's the main rule we ask of everyone who's beta testing. We share lots of tech info here, like the pinouts in msg #2, but not photos.
yep understood, fingers crossed its no wider than 19mm![]()
VIN at x=50, y=650
The plan is for T4 to match the form factor T3.2, at least for overall size and the 28 outside pins.
Pin 24: x=1182, y=550
Pin 25, x=1018, y=550
Pin 26: x=1182, y=450
Pin 27, x=1018, y=450
Pin 28: x=1182, y=350
Pin 29, x=1018, y=350
Pin 30: x=1182, y=250
Pin 31, x=1018, y=250
Pin 32: x=1182, y=150
Pin 33, x=1018, y=150
USB2 D+, x=72, y=305
USB2 D+, x=72, y=395
SD DAT1, x=361.22, y=487.80
SD DAT0, x=361.22, y=448.43
SD GND, x=361.22, y=409.06
SD CLK, x=361.22, y=369.69
SD 3.3V, x=361.22, y=330.32
SD CMD, x=361.22, y=290.95
SD DAT3, x=361.22, y=251.58
SD DAT2, x=361.22, y=212.21
Not sure if Bill ported the T4 specific uSDHC code (for build-in uSD card) to his library (the "SdFat-beta/src/SdCard/SdioTeensy.cpp" only handles Teemsy3.5 3.6)SDFat vs SDFat-Beta
Just discovered that Bill Greiman has updated his SDFat library to SDFat -Beta. It runs out of the box without any modifications for the T4. It also supports FAT16/FAT32 and exFAT SD cards. I have been testing it on the T4B2W version. Just can't figure out how to get it to read the builtin_sdcard (one on board). Supposedly all you have to do is something like this:
.Code:#define SD1_CONFIG SdSpiConfig(36, DEDICATED_SPI, SD_SCK_MHZ(18), &SPI1)
