Teensy 4.0 First Beta Test
Today we mailed pinout cards to all 27 people who have the beta hardware. They're coming by ordinary postal mail, just 2 cards in an envelope.
Thank you appreciate it. I printed out the basic card on card stock and really did look good. Should be even better from the printers. Getting closer to release think we are all getting excited now.
@mjs513 - Thanks
No never did get it working. There was a problem with the SD library and its on the msg#6 list for Paul to Check out.
I guess this is probably where I need to start. I have the latest TD software. TD1.47B4 if I have not missed something. Frank B's MP3 player works perfectly with the SDcard on PJRC's audio board.
I do not have a prop-shield so I cannot test with that.
Breaking from MSC to play. See if I can get the audio board to work with the T4 SDCard slot on the break out board and SD.
The Metro library appears to work, but the example at https://www.pjrc.com/teensy/td_libs_Metro.html uses the obsolete BYTE constant and fails to compile for this reason. I'm not sure if the timing is as precise as we should expect, judging by the time stamps in the Serial Monitor window.
<added>: linked to this post in Post #4:: Metro Fails for BYTE usage and possible timing issue
@mjs513 - when you got that recent T4 FAULT - did you have LED blinking?
I'm wondering if this code was updated to 1062 fast io?
IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_03 = 5; // pin 13
IOMUXC_SW_PAD_CTL_PAD_GPIO_B0_03 = IOMUXC_PAD_DSE(7);
GPIO2_GDIR |= (1 << 3);
GPIO2_DR_SET = (1 << 3);
GPIO2_DR_CLEAR = (1 << 3); //digitalWrite(13, LOW);
if ( F_CPU_ACTUAL >= 600000000 )
set_arm_clock(300000000);
while (1)
GPIO2_DR_SET = (1 << 3); //digitalWrite(13, HIGH);
// digitalWrite(13, HIGH);
for (nn = 0; nn < 2000000/2; nn++) ;
// digitalWrite(13, LOW);
for (nn = 0; nn < 18000000/2; nn++) ;
Not wondering much though because this works as well when FAULTED:
    while ( 1 ) {
      volatile unsigned int nn ;
      digitalWriteFast( 13, HIGH);
      for (nn = 0; nn < 2000000 / 2; nn++) ;
      digitalWriteFast( 13, 0);
      for (nn = 0; nn < 18000000 / 2; nn++) ;
I got back to the debug_tt library now working on T4 USB Serial. The weak :: void HardFault_HandlerC(unsigned int *hardfault_args) {//…} that PJRC Fault Code currently sends to Serial4 (until it gets turned off ?) can be brought back with :: #include "debug_tt.h" and
debBegin_tt( (HardwareSerial*)&Serial1, LED_BUILTIN, 12); // Use Serial1, Blink pin #13 on fault, {opt} watch pin #12 for _isr() CHANGE and break into debug_tt code.
**COOL Note: not checked today - but last I saw loop() can HALT and _isr() code still gets calls and USB Serial can still print - as it does below even when MCU FAULTED. As below it dumps the sketch generated 'call trace' - and then allows calling the 'Debug_Dump()' code and return to execution.
I am finding as before that Serial.printf() can handle a NAN - but printf() causes a fault - with this code:
    deb_tt( 6, 0xdeadbeef );    [COLOR="#FF0000"]// THIS IS LINE #114 where '0xdeadbeef' is recorded in value '6 =>'[/COLOR]
  float x = 0.0 / 0.0;
  [COLOR="#40E0D0"]Serial.printf("[B]NAN >> %f[/B]\n", x)[/COLOR]; // Hard Fault with printf()
  deb_tt( 7, __LINE__ );  // THIS IS LINE #119
  printf("NAN >> %f\n", x); // Hard Fault with printf()
You can see up to the FAULT in line #120 {last func:: DebugTest2()} - then the FAULT register dump happens - then it returns to debug_tt code where you can see the recording of line #119 setting entry '7 =>' shows the last logged entry before the FAULT.
That information shown after : Last debug_tt helper @ L#:31 Debug_Dump() where the SKETCH can place a 'weak' override for Debug_Dump() to print any other global sketch data that function can access.
After calling that code it then proceeds to print the last updated 'call trace' (?) of the log entries mad with debug_tt funcs() and then a FAST BLINK HALT of execution.
#### Debug trace Show debug_tt Info: [Last debug_tt helper @ L#:114 DebugTest2()
2 => 14916973 0x00E39D6D [L#109_C#4
3 => 1052929 0x00101101 [L#112_C#5
4 => 615047 0x00096287 [L#68_C#3
6 => 3735928559 0xDEADBEEF [L#114_C#6 _<< last func:: DebugTest2()
NAN >> nan
Fault irq 3
stacked_r0 :: 00000001
stacked_r1 :: 20200008
stacked_r2 :: 0000000B
stacked_r3 :: 00000000
stacked_r12 :: FFFFFFFF
stacked_lr :: 000016AF
stacked_pc :: 00000000
stacked_psr :: 400F0000
_CFSR :: 00020000
(INVSTATE) Instruction makes illegal use of EPSR)
_HFSR :: 40000000
(FORCED) Forced Hard Fault
_DFSR :: 00000000
_AFSR :: 00000000
_BFAR :: 00000000
_MMAR :: 00000000
in Debug_Dump @L#31 stack var addr: 0x2006FD14
User Custom Debug Dump. Micros==14945934
userDebugDumptt() in debug_tt ___
F_CPU=300000000
>>>> Debug Fault >>>> debug_fault >>>> TYPE:T_4
debug_tt Info: [Last debug_tt helper @ L#:31 Debug_Dump()
7 => 119 0x00000077 [L#119_C#7 _<< last func:: DebugTest2()
>>>> Debug Fault >>>> TYPE:T_4
--- Faulted >>>> Execution Halted.
For more info - print it in sketch :: Debug_Dump(void)
The code seems usable but horribly written and much abused as I transitioned it from T_3.x on Beta 1 T4_1052. I can post it soon - or sooner by request - but I should make a better example or two.
But for now it runs similarly on T_3.5 with the same code - it just has a different register DUMP and output ordering:
2 => 10436433	0x009F3F51	[L#109_C#4
4 => 648498	0x0009E532	[L#68_C#3
NAN >> nan
 >>>> Debug Fault   >>>> debug_fault   >>>> TYPE:hrd
debug_tt Info:	[Last debug_tt helper @ L#:119  DebugTest2()
fault:
??: 00000001		??: 1FFF0CE0		??: 00008809
psr: 1FFF0CE0		adr: 00000001		lr: 0000000B
r12: 00001623		r3: 00000000
r2: 1FFF171C
r1: 7FF80000
r0: 00000000
r4: 1FFF0C20
lr: 1FFF0CE0
CFR: :: 00008200
HFR: :: 40000000
DFR: :: 00000000
MMA: :: 99200303
BFA: :: 99200303
ASR: :: 00000000
Another T4 example:: Doing something like this at line #60 - using something not enabled:
  [B]deb_tt( 2, micros() );[/B]  // LINE #58 in setup() - as noted below
#if defined(__IMXRT1062__)
  [U]GPT1_CNT = 5[/U]; // FAULT
Would end with output like this with the deb_tt() entry as shown above:
 begin ...
Fault irq 3
 stacked_r0 ::  20000010
 stacked_r1 ::  20000000
 stacked_r2 ::  0000005F
 stacked_r3 ::  0000005F
 stacked_r12 ::  200024D8
 stacked_lr ::  00000351
 stacked_pc ::  600012F4
 stacked_psr ::  01070000
 _CFSR ::  00000400
      (IMPRECISERR) Data bus error but address not related to instruction
 _HFSR ::  40000000
 _DFSR ::  00000000
 _AFSR ::  00000000
 _BFAR ::  00000000
 _MMAR ::  00000000
in Debug_Dump @L#31	stack var addr: 0x2006FEE4
 User Custom Debug Dump. Micros==797938
 F_CPU=300000000
[B][U]2 => 769006	0x000BBBEE	[L#58_C#1 _<< last func:: setup()[/U][/B]
But in https://forum.pjrc.com/threads/54711-Teensy-4-0-First-Beta-Test?p=203973&viewfull=1#post203973 you said it is working.
The original port was for T4b1 and needed obviously modified for T4b2, which you did.
Are there other issues?
BTW, why did you use another BUILTIN_SDCARD number than the other boards (36 instead of 254)?
@WMXZ
If you look at msg #6 there are two open issues:
  1. WavFilePlayer issue with BUILTIN_SDCARD, #3008,
  2. SD lib datalogger issue, #3135,[/TD]
Not sure what is causing the issue but Paul in a follow-on to my Datalogger issue did indicate that there was an issue with the lib that he needed to rewicker the library. To be honest I can not find that post right now.
Why did I use 36 instead of 254 - I can't remember now but Paul did change that when he incorporated the PR to 254: https://github.com/PaulStoffregen/SD/pull/18
EDIT: You might want to check this out as well: https://github.com/PaulStoffregen/Audio/pull/294
@mjs513 - Thanks, it all helps. XBAR is a new area for me.
Just reading the 1060 RM XBAR chapters, there is an intriguing statement 60.2.1 that "...any input (typically FROM external GPIO pin or internal modules) can be connected to any output (typically TO external GPIO pin or internal modules). This seems to be a big difference of T4 with T3? On the surface, the old issue of not being able to access a peripheral - because the IOMUX table did not config it to the available pins that Paul designed as Teensy pins - appears to be circumvented.
Conceptually, these XBAR modules (A and B) seem to be "overtaking" the old idea of "ALT"ernatives for a specific GPIO pin (previously a more limited muxing arrangement). Or have I got the wrong end of the stick?
@TelephoneBill
Its new to me as well - still don't have it all down. Check out 3.5 XBAR Resource Assignments, think its page 60 of the RM and should give you an idea of how its mapped to peripherial pins
UPDATE: Just to make your life a little easier the XBARA assignments that you see in the example were extracted from the IMXRT1060.h file in the sdk. I extracted the whole pin assignment list for you, Input and output for XBAR:
  • XBARA_IO_ASSIGNMENTS.txt
Oh, if only all the peripheral signals connected to the crossbar switch. But they don't. Only a relatively small number of trigger signals are routed to it. There are a few cases where it might be usable this way, but most of the I/O signals go to normal pin muxes, not the crossbar.
No, but I'm pretty sure it won't work. NXP didn't assign the SPI signals to the pins in a way that matches the corresponding SDIO pins. For example, SCK2 ends up in pin 37, but would need to be on pin 36. I know this could have been done better, but it's simply the way NXP designed the chip. No amount of wishful thinking or software trickery can re-wire the muxes they put into the silicon.
You can find the pinout info on msg #3.
Looks like there is no way to correctly mux the SPI pins to the SD socket. It is nice that Teensy 3.5/3.6 allows this.
SPI access is nice since you can insure the max latency for a write is small by doing very large write transactions.
SD RUs, Record Units, are very large, 512 KiB. If you do a write smaller than an RU, data is copied to a new RU. Think of RUs as flash pages. 512 byte sectors are emulated, 1024 sectors are in a typical RU. If you write multiple RUs in a single transaction, The SD makes maximum use of internal buffering and you get maximum performance.
I hope I can get the uSDHC controller on T4 to do huge, many MB, writes as a single transaction this was only possible on T3.6 with programmed I/O to the FIFO. It was not possible with DMA.
The Time library used in the TimeSerial example documented in https://www.pjrc.com/teensy/td_libs_Time.html works.
To set the time, I needed to use /dev/ttyACM1 because I had a Teensy LC at ttyACM0 so the Teensy 4.0 was at ttyACM1. Was able to set the time using the Processing sketch as well as the Linux command line. First time using Processing. Looks nice.
@Paul: Made a note in post here.
IIRC > Just a reminder - You asked once about startup Hook()'s in some fashion - adding a new one?
Looking at current T4 startup.c::ResetHandler() code I'm not seeing the ones present on T_3.x?
void startup_early_hook(void)		__attribute__ ((weak, alias("startup_default_early_hook")));
void startup_late_hook(void)		__attribute__ ((weak, alias("startup_default_late_hook")));
No need or ideas now - just wondering if they were on a list?
This post #1142 is the one I was referring to:
Would be perfect if there were some early hooks - before and after USB init. Setup() is too late - all objects get initialized before Setup().
I believe we have 2 hooks in Teensy 3.x startup.
The first is very early before the PLLs or static C variables initialized, mainly for taking control of the watchdog. The second is after C++ constructors but before setup().
Are these 2 good enough? Do we need a 3rd, maybe before constructors but after PLLs running and static variables initialized? Before USB, after USB, etc? Do we need 4, 5 or even more?!
Whatever ends up being done, I'd like to have the same names and roughly similar places in the startup process on Teensy 3 & 4.
Marked 'Time' as working in Msg #4 list.
works   Time   post #3539   based on : www.pjrc.com/teensy/td_libs_Time.html
@pictographer - note the TeensyLoader now prepopulates the 'Time' at time of upload. Did you see that working in conjunction with this? No longer static compile time - but pushed to T4 from PC during upload. It was seen to work with last updated to bootloader - if time already set it may not present a change.
@defragster, thank you.
The time appears to be set reasonably by the TeensyLoader. I modified the example to report the time during setup. The example does not recognize that the Teensy is synchronized until it gets time from the source it expects, even though it already has the time from the loader.
If I understand correctly, the TeensyLoader wouldn't run if the Teensy were unplugged and replugged, so the Teensy would reflect the time as of last upload, not last start, so the Time library is still useful.
@mjs513 - @Paul - As mentioned in other thread.
I was playing with the uncanny eyes as modified by @mjs513 to work with our ST7735_t3 library, the program is up at: https://forum.pjrc.com/threads/5573...3-x-and-beyond?p=209650&viewfull=1#post209650
I made a few changes to his app on configuration as to work with your breakout boards, so configured the 2nd display to use pin 23(MCLK) and reset pin 20 (LRCLK)... Was working. Then made a code change to try it out and then when it uploads,
The Windows machine shows
Then stopped being able to upload and startup that program...
Was able to upload blink, after hitting program button. Then uploaded that app again... This time I had debug setup to Serial4:
sof 31
sof 30
sof 29
sof 28
sof 27
sof 26
sof 25
sof 24
sof 23
sof 22
sof 21
sof 20
sof 19
sof 18
sof 17
sof 16
sof 15
sof 14
sof 13
sof 12
sof 11
sof 10
sof 9
sof 8
sof 7
sof 6
sof 5
sof 4
sof 3
sof 2
sof 1
CB  a
CBAd pe !a en ad db ata ch `k `dpabf pe clfac `e if DCD    " @
@@L @DD$! ABL @DD d@@L @DD$! BE5 D  APE,!q
ED p p p p !p p p !p           @B@ _@FSR ::  00000000
 _@FAR ::  00000000
 _@DAR ::  00020004
De pe !a e
This time had what looks like some debug stuff at the end...
Verbose info not sure if it will show much:
17:07:06.506 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:07:06.507 (ports 5): nothing new, skipping HID & Ports enum
17:07:06.508 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:07:06.509 (ports 5): nothing new, skipping HID & Ports enum
17:07:06.808 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:07:06.809 (ports 5): nothing new, skipping HID & Ports enum
17:07:08.813 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:07:08.814 (ports 5): nothing new, skipping HID & Ports enum
17:09:01.170 (post_compile 1): Begin, version=1.47-beta4, high-res time
17:09:01.641 (loader): Teensy Loader 1.47-beta4, begin program
17:09:01.736 (loader): File "uncannyEyes.ino.hex". 197012 bytes, 10% used
17:09:01.748 (loader): Listening for remote control on port 3149
17:09:01.748 (loader): initialized, showing main window
17:09:01.772 (loader): remote connection 1260 opened
17:09:01.772 (loader): remote cmd from 1260: "comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)"
17:09:01.773 (post_compile 1): Sending command: comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)
17:09:01.773 (loader): remote cmd from 1260: "status"
17:09:01.775 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:09:01.776 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:09:01.776 (loader): HID/win32:  vid:046D pid:B01A ver:0003
17:09:01.777 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:09:01.778 (loader): remote cmd from 1260: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\"
17:09:01.778 (loader): remote cmd from 1260: "file:Blink.ino.hex"
17:09:01.779 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:09:01.779 (post_compile 1): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\
17:09:01.779 (post_compile 1): Sending command: file:Blink.ino.hex
17:09:01.783 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:09:01.787 (loader): remote cmd from 1260: "status"
17:09:01.789 (loader): remote cmd from 1260: "auto:on"
17:09:01.790 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:09:01.790 (post_compile 1): Sending command: auto:on
17:09:01.790 (post_compile 1): Disconnect
17:09:01.801 (loader): remote connection 1260 closed
17:09:02.009 (post_compile 2): Begin, version=1.47-beta4, high-res time
17:09:02.011 (loader): remote connection 1332 opened
17:09:02.011 (loader): remote cmd from 1332: "comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)"
17:09:02.011 (loader): remote cmd from 1332: "status"
17:09:02.011 (post_compile 2): Sending command: comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)
17:09:02.013 (loader): remote cmd from 1332: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\"
17:09:02.013 (post_compile 2): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:09:02.013 (post_compile 2): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\
17:09:02.014 (post_compile 2): Sending command: file:Blink.ino.hex
17:09:02.014 (loader): remote cmd from 1332: "file:Blink.ino.hex"
17:09:02.018 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:09:02.021 (loader): remote cmd from 1332: "status"
17:09:02.023 (post_compile 2): Status: 1, 1, 0, 0, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:09:02.023 (post_compile 2): Disconnect
17:09:02.035 (loader): remote connection 1332 closed
17:09:02.035 (loader): remote connection 1332 opened
17:09:02.035 (post_compile 3): Running teensy_reboot: "D:\arduino-1.8.9\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY40" "-port=usb:0/140000/0/7/2" "-portlabel=(null)" "-portprotocol=(null)"
17:09:02.051 (reboot 4): Begin, version=1.47-beta4, high-res time
17:09:02.051 (reboot 4): location = usb:0/140000/0/7/2
17:09:02.051 (reboot 4): portlabel = (null)
17:09:02.051 (reboot 4): portprotocol = (null)
17:09:02.051 (reboot 4): LoadLibrary cfgmgr32 ok
17:09:02.051 (reboot 4): LoadLibrary ntdll ok
17:09:02.053 (reboot 4): nothing new, skipping HID & Ports enum
17:09:02.055 (loader): remote connection 1268 opened
17:09:02.055 (reboot 4): Disconnect
17:09:02.067 (loader): remote connection 1268 closed
17:09:02.077 (loader): remote connection 1332 closed
17:09:03.160 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:09:03.161 (loader): remote connection 1352 opened
17:09:03.164 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#0008f870#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:09:03.164 (ports 5): found_usb_device, loc=usb:0/140000/0/7/2    Port_#0002.Hub_#0003
17:09:03.164 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0004
17:09:03.164 (ports 5): found_usb_device, devinst=0000001c
17:09:03.164 (ports 5): add: loc=usb:0/140000/0/7/2, class=HID, vid=16C0, pid=0478, ver=0004, serial=0008f870, dev=\\?\usb#vid_16c0&pid_0478#0008f870#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:09:03.164 (ports 5): hiddev_from_devinst_list: iface=0
17:09:03.165 (ports 5): found_usb_device complete
17:09:03.166 (ports 5): hid, found devinst=0000001D
17:09:03.166 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#7&283234e0&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
17:09:03.166 (ports 5): hid,  opened handle
17:09:03.166 (ports 5):  devinst=0000001D, location=usb:0/140000/0/7/2
17:09:03.166 (ports 5):  vid=16C0, pid=0478, ver=0004, usepage=FF9C, use=0024
17:09:03.166 (ports 5):  devpath=\\?\hid#vid_16c0&pid_0478#7&283234e0&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
17:09:03.166 (ports 5): usb_add: usb:0/140000/0/7/2  hid#vid_16c0&pid_0478 (Teensy 4-Beta2) Bootloader
17:09:03.233 (loader): Device came online, code_size = 2031616
17:09:03.233 (loader): Board is: Teensy 4-Beta2 (IMXRT1062), version 0.04
17:09:03.237 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:09:03.238 (loader): set background IMG_ONLINE
17:09:03.243 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:09:03.244 (loader): elf appears to be for Teensy 4-Beta2 (IMXRT1062) (2031616 bytes)
17:09:03.244 (loader): elf binary data matches hex file
17:09:03.244 (loader): elf file is for Teensy 4-Beta2 (IMXRT1062)
17:09:03.244 (loader): begin operation
17:09:03.260 (loader): flash, block=0, bs=1024, auto=1
17:09:03.261 (loader):  gauge old value = 0
17:09:03.264 (loader): flash, block=1, bs=1024, auto=1
17:09:03.394 (loader):  gauge old value = 1
17:09:03.396 (loader): flash, block=2, bs=1024, auto=1
17:09:03.512 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:09:03.513 (ports 5): nothing new, skipping HID & Ports enum
17:09:03.664 (loader):  gauge old value = 2
17:09:03.665 (loader): flash, block=3, bs=1024, auto=1
17:09:03.665 (loader):  gauge old value = 3
17:09:03.665 (loader): flash, block=4, bs=1024, auto=1
17:09:03.666 (loader):  gauge old value = 4
17:09:03.666 (loader): flash, block=5, bs=1024, auto=1
17:09:03.667 (loader):  gauge old value = 5
17:09:03.668 (loader): flash, block=6, bs=1024, auto=1
17:09:03.669 (loader):  gauge old value = 6
17:09:03.669 (loader): flash, block=7, bs=1024, auto=1
17:09:03.670 (loader):  gauge old value = 7
17:09:03.671 (loader): flash, block=8, bs=1024, auto=1
17:09:03.672 (loader):  gauge old value = 8
17:09:03.672 (loader): flash, block=9, bs=1024, auto=1
17:09:03.673 (loader):  gauge old value = 9
17:09:03.674 (loader): flash, block=10, bs=1024, auto=1
17:09:03.675 (loader):  gauge old value = 10
17:09:03.676 (loader): flash, block=11, bs=1024, auto=1
17:09:03.676 (loader):  gauge old value = 11
17:09:03.678 (loader): flash, block=12, bs=1024, auto=1
17:09:03.678 (loader):  gauge old value = 12
17:09:03.680 (loader): flash, block=13, bs=1024, auto=1
17:09:03.680 (loader):  gauge old value = 13
17:09:03.681 (loader): flash, block=14, bs=1024, auto=1
17:09:03.682 (loader):  gauge old value = 14
17:09:03.682 (loader): flash, block=15, bs=1024, auto=1
17:09:03.683 (loader):  gauge old value = 15
17:09:03.689 (loader): sending reboot
17:09:03.690 (loader): begin wait_until_offline
17:09:03.707 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:09:03.708 (ports 5): remove: loc=usb:0/140000/0/7/2
17:09:03.708 (ports 5): usb_remove: usb:0/140000/0/7/2
17:09:03.708 (ports 5): nothing new, skipping HID & Ports enum
17:09:03.741 (loader): offline, waited 1
17:09:03.741 (loader): end operation, total time = 0.497 seconds
17:09:03.742 (loader): set background IMG_REBOOT_OK
17:09:03.743 (loader): redraw timer set, image 14 to show for 1200 ms
17:09:03.748 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:09:03.748 (loader): HID/win32:  vid:046D pid:B01A ver:0003
17:09:03.982 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:09:03.983 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:09:03.983 (ports 5): found_usb_device, loc=usb:0/140000/0/7/2    Port_#0002.Hub_#0003
17:09:03.983 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
17:09:03.983 (ports 5): found_usb_device, devinst=0000001b
17:09:03.983 (ports 5): add: loc=usb:0/140000/0/7/2, class=Ports, vid=16C0, pid=0483, ver=0279, serial=5878880, dev=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:09:03.983 (ports 5):   comport_from_devinst_list attempt
17:09:03.983 (ports 5):   found Ports in classguid_list at index=0
17:09:03.983 (ports 5):   port COM32 found from devnode
17:09:03.983 (ports 5): found_usb_device complete
17:09:03.984 (ports 5): usb_add: usb:0/140000/0/7/2  COM32 (Teensy 4-Beta2) Serial
17:09:04.265 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:09:04.266 (ports 5): nothing new, skipping HID & Ports enum
17:09:04.764 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:09:04.765 (ports 5): nothing new, skipping HID & Ports enum
17:09:04.944 (loader): redraw, image 9
17:09:10.896 (loader): Verbose Info event
17:18:12.261 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:18:12.262 (ports 5): remove: loc=usb:0/140000/0/7/2
17:18:12.262 (ports 5): usb_remove: usb:0/140000/0/7/2
17:18:12.262 (ports 5): nothing new, skipping HID & Ports enum
17:18:12.312 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:18:12.312 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:18:12.312 (ports 5): nothing new, skipping HID & Ports enum
17:18:12.726 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:18:12.727 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#0008f870#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:18:12.727 (ports 5): found_usb_device, loc=usb:0/140000/0/7/2    Port_#0002.Hub_#0003
17:18:12.727 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0004
17:18:12.727 (ports 5): found_usb_device, devinst=0000001c
17:18:12.727 (ports 5): add: loc=usb:0/140000/0/7/2, class=HID, vid=16C0, pid=0478, ver=0004, serial=0008f870, dev=\\?\usb#vid_16c0&pid_0478#0008f870#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:18:12.728 (ports 5): hiddev_from_devinst_list: iface=0
17:18:12.729 (ports 5): found_usb_device complete
17:18:12.731 (ports 5): usb_add: usb:0/140000/0/7/2  [no_device] (Teensy 4-Beta2) Bootloader
17:18:12.829 (loader): Device came online, code_size = 2031616
17:18:12.834 (loader): Board is: Teensy 4-Beta2 (IMXRT1062), version 0.04
17:18:12.844 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:18:12.849 (loader): set background IMG_ONLINE
17:18:12.859 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:18:12.864 (loader): elf appears to be for Teensy 4-Beta2 (IMXRT1062) (2031616 bytes)
17:18:12.868 (loader): elf binary data matches hex file
17:18:12.880 (loader): elf file is for Teensy 4-Beta2 (IMXRT1062)
17:18:12.887 (loader): begin operation
17:18:12.909 (loader): flash, block=0, bs=1024, auto=1
17:18:12.914 (loader):  gauge old value = 0
17:18:12.920 (loader): flash, block=1, bs=1024, auto=1
17:18:13.045 (loader):  gauge old value = 1
17:18:13.069 (loader): flash, block=2, bs=1024, auto=1
17:18:13.074 (loader):  gauge old value = 2
17:18:13.078 (loader): flash, block=3, bs=1024, auto=1
17:18:13.082 (loader):  gauge old value = 3
17:18:13.086 (loader): flash, block=4, bs=1024, auto=1
17:18:13.091 (loader):  gauge old value = 4
17:18:13.095 (loader): flash, block=5, bs=1024, auto=1
17:18:13.100 (loader):  gauge old value = 5
17:18:13.105 (loader): flash, block=6, bs=1024, auto=1
17:18:13.109 (loader):  gauge old value = 6
17:18:13.113 (loader): flash, block=7, bs=1024, auto=1
17:18:13.117 (loader):  gauge old value = 7
17:18:13.121 (loader): flash, block=8, bs=1024, auto=1
17:18:13.125 (loader):  gauge old value = 8
17:18:13.128 (loader): flash, block=9, bs=1024, auto=1
17:18:13.132 (loader):  gauge old value = 9
17:18:13.136 (loader): flash, block=10, bs=1024, auto=1
17:18:13.140 (loader):  gauge old value = 10
17:18:13.145 (loader): flash, block=11, bs=1024, auto=1
17:18:13.148 (loader):  gauge old value = 11
17:18:13.152 (loader): flash, block=12, bs=1024, auto=1
17:18:13.155 (loader):  gauge old value = 12
17:18:13.160 (loader): flash, block=13, bs=1024, auto=1
17:18:13.164 (loader):  gauge old value = 13
17:18:13.167 (loader): flash, block=14, bs=1024, auto=1
17:18:13.172 (loader):  gauge old value = 14
17:18:13.177 (loader): flash, block=15, bs=1024, auto=1
17:18:13.180 (loader):  gauge old value = 15
17:18:13.186 (loader): sending reboot
17:18:13.192 (loader): begin wait_until_offline
17:18:13.202 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:18:13.203 (ports 5): remove: loc=usb:0/140000/0/7/2
17:18:13.203 (ports 5): usb_remove: usb:0/140000/0/7/2
17:18:13.203 (ports 5): nothing new, skipping HID & Ports enum
17:18:13.246 (loader): offline, waited 1
17:18:13.250 (loader): end operation, total time = 0.358 seconds
17:18:13.255 (loader): set background IMG_REBOOT_OK
17:18:13.260 (loader): redraw timer set, image 14 to show for 1200 ms
17:18:13.331 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:18:13.335 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:18:13.340 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:18:13.344 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:18:13.348 (loader): HID/win32:  vid:046D pid:B01A ver:0003
17:18:13.352 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:18:13.355 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:18:13.488 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:18:13.490 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:18:13.490 (ports 5): found_usb_device, loc=usb:0/140000/0/7/2    Port_#0002.Hub_#0003
17:18:13.490 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
17:18:13.490 (ports 5): found_usb_device, devinst=0000001b
17:18:13.490 (ports 5): add: loc=usb:0/140000/0/7/2, class=Ports, vid=16C0, pid=0483, ver=0279, serial=5878880, dev=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:18:13.490 (ports 5):   comport_from_devinst_list attempt
17:18:13.490 (ports 5):   found Ports in classguid_list at index=0
17:18:13.490 (ports 5):   port COM32 found from devnode
17:18:13.490 (ports 5): found_usb_device complete
17:18:13.492 (ports 5): usb_add: usb:0/140000/0/7/2  COM32 (Teensy 4-Beta2) Serial
17:18:14.068 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:18:14.068 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:18:14.069 (ports 5): nothing new, skipping HID & Ports enum
17:18:14.450 (loader): redraw, image 9
17:18:49.331 (loader): file changed
17:18:49.343 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:18:49.409 (post_compile 6): Begin, version=1.47-beta4, high-res time
17:18:49.410 (loader): remote connection 1532 opened
17:18:49.415 (post_compile 6): Sending command: comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)
17:18:49.415 (loader): remote cmd from 1532: "comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)"
17:18:49.423 (loader): remote cmd from 1532: "status"
17:18:49.429 (loader): remote cmd from 1532: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\"
17:18:49.430 (post_compile 6): Status: 1, 1, 0, 2, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:18:49.430 (post_compile 6): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\
17:18:49.434 (loader): remote cmd from 1532: "file:Blink.ino.hex"
17:18:49.434 (post_compile 6): Sending command: file:Blink.ino.hex
17:18:49.443 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:18:49.453 (loader): remote cmd from 1532: "status"
17:18:49.459 (post_compile 6): Status: 1, 1, 0, 2, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:18:49.459 (post_compile 6): Disconnect
17:18:49.473 (loader): remote connection 1532 closed
17:18:49.670 (post_compile 7): Begin, version=1.47-beta4, high-res time
17:18:49.671 (loader): remote connection 1536 opened
17:18:49.676 (loader): remote cmd from 1536: "comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)"
17:18:49.677 (post_compile 7): Sending command: comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)
17:18:49.681 (loader): remote cmd from 1536: "status"
17:18:49.691 (loader): remote cmd from 1536: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\"
17:18:49.692 (post_compile 7): Status: 1, 1, 0, 2, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:18:49.692 (post_compile 7): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\
17:18:49.695 (loader): remote cmd from 1536: "file:Blink.ino.hex"
17:18:49.696 (post_compile 7): Sending command: file:Blink.ino.hex
17:18:49.703 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:18:49.712 (loader): remote cmd from 1536: "status"
17:18:49.719 (post_compile 7): Status: 1, 1, 0, 2, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:18:49.719 (post_compile 7): Disconnect
17:18:49.731 (post_compile 8): Running teensy_reboot: "D:\arduino-1.8.9\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY40" "-port=usb:0/140000/0/7/2" "-portlabel=(null)" "-portprotocol=(null)"
17:18:49.731 (loader): remote connection 1536 closed
17:18:49.742 (loader): remote connection 1536 opened
17:18:49.764 (reboot 9): Begin, version=1.47-beta4, high-res time
17:18:49.764 (reboot 9): location = usb:0/140000/0/7/2
17:18:49.764 (reboot 9): portlabel = (null)
17:18:49.764 (reboot 9): portprotocol = (null)
17:18:49.764 (reboot 9): LoadLibrary cfgmgr32 ok
17:18:49.764 (reboot 9): LoadLibrary ntdll ok
17:18:49.765 (reboot 9): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:18:49.765 (reboot 9): found_usb_device, loc=usb:0/140000/0/7/2    Port_#0002.Hub_#0003
17:18:49.765 (reboot 9): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
17:18:49.765 (reboot 9): found_usb_device, devinst=00000003
17:18:49.765 (reboot 9): add: loc=usb:0/140000/0/7/2, class=Ports, vid=16C0, pid=0483, ver=0279, serial=5878880, dev=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:18:49.765 (reboot 9):   comport_from_devinst_list attempt
17:18:49.765 (reboot 9):   found Ports in classguid_list at index=0
17:18:49.765 (reboot 9):   port COM32 found from devnode
17:18:49.765 (reboot 9): found_usb_device complete
17:18:49.768 (loader): remote connection 1568 opened
17:18:49.772 (loader): remote cmd from 1568: "show:arduino_attempt_reboot"
17:18:49.773 (reboot 9): found Teensy Loader, version 1.47
17:18:49.773 (reboot 9): Sending command: show:arduino_attempt_reboot
17:18:49.775 (loader): got request to show arduino rebooting message
17:18:49.781 (loader): remote cmd from 1568: "comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_reboot)"
17:18:49.782 (reboot 9): Sending command: comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_reboot)
17:18:49.787 (loader): remote cmd from 1568: "status"
17:18:49.794 (reboot 9): Status: 1, 1, 0, 2, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:18:49.794 (reboot 9): do_reset (serial) COM32
17:18:49.805 (loader): remote cmd from 1568: "status"
17:18:49.811 (reboot 9): Status: 1, 1, 0, 2, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:18:49.811 (reboot 9): status read, retry 0
17:18:49.868 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:18:49.871 (ports 5): remove: loc=usb:0/140000/0/7/2
17:18:49.871 (ports 5): usb_remove: usb:0/140000/0/7/2
17:18:49.871 (ports 5): nothing new, skipping HID & Ports enum
17:18:49.913 (loader): remote cmd from 1568: "status"
17:18:49.920 (reboot 9): Status: 1, 1, 0, 2, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:18:49.920 (reboot 9): status read, retry 1
17:18:50.021 (loader): remote cmd from 1568: "status"
17:18:50.038 (reboot 9): Status: 1, 1, 0, 2, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:18:50.038 (reboot 9): status read, retry 2
17:18:50.073 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:18:50.074 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#0008f870#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:18:50.074 (ports 5): found_usb_device, loc=usb:0/140000/0/7/2    Port_#0002.Hub_#0003
17:18:50.074 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0004
17:18:50.074 (ports 5): found_usb_device, devinst=0000001c
17:18:50.074 (ports 5): add: loc=usb:0/140000/0/7/2, class=HID, vid=16C0, pid=0478, ver=0004, serial=0008f870, dev=\\?\usb#vid_16c0&pid_0478#0008f870#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:18:50.074 (ports 5): hiddev_from_devinst_list: iface=0
17:18:50.074 (ports 5): found_usb_device complete
17:18:50.075 (ports 5): usb_add: usb:0/140000/0/7/2  [no_device] (Teensy 4-Beta2) Bootloader
17:18:50.148 (loader): remote cmd from 1568: "status"
17:18:50.158 (loader): Device came online, code_size = 2031616
17:18:50.163 (loader): Board is: Teensy 4-Beta2 (IMXRT1062), version 0.04
17:18:50.172 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:18:50.177 (loader): set background IMG_ONLINE
17:18:50.186 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:18:50.191 (loader): elf appears to be for Teensy 4-Beta2 (IMXRT1062) (2031616 bytes)
17:18:50.195 (loader): elf binary data matches hex file
17:18:50.199 (loader): elf file is for Teensy 4-Beta2 (IMXRT1062)
17:18:50.207 (loader): begin operation
17:18:50.226 (reboot 9): Status: 1, 1, 1, 3, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:18:50.232 (loader): flash, block=0, bs=1024, auto=1
17:18:50.237 (loader):  gauge old value = 0
17:18:50.244 (loader): flash, block=1, bs=1024, auto=1
17:18:50.367 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:18:50.367 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:18:50.368 (loader):  gauge old value = 1
17:18:50.370 (ports 5): hid, found devinst=0000001D
17:18:50.370 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#7&283234e0&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
17:18:50.370 (ports 5): hid,  opened handle
17:18:50.370 (ports 5):  devinst=0000001D, location=usb:0/140000/0/7/2
17:18:50.370 (ports 5):  vid=16C0, pid=0478, ver=0004, usepage=FF9C, use=0024
17:18:50.370 (ports 5):  devpath=\\?\hid#vid_16c0&pid_0478#7&283234e0&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
17:18:50.370 (ports 5): usb_add: usb:0/140000/0/7/2  hid#vid_16c0&pid_0478 (Teensy 4-Beta2) Bootloader
17:18:50.377 (loader): remote cmd from 1568: "status"
17:18:50.386 (reboot 9): Status: 1, 1, 1, 3, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:18:50.407 (loader): flash, block=2, bs=1024, auto=1
17:18:50.411 (loader):  gauge old value = 2
17:18:50.417 (loader): flash, block=3, bs=1024, auto=1
17:18:50.421 (loader):  gauge old value = 3
17:18:50.425 (loader): flash, block=4, bs=1024, auto=1
17:18:50.428 (loader):  gauge old value = 4
17:18:50.432 (loader): flash, block=5, bs=1024, auto=1
17:18:50.437 (loader):  gauge old value = 5
17:18:50.440 (loader): flash, block=6, bs=1024, auto=1
17:18:50.444 (loader):  gauge old value = 6
17:18:50.448 (loader): flash, block=7, bs=1024, auto=1
17:18:50.454 (loader):  gauge old value = 7
17:18:50.459 (loader): flash, block=8, bs=1024, auto=1
17:18:50.462 (loader):  gauge old value = 8
17:18:50.466 (loader): flash, block=9, bs=1024, auto=1
17:18:50.471 (loader):  gauge old value = 9
17:18:50.474 (loader): flash, block=10, bs=1024, auto=1
17:18:50.478 (loader):  gauge old value = 10
17:18:50.481 (loader): flash, block=11, bs=1024, auto=1
17:18:50.485 (loader):  gauge old value = 11
17:18:50.489 (loader): flash, block=12, bs=1024, auto=1
17:18:50.494 (loader):  gauge old value = 12
17:18:50.498 (loader): flash, block=13, bs=1024, auto=1
17:18:50.509 (loader):  gauge old value = 13
17:18:50.512 (loader): flash, block=14, bs=1024, auto=1
17:18:50.515 (loader):  gauge old value = 14
17:18:50.525 (loader): flash, block=15, bs=1024, auto=1
17:18:50.528 (loader):  gauge old value = 15
17:18:50.537 (loader): remote cmd from 1568: "status"
17:18:50.543 (loader): sending reboot
17:18:50.544 (reboot 9): Status: 1, 1, 1, 3, 0, 2, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:18:50.547 (loader): begin wait_until_offline
17:18:50.551 (loader): offline, waited 0
17:18:50.553 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:18:50.554 (ports 5): remove: loc=usb:0/140000/0/7/2
17:18:50.554 (ports 5): usb_remove: usb:0/140000/0/7/2
17:18:50.554 (ports 5): nothing new, skipping HID & Ports enum
17:18:50.558 (loader): end operation, total time = 0.347 seconds
17:18:50.563 (loader): set background IMG_REBOOT_OK
17:18:50.574 (loader): redraw timer set, image 14 to show for 1200 ms
17:18:50.618 (loader): remote cmd from 1568: "status"
17:18:50.628 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:18:50.632 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:18:50.636 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:18:50.649 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:18:50.659 (loader): HID/win32:  vid:046D pid:B01A ver:0003
17:18:50.665 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:18:50.672 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:18:50.682 (reboot 9): Status: 1, 1, 0, 3, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:18:50.682 (reboot 9): status read, retry 3
17:18:50.682 (reboot 9): Success
17:18:50.682 (reboot 9): Disconnect
17:18:50.705 (loader): remote connection 1568 closed
17:18:50.711 (loader): remote connection 1536 closed
17:18:50.824 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:18:50.825 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:18:50.825 (ports 5): found_usb_device, loc=usb:0/140000/0/7/2    Port_#0002.Hub_#0003
17:18:50.825 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
17:18:50.825 (ports 5): found_usb_device, devinst=0000001b
17:18:50.825 (ports 5): add: loc=usb:0/140000/0/7/2, class=Ports, vid=16C0, pid=0483, ver=0279, serial=5878880, dev=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:18:50.825 (ports 5):   comport_from_devinst_list attempt
17:18:50.825 (ports 5):   found Ports in classguid_list at index=0
17:18:50.825 (ports 5):   port COM32 found from devnode
17:18:50.825 (ports 5): found_usb_device complete
17:18:50.826 (ports 5): usb_add: usb:0/140000/0/7/2  COM32 (Teensy 4-Beta2) Serial
17:18:51.120 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:18:51.120 (ports 5): nothing new, skipping HID & Ports enum
17:18:51.370 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:18:51.370 (ports 5): nothing new, skipping HID & Ports enum
17:18:51.762 (loader): redraw, image 9
17:18:53.138 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:18:53.141 (ports 5): nothing new, skipping HID & Ports enum
17:21:01.016 (post_compile 10): Begin, version=1.47-beta4, high-res time
17:21:01.018 (loader): remote connection 1564 opened
17:21:01.022 (loader): remote cmd from 1564: "comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)"
17:21:01.022 (post_compile 10): Sending command: comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)
17:21:01.026 (loader): remote cmd from 1564: "status"
17:21:01.029 (loader): file changed
17:21:01.039 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:21:01.046 (post_compile 10): Status: 1, 1, 0, 3, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:01.046 (post_compile 10): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\
17:21:01.050 (loader): remote cmd from 1564: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\"
17:21:01.054 (post_compile 10): Sending command: file:Blink.ino.hex
17:21:01.055 (loader): remote cmd from 1564: "file:Blink.ino.hex"
17:21:01.063 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:21:01.075 (loader): remote cmd from 1564: "status"
17:21:01.081 (post_compile 10): Status: 1, 1, 0, 3, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:01.081 (post_compile 10): Disconnect
17:21:01.097 (loader): remote connection 1564 closed
17:21:01.286 (post_compile 11): Begin, version=1.47-beta4, high-res time
17:21:01.288 (loader): remote connection 1604 opened
17:21:01.293 (post_compile 11): Sending command: comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)
17:21:01.293 (loader): remote cmd from 1604: "comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)"
17:21:01.297 (loader): remote cmd from 1604: "status"
17:21:01.303 (loader): remote cmd from 1604: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\"
17:21:01.304 (post_compile 11): Status: 1, 1, 0, 3, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:01.304 (post_compile 11): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\
17:21:01.311 (loader): remote cmd from 1604: "file:Blink.ino.hex"
17:21:01.311 (post_compile 11): Sending command: file:Blink.ino.hex
17:21:01.318 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:21:01.327 (loader): remote cmd from 1604: "status"
17:21:01.332 (post_compile 11): Status: 1, 1, 0, 3, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:01.332 (post_compile 11): Disconnect
17:21:01.344 (post_compile 12): Running teensy_reboot: "D:\arduino-1.8.9\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY40" "-port=usb:0/140000/0/7/2" "-portlabel=hid#vid_16c0&pid_0478 Bootloader" "-portprotocol=Teensy"
17:21:01.348 (loader): remote connection 1604 closed
17:21:01.357 (loader): remote connection 1604 opened
17:21:01.377 (reboot 13): Begin, version=1.47-beta4, high-res time
17:21:01.377 (reboot 13): location = usb:0/140000/0/7/2
17:21:01.377 (reboot 13): portlabel = hid#vid_16c0&pid_0478 Bootloader
17:21:01.377 (reboot 13): portprotocol = Teensy
17:21:01.377 (reboot 13): Only location usb:0/140000/0/7/2 will be tried
17:21:01.377 (reboot 13): LoadLibrary cfgmgr32 ok
17:21:01.377 (reboot 13): LoadLibrary ntdll ok
17:21:01.378 (reboot 13): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:21:01.378 (reboot 13): found_usb_device, loc=usb:0/140000/0/7/2    Port_#0002.Hub_#0003
17:21:01.378 (reboot 13): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
17:21:01.378 (reboot 13): found_usb_device, devinst=00000003
17:21:01.378 (reboot 13): add: loc=usb:0/140000/0/7/2, class=Ports, vid=16C0, pid=0483, ver=0279, serial=5878880, dev=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:21:01.378 (reboot 13):   comport_from_devinst_list attempt
17:21:01.378 (reboot 13):   found Ports in classguid_list at index=0
17:21:01.378 (reboot 13):   port COM32 found from devnode
17:21:01.378 (reboot 13): found_usb_device complete
17:21:01.384 (loader): remote connection 1564 opened
17:21:01.393 (loader): remote cmd from 1564: "show:arduino_attempt_reboot"
17:21:01.393 (reboot 13): found Teensy Loader, version 1.47
17:21:01.393 (reboot 13): Sending command: show:arduino_attempt_reboot
17:21:01.397 (loader): got request to show arduino rebooting message
17:21:01.403 (reboot 13): Sending command: comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_reboot)
17:21:01.404 (loader): remote cmd from 1564: "comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_reboot)"
17:21:01.408 (loader): remote cmd from 1564: "status"
17:21:01.413 (reboot 13): Status: 1, 1, 0, 3, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:01.413 (reboot 13): do_reset (serial) COM32
17:21:01.426 (loader): remote cmd from 1564: "status"
17:21:01.431 (reboot 13): Status: 1, 1, 0, 3, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:01.431 (reboot 13): status read, retry 0
17:21:01.485 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:21:01.486 (ports 5): remove: loc=usb:0/140000/0/7/2
17:21:01.486 (ports 5): usb_remove: usb:0/140000/0/7/2
17:21:01.486 (ports 5): nothing new, skipping HID & Ports enum
17:21:01.532 (loader): remote cmd from 1564: "status"
17:21:01.540 (reboot 13): Status: 1, 1, 0, 3, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:01.540 (reboot 13): status read, retry 1
17:21:01.641 (loader): remote cmd from 1564: "status"
17:21:01.664 (reboot 13): Status: 1, 1, 0, 3, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:01.664 (reboot 13): status read, retry 2
17:21:01.692 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:21:01.692 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#0008f870#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:21:01.692 (ports 5): found_usb_device, loc=usb:0/140000/0/7/2    Port_#0002.Hub_#0003
17:21:01.692 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0004
17:21:01.692 (ports 5): found_usb_device, devinst=0000001c
17:21:01.692 (ports 5): add: loc=usb:0/140000/0/7/2, class=HID, vid=16C0, pid=0478, ver=0004, serial=0008f870, dev=\\?\usb#vid_16c0&pid_0478#0008f870#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:21:01.692 (ports 5): hiddev_from_devinst_list: iface=0
17:21:01.693 (ports 5): found_usb_device complete
17:21:01.694 (ports 5): usb_add: usb:0/140000/0/7/2  [no_device] (Teensy 4-Beta2) Bootloader
17:21:01.764 (loader): remote cmd from 1564: "status"
17:21:01.775 (loader): Device came online, code_size = 2031616
17:21:01.779 (loader): Board is: Teensy 4-Beta2 (IMXRT1062), version 0.04
17:21:01.787 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:21:01.793 (loader): set background IMG_ONLINE
17:21:01.801 (loader): File "Blink.ino.hex". 15444 bytes, 1% used
17:21:01.807 (loader): elf appears to be for Teensy 4-Beta2 (IMXRT1062) (2031616 bytes)
17:21:01.812 (loader): elf binary data matches hex file
17:21:01.816 (loader): elf file is for Teensy 4-Beta2 (IMXRT1062)
17:21:01.820 (loader): begin operation
17:21:01.834 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:21:01.834 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:21:01.835 (ports 5): hid, found devinst=0000001D
17:21:01.835 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#7&283234e0&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
17:21:01.835 (ports 5): hid,  opened handle
17:21:01.835 (ports 5):  devinst=0000001D, location=usb:0/140000/0/7/2
17:21:01.835 (ports 5):  vid=16C0, pid=0478, ver=0004, usepage=FF9C, use=0024
17:21:01.835 (ports 5):  devpath=\\?\hid#vid_16c0&pid_0478#7&283234e0&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
17:21:01.836 (ports 5): usb_add: usb:0/140000/0/7/2  hid#vid_16c0&pid_0478 (Teensy 4-Beta2) Bootloader
17:21:01.843 (reboot 13): Status: 1, 1, 1, 4, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:01.896 (loader): remote cmd from 1564: "status"
17:21:01.906 (reboot 13): Status: 1, 1, 1, 4, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:01.912 (loader): flash, block=0, bs=1024, auto=1
17:21:01.916 (loader):  gauge old value = 0
17:21:01.923 (loader): flash, block=1, bs=1024, auto=1
17:21:02.048 (loader):  gauge old value = 1
17:21:02.057 (loader): remote cmd from 1564: "status"
17:21:02.067 (reboot 13): Status: 1, 1, 1, 4, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:02.068 (loader): flash, block=2, bs=1024, auto=1
17:21:02.073 (loader):  gauge old value = 2
17:21:02.076 (loader): flash, block=3, bs=1024, auto=1
17:21:02.082 (loader):  gauge old value = 3
17:21:02.085 (loader): flash, block=4, bs=1024, auto=1
17:21:02.089 (loader):  gauge old value = 4
17:21:02.093 (loader): flash, block=5, bs=1024, auto=1
17:21:02.097 (loader):  gauge old value = 5
17:21:02.101 (loader): flash, block=6, bs=1024, auto=1
17:21:02.105 (loader):  gauge old value = 6
17:21:02.111 (loader): flash, block=7, bs=1024, auto=1
17:21:02.116 (loader):  gauge old value = 7
17:21:02.120 (loader): flash, block=8, bs=1024, auto=1
17:21:02.129 (loader):  gauge old value = 8
17:21:02.135 (loader): remote cmd from 1564: "status"
17:21:02.140 (loader): flash, block=9, bs=1024, auto=1
17:21:02.140 (reboot 13): Status: 1, 1, 1, 4, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:02.145 (loader):  gauge old value = 9
17:21:02.148 (loader): flash, block=10, bs=1024, auto=1
17:21:02.152 (loader):  gauge old value = 10
17:21:02.155 (loader): flash, block=11, bs=1024, auto=1
17:21:02.158 (loader):  gauge old value = 11
17:21:02.165 (loader): flash, block=12, bs=1024, auto=1
17:21:02.168 (loader):  gauge old value = 12
17:21:02.172 (loader): flash, block=13, bs=1024, auto=1
17:21:02.176 (loader):  gauge old value = 13
17:21:02.180 (loader): flash, block=14, bs=1024, auto=1
17:21:02.183 (loader):  gauge old value = 14
17:21:02.198 (loader): flash, block=15, bs=1024, auto=1
17:21:02.202 (loader):  gauge old value = 15
17:21:02.234 (loader): remote cmd from 1564: "status"
17:21:02.243 (loader): sending reboot
17:21:02.244 (reboot 13): Status: 1, 1, 1, 4, 0, 2, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:02.254 (loader): begin wait_until_offline
17:21:02.259 (loader): offline, waited 0
17:21:02.261 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:21:02.262 (ports 5): remove: loc=usb:0/140000/0/7/2
17:21:02.262 (ports 5): usb_remove: usb:0/140000/0/7/2
17:21:02.262 (ports 5): nothing new, skipping HID & Ports enum
17:21:02.265 (loader): end operation, total time = 0.439 seconds
17:21:02.269 (loader): set background IMG_REBOOT_OK
17:21:02.279 (loader): redraw timer set, image 14 to show for 1200 ms
17:21:02.315 (loader): remote cmd from 1564: "status"
17:21:02.351 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:21:02.357 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:21:02.361 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:21:02.368 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:21:02.373 (loader): HID/win32:  vid:046D pid:B01A ver:0003
17:21:02.383 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:21:02.404 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:21:02.410 (reboot 13): Status: 1, 1, 0, 4, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:02.410 (reboot 13): status read, retry 3
17:21:02.410 (reboot 13): Success
17:21:02.410 (reboot 13): Disconnect
17:21:02.463 (loader): remote connection 1564 closed
17:21:02.477 (loader): remote connection 1604 closed
17:21:02.550 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:21:02.551 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:21:02.551 (ports 5): found_usb_device, loc=usb:0/140000/0/7/2    Port_#0002.Hub_#0003
17:21:02.551 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
17:21:02.551 (ports 5): found_usb_device, devinst=0000001b
17:21:02.551 (ports 5): add: loc=usb:0/140000/0/7/2, class=Ports, vid=16C0, pid=0483, ver=0279, serial=5878880, dev=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:21:02.551 (ports 5):   comport_from_devinst_list attempt
17:21:02.551 (ports 5):   found Ports in classguid_list at index=0
17:21:02.551 (ports 5):   port COM32 found from devnode
17:21:02.551 (ports 5): found_usb_device complete
17:21:02.552 (ports 5): usb_add: usb:0/140000/0/7/2  COM32 (Teensy 4-Beta2) Serial
17:21:02.833 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:21:02.833 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:21:02.834 (ports 5): nothing new, skipping HID & Ports enum
17:21:03.485 (loader): redraw, image 9
17:21:50.846 (post_compile 14): Begin, version=1.47-beta4, high-res time
17:21:50.848 (loader): remote connection 1640 opened
17:21:50.852 (loader): remote cmd from 1640: "comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)"
17:21:50.852 (post_compile 14): Sending command: comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)
17:21:50.860 (loader): remote cmd from 1640: "status"
17:21:50.869 (loader): remote cmd from 1640: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\"
17:21:50.869 (post_compile 14): Status: 1, 1, 0, 4, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_79524\, Blink.ino.hex
17:21:50.869 (post_compile 14): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\
17:21:50.874 (loader): remote cmd from 1640: "file:uncannyEyes.ino.hex"
17:21:50.874 (post_compile 14): Sending command: file:uncannyEyes.ino.hex
17:21:50.906 (loader): File "uncannyEyes.ino.hex". 197012 bytes, 10% used
17:21:50.916 (loader): remote cmd from 1640: "status"
17:21:50.923 (post_compile 14): Status: 1, 1, 0, 4, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:21:50.923 (post_compile 14): Disconnect
17:21:50.945 (loader): remote connection 1640 closed
17:21:51.230 (post_compile 15): Begin, version=1.47-beta4, high-res time
17:21:51.232 (loader): remote connection 1640 opened
17:21:51.238 (loader): remote cmd from 1640: "comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)"
17:21:51.238 (post_compile 15): Sending command: comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_post_compile)
17:21:51.242 (loader): remote cmd from 1640: "status"
17:21:51.248 (loader): remote cmd from 1640: "dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\"
17:21:51.248 (post_compile 15): Status: 1, 1, 0, 4, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:21:51.248 (post_compile 15): Sending command: dir:C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\
17:21:51.255 (loader): remote cmd from 1640: "file:uncannyEyes.ino.hex"
17:21:51.255 (post_compile 15): Sending command: file:uncannyEyes.ino.hex
17:21:51.284 (loader): File "uncannyEyes.ino.hex". 197012 bytes, 10% used
17:21:51.297 (loader): remote cmd from 1640: "status"
17:21:51.303 (post_compile 15): Status: 1, 1, 0, 4, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:21:51.303 (post_compile 15): Disconnect
17:21:51.315 (post_compile 16): Running teensy_reboot: "D:\arduino-1.8.9\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY40" "-port=usb:0/140000/0/7/2" "-portlabel=hid#vid_16c0&pid_0478 Bootloader" "-portprotocol=Teensy"
17:21:51.322 (loader): remote connection 1640 closed
17:21:51.331 (loader): remote connection 1640 opened
17:21:51.350 (reboot 17): Begin, version=1.47-beta4, high-res time
17:21:51.350 (reboot 17): location = usb:0/140000/0/7/2
17:21:51.350 (reboot 17): portlabel = hid#vid_16c0&pid_0478 Bootloader
17:21:51.350 (reboot 17): portprotocol = Teensy
17:21:51.350 (reboot 17): Only location usb:0/140000/0/7/2 will be tried
17:21:51.350 (reboot 17): LoadLibrary cfgmgr32 ok
17:21:51.350 (reboot 17): LoadLibrary ntdll ok
17:21:51.351 (reboot 17): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:21:51.351 (reboot 17): found_usb_device, loc=usb:0/140000/0/7/2    Port_#0002.Hub_#0003
17:21:51.351 (reboot 17): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
17:21:51.351 (reboot 17): found_usb_device, devinst=00000003
17:21:51.351 (reboot 17): add: loc=usb:0/140000/0/7/2, class=Ports, vid=16C0, pid=0483, ver=0279, serial=5878880, dev=\\?\usb#vid_16c0&pid_0483#5878880#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:21:51.351 (reboot 17):   comport_from_devinst_list attempt
17:21:51.351 (reboot 17):   found Ports in classguid_list at index=0
17:21:51.351 (reboot 17):   port COM32 found from devnode
17:21:51.351 (reboot 17): found_usb_device complete
17:21:51.355 (loader): remote connection 1620 opened
17:21:51.367 (loader): remote cmd from 1620: "show:arduino_attempt_reboot"
17:21:51.368 (reboot 17): found Teensy Loader, version 1.47
17:21:51.368 (reboot 17): Sending command: show:arduino_attempt_reboot
17:21:51.372 (loader): got request to show arduino rebooting message
17:21:51.379 (reboot 17): Sending command: comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_reboot)
17:21:51.379 (loader): remote cmd from 1620: "comment: Teensyduino 1.47-beta4 - WINDOWS (teensy_reboot)"
17:21:51.383 (loader): remote cmd from 1620: "status"
17:21:51.389 (reboot 17): Status: 1, 1, 0, 4, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:21:51.389 (reboot 17): do_reset (serial) COM32
17:21:51.402 (loader): remote cmd from 1620: "status"
17:21:51.418 (reboot 17): Status: 1, 1, 0, 4, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:21:51.418 (reboot 17): status read, retry 0
17:21:51.489 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:21:51.490 (ports 5): remove: loc=usb:0/140000/0/7/2
17:21:51.490 (ports 5): usb_remove: usb:0/140000/0/7/2
17:21:51.490 (ports 5): nothing new, skipping HID & Ports enum
17:21:51.519 (loader): remote cmd from 1620: "status"
17:21:51.526 (reboot 17): Status: 1, 1, 0, 4, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:21:51.526 (reboot 17): status read, retry 1
17:21:51.627 (loader): remote cmd from 1620: "status"
17:21:51.647 (reboot 17): Status: 1, 1, 0, 4, 0, 0, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:21:51.647 (reboot 17): status read, retry 2
17:21:51.682 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:21:51.683 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#0008f870#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:21:51.683 (ports 5): found_usb_device, loc=usb:0/140000/0/7/2    Port_#0002.Hub_#0003
17:21:51.683 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0004
17:21:51.683 (ports 5): found_usb_device, devinst=0000001c
17:21:51.683 (ports 5): add: loc=usb:0/140000/0/7/2, class=HID, vid=16C0, pid=0478, ver=0004, serial=0008f870, dev=\\?\usb#vid_16c0&pid_0478#0008f870#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
17:21:51.683 (ports 5): hiddev_from_devinst_list: iface=0
17:21:51.685 (ports 5): found_usb_device complete
17:21:51.686 (ports 5): hid, found devinst=0000001D
17:21:51.686 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#7&283234e0&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
17:21:51.686 (ports 5): hid,  opened handle
17:21:51.686 (ports 5):  devinst=0000001D, location=usb:0/140000/0/7/2
17:21:51.686 (ports 5):  vid=16C0, pid=0478, ver=0004, usepage=FF9C, use=0024
17:21:51.686 (ports 5):  devpath=\\?\hid#vid_16c0&pid_0478#7&283234e0&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
17:21:51.686 (ports 5): usb_add: usb:0/140000/0/7/2  hid#vid_16c0&pid_0478 (Teensy 4-Beta2) Bootloader
17:21:51.781 (loader): remote cmd from 1620: "status"
17:21:51.790 (loader): Device came online, code_size = 2031616
17:21:51.795 (loader): Board is: Teensy 4-Beta2 (IMXRT1062), version 0.04
17:21:51.824 (loader): File "uncannyEyes.ino.hex". 197012 bytes, 10% used
17:21:51.830 (loader): set background IMG_ONLINE
17:21:51.862 (loader): File "uncannyEyes.ino.hex". 197012 bytes, 10% used
17:21:51.868 (loader): elf appears to be for Teensy 4-Beta2 (IMXRT1062) (2031616 bytes)
17:21:51.872 (loader): elf binary data matches hex file
17:21:51.877 (loader): elf file is for Teensy 4-Beta2 (IMXRT1062)
17:21:51.890 (loader): begin operation
17:21:51.908 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:21:51.908 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:21:51.909 (ports 5): nothing new, skipping HID & Ports enum
17:21:51.909 (reboot 17): Status: 1, 1, 1, 5, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:21:51.938 (loader): flash, block=0, bs=1024, auto=1
17:21:51.943 (loader):  gauge old value = 0
17:21:51.951 (loader): flash, block=1, bs=1024, auto=1
17:21:52.074 (loader):  gauge old value = 1
17:21:52.087 (loader): remote cmd from 1620: "status"
17:21:52.091 (loader): flash, block=2, bs=1024, auto=1
17:21:52.091 (reboot 17): Status: 1, 1, 1, 5, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:21:52.096 (loader):  gauge old value = 2
17:21:52.099 (loader): flash, block=3, bs=1024, auto=1
17:21:52.103 (loader):  gauge old value = 3
17:21:52.107 (loader): flash, block=4, bs=1024, auto=1
17:21:52.113 (loader):  gauge old value = 4
17:21:52.120 (loader): flash, block=5, bs=1024, auto=1
17:21:52.124 (loader):  gauge old value = 5
17:21:52.128 (loader): flash, block=6, bs=1024, auto=1
17:21:52.133 (loader):  gauge old value = 6
17:21:52.143 (loader): flash, block=7, bs=1024, auto=1
17:21:52.147 (loader):  gauge old value = 7
17:21:52.155 (loader): flash, block=8, bs=1024, auto=1
17:21:52.159 (loader):  gauge old value = 8
17:21:52.168 (loader): flash, block=9, bs=1024, auto=1
17:21:52.173 (loader):  gauge old value = 9
17:21:52.177 (loader): remote cmd from 1620: "status"
17:21:52.182 (loader): flash, block=10, bs=1024, auto=1
17:21:52.182 (reboot 17): Status: 1, 1, 1, 5, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:21:52.186 (loader):  gauge old value = 10
17:21:52.189 (loader): flash, block=11, bs=1024, auto=1
17:21:52.195 (loader):  gauge old value = 11
17:21:52.199 (loader): flash, block=12, bs=1024, auto=1
17:21:52.205 (loader):  gauge old value = 12
17:21:52.211 (loader): flash, block=13, bs=1024, auto=1
17:21:52.218 (loader):  gauge old value = 13
17:21:52.224 (loader): flash, block=14, bs=1024, auto=1
17:21:52.233 (loader):  gauge old value = 14
17:21:52.238 (loader): flash, block=15, bs=1024, auto=1
17:21:52.242 (loader):  gauge old value = 15
17:21:52.246 (loader): flash, block=16, bs=1024, auto=1
17:21:52.254 (loader):  gauge old value = 16
17:21:52.260 (loader): flash, block=17, bs=1024, auto=1
17:21:52.265 (loader):  gauge old value = 17
17:21:52.270 (loader): flash, block=18, bs=1024, auto=1
17:21:52.275 (loader):  gauge old value = 18
17:21:52.281 (loader): flash, block=19, bs=1024, auto=1
17:21:52.286 (loader):  gauge old value = 19
17:21:52.293 (loader): flash, block=20, bs=1024, auto=1
17:21:52.302 (loader):  gauge old value = 20
17:21:52.306 (loader): flash, block=21, bs=1024, auto=1
17:21:52.313 (loader):  gauge old value = 21
17:21:52.323 (loader): flash, block=22, bs=1024, auto=1
17:21:52.328 (loader):  gauge old value = 22
17:21:52.333 (loader): flash, block=23, bs=1024, auto=1
17:21:52.337 (loader):  gauge old value = 23
17:21:52.341 (loader): flash, block=24, bs=1024, auto=1
17:21:52.346 (loader):  gauge old value = 24
17:21:52.350 (loader): flash, block=25, bs=1024, auto=1
17:21:52.355 (loader):  gauge old value = 25
17:21:52.359 (loader): flash, block=26, bs=1024, auto=1
17:21:52.363 (loader):  gauge old value = 26
17:21:52.369 (loader): flash, block=27, bs=1024, auto=1
17:21:52.376 (loader):  gauge old value = 27
17:21:52.380 (loader): flash, block=28, bs=1024, auto=1
17:21:52.385 (loader):  gauge old value = 28
17:21:52.390 (loader): flash, block=29, bs=1024, auto=1
17:21:52.395 (loader):  gauge old value = 29
17:21:52.400 (loader): flash, block=30, bs=1024, auto=1
17:21:52.405 (loader):  gauge old value = 30
17:21:52.409 (loader): flash, block=31, bs=1024, auto=1
17:21:52.415 (loader):  gauge old value = 31
17:21:52.422 (loader): remote cmd from 1620: "status"
17:21:52.427 (loader): flash, block=32, bs=1024, auto=1
17:21:52.428 (reboot 17): Status: 1, 1, 1, 5, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:21:52.431 (loader):  gauge old value = 32
17:21:52.439 (loader): flash, block=33, bs=1024, auto=1
17:21:52.444 (loader):  gauge old value = 33
17:21:52.454 (loader): flash, block=34, bs=1024, auto=1
17:21:52.461 (loader):  gauge old value = 34
17:21:52.466 (loader): flash, block=35, bs=1024, auto=1
17:21:52.470 (loader):  gauge old value = 35
17:21:52.474 (loader): flash, block=36, bs=1024, auto=1
17:21:52.478 (loader):  gauge old value = 36
17:21:52.483 (loader): flash, block=37, bs=1024, auto=1
17:21:52.487 (loader):  gauge old value = 37
17:21:52.491 (loader): flash, block=38, bs=1024, auto=1
17:21:52.495 (loader):  gauge old value = 38
17:21:52.499 (loader): flash, block=39, bs=1024, auto=1
17:21:52.503 (loader):  gauge old value = 39
17:21:52.507 (loader): flash, block=40, bs=1024, auto=1
17:21:52.511 (loader):  gauge old value = 40
17:21:52.515 (loader): flash, block=41, bs=1024, auto=1
17:21:52.519 (loader):  gauge old value = 41
17:21:52.523 (loader): flash, block=42, bs=1024, auto=1
17:21:52.527 (loader):  gauge old value = 42
17:21:52.532 (loader): flash, block=43, bs=1024, auto=1
17:21:52.536 (loader):  gauge old value = 43
17:21:52.539 (loader): flash, block=44, bs=1024, auto=1
17:21:52.543 (loader):  gauge old value = 44
17:21:52.546 (loader): flash, block=45, bs=1024, auto=1
17:21:52.550 (loader):  gauge old value = 45
17:21:52.554 (loader): flash, block=46, bs=1024, auto=1
17:21:52.558 (loader):  gauge old value = 46
17:21:52.561 (loader): flash, block=47, bs=1024, auto=1
17:21:52.564 (loader):  gauge old value = 47
17:21:52.568 (loader): flash, block=48, bs=1024, auto=1
17:21:52.571 (loader):  gauge old value = 48
17:21:52.574 (loader): flash, block=49, bs=1024, auto=1
17:21:52.579 (loader):  gauge old value = 49
17:21:52.582 (loader): flash, block=50, bs=1024, auto=1
17:21:52.586 (loader):  gauge old value = 50
17:21:52.590 (loader): flash, block=51, bs=1024, auto=1
17:21:52.593 (loader):  gauge old value = 51
17:21:52.600 (loader): flash, block=52, bs=1024, auto=1
17:21:52.604 (loader):  gauge old value = 52
17:21:52.607 (loader): flash, block=53, bs=1024, auto=1
17:21:52.611 (loader):  gauge old value = 53
17:21:52.615 (loader): flash, block=54, bs=1024, auto=1
17:21:52.619 (loader):  gauge old value = 54
17:21:52.623 (loader): flash, block=55, bs=1024, auto=1
17:21:52.628 (loader):  gauge old value = 55
17:21:52.632 (loader): flash, block=56, bs=1024, auto=1
17:21:52.635 (loader):  gauge old value = 56
17:21:52.640 (loader): flash, block=57, bs=1024, auto=1
17:21:52.644 (loader):  gauge old value = 57
17:21:52.650 (loader): flash, block=58, bs=1024, auto=1
17:21:52.654 (loader):  gauge old value = 58
17:21:52.657 (loader): flash, block=59, bs=1024, auto=1
17:21:52.661 (loader):  gauge old value = 59
17:21:52.665 (loader): flash, block=60, bs=1024, auto=1
17:21:52.668 (loader):  gauge old value = 60
17:21:52.672 (loader): flash, block=61, bs=1024, auto=1
17:21:52.676 (loader):  gauge old value = 61
17:21:52.680 (loader): remote cmd from 1620: "status"
17:21:52.685 (loader): flash, block=62, bs=1024, auto=1
17:21:52.685 (reboot 17): Status: 1, 1, 1, 5, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:21:52.690 (loader):  gauge old value = 62
17:21:52.695 (loader): flash, block=63, bs=1024, auto=1
17:21:52.702 (loader):  gauge old value = 63
17:21:52.707 (loader): flash, block=64, bs=1024, auto=1
17:21:52.715 (loader):  gauge old value = 64
17:21:52.721 (loader): flash, block=65, bs=1024, auto=1
17:21:52.745 (loader):  gauge old value = 65
17:21:52.750 (loader): flash, block=66, bs=1024, auto=1
17:21:52.755 (loader):  gauge old value = 66
17:21:52.758 (loader): flash, block=67, bs=1024, auto=1
17:21:52.763 (loader):  gauge old value = 67
17:21:52.767 (loader): flash, block=68, bs=1024, auto=1
17:21:52.772 (loader):  gauge old value = 68
17:21:52.776 (loader): flash, block=69, bs=1024, auto=1
17:21:52.781 (loader):  gauge old value = 69
17:21:52.785 (loader): flash, block=70, bs=1024, auto=1
17:21:52.789 (loader):  gauge old value = 70
17:21:52.794 (loader): flash, block=71, bs=1024, auto=1
17:21:52.799 (loader):  gauge old value = 71
17:21:52.809 (loader): flash, block=72, bs=1024, auto=1
17:21:52.814 (loader):  gauge old value = 72
17:21:52.818 (loader): flash, block=73, bs=1024, auto=1
17:21:52.826 (loader):  gauge old value = 73
17:21:52.830 (loader): flash, block=74, bs=1024, auto=1
17:21:52.835 (loader):  gauge old value = 74
17:21:52.837 (loader): flash, block=75, bs=1024, auto=1
17:21:52.841 (loader):  gauge old value = 75
17:21:52.845 (loader): flash, block=76, bs=1024, auto=1
17:21:52.849 (loader):  gauge old value = 76
17:21:52.852 (loader): flash, block=77, bs=1024, auto=1
17:21:52.856 (loader):  gauge old value = 77
17:21:52.859 (loader): flash, block=78, bs=1024, auto=1
17:21:52.863 (loader):  gauge old value = 78
17:21:52.867 (loader): flash, block=79, bs=1024, auto=1
17:21:52.872 (loader):  gauge old value = 79
17:21:52.876 (loader): flash, block=80, bs=1024, auto=1
17:21:52.879 (loader):  gauge old value = 80
17:21:52.883 (loader): flash, block=81, bs=1024, auto=1
17:21:52.888 (loader):  gauge old value = 81
17:21:52.892 (loader): flash, block=82, bs=1024, auto=1
17:21:52.896 (loader):  gauge old value = 82
17:21:52.900 (loader): flash, block=83, bs=1024, auto=1
17:21:52.904 (loader):  gauge old value = 83
17:21:52.908 (loader): flash, block=84, bs=1024, auto=1
17:21:52.912 (loader):  gauge old value = 84
17:21:52.916 (loader): flash, block=85, bs=1024, auto=1
17:21:52.919 (loader):  gauge old value = 85
17:21:52.923 (loader): flash, block=86, bs=1024, auto=1
17:21:52.928 (loader):  gauge old value = 86
17:21:52.933 (loader): remote cmd from 1620: "status"
17:21:52.937 (loader): flash, block=87, bs=1024, auto=1
17:21:52.938 (reboot 17): Status: 1, 1, 1, 5, 0, 1, C:\Users\kurte\AppData\Local\Temp\arduino_build_853169\, uncannyEyes.ino.hex
17:21:52.942 (loader):  gauge old value = 87
17:21:52.946 (loader): flash, block=88, bs=1024, auto=1
17:21:52.950 (loader):  gauge old value = 88
17:21:52.954 (loader): flash, block=89, bs=1024, auto=1
17:21:52.960 (loader):  gauge old value = 89
17:21:52.964 (loader): flash, block=90, bs=1024, auto=1
17:21:52.968 (loader):  gauge old value = 90
17:21:52.971 (loader): flash, block=91, bs=1024, auto=1
17:21:52.976 (loader):  gauge old value = 91
17:21:52.980 (loader): flash, block=92, bs=1024, auto=1
17:21:52.984 (loader):  gauge old value = 92
17:21:52.988 (loader): flash, block=93, bs=1024, auto=1
17:21:52.989 (reboot 17): status read, retry 3
17:21:52.989 (reboot 17): Success
17:21:52.989 (reboot 17): Disconnect
17:21:52.992 (loader):  gauge old value = 93
17:21:52.996 (loader): flash, block=94, bs=1024, auto=1
17:21:53.000 (loader):  gauge old value = 94
17:21:53.004 (loader): remote connection 1620 closed
17:21:53.028 (loader): remote connection 1640 closed
17:21:53.035 (loader): flash, block=95, bs=1024, auto=1
17:21:53.039 (loader):  gauge old value = 95
17:21:53.043 (loader): flash, block=96, bs=1024, auto=1
17:21:53.047 (loader):  gauge old value = 96
17:21:53.054 (loader): flash, block=97, bs=1024, auto=1
17:21:53.058 (loader):  gauge old value = 97
17:21:53.062 (loader): flash, block=98, bs=1024, auto=1
17:21:53.066 (loader):  gauge old value = 98
17:21:53.070 (loader): flash, block=99, bs=1024, auto=1
17:21:53.074 (loader):  gauge old value = 99
17:21:53.079 (loader): flash, block=100, bs=1024, auto=1
17:21:53.084 (loader):  gauge old value = 100
17:21:53.088 (loader): flash, block=101, bs=1024, auto=1
17:21:53.092 (loader):  gauge old value = 101
17:21:53.096 (loader): flash, block=102, bs=1024, auto=1
17:21:53.100 (loader):  gauge old value = 102
17:21:53.105 (loader): flash, block=103, bs=1024, auto=1
17:21:53.109 (loader):  gauge old value = 103
17:21:53.113 (loader): flash, block=104, bs=1024, auto=1
17:21:53.117 (loader):  gauge old value = 104
17:21:53.121 (loader): flash, block=105, bs=1024, auto=1
17:21:53.125 (loader):  gauge old value = 105
17:21:53.128 (loader): flash, block=106, bs=1024, auto=1
17:21:53.132 (loader):  gauge old value = 106
17:21:53.136 (loader): flash, block=107, bs=1024, auto=1
17:21:53.140 (loader):  gauge old value = 107
17:21:53.144 (loader): flash, block=108, bs=1024, auto=1
17:21:53.150 (loader):  gauge old value = 108
17:21:53.154 (loader): flash, block=109, bs=1024, auto=1
17:21:53.158 (loader):  gauge old value = 109
17:21:53.159 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:21:53.160 (ports 5): nothing new, skipping HID & Ports enum
17:21:53.163 (loader): flash, block=110, bs=1024, auto=1
17:21:53.167 (loader):  gauge old value = 110
17:21:53.170 (loader): flash, block=111, bs=1024, auto=1
17:21:53.174 (loader):  gauge old value = 111
17:21:53.204 (loader): flash, block=112, bs=1024, auto=1
17:21:53.208 (loader):  gauge old value = 112
17:21:53.210 (loader): flash, block=113, bs=1024, auto=1
17:21:53.214 (loader):  gauge old value = 113
17:21:53.217 (loader): flash, block=114, bs=1024, auto=1
17:21:53.224 (loader):  gauge old value = 114
17:21:53.227 (loader): flash, block=115, bs=1024, auto=1
17:21:53.233 (loader):  gauge old value = 115
17:21:53.236 (loader): flash, block=116, bs=1024, auto=1
17:21:53.240 (loader):  gauge old value = 116
17:21:53.243 (loader): flash, block=117, bs=1024, auto=1
17:21:53.247 (loader):  gauge old value = 117
17:21:53.251 (loader): flash, block=118, bs=1024, auto=1
17:21:53.254 (loader):  gauge old value = 118
17:21:53.258 (loader): flash, block=119, bs=1024, auto=1
17:21:53.261 (loader):  gauge old value = 119
17:21:53.265 (loader): flash, block=120, bs=1024, auto=1
17:21:53.268 (loader):  gauge old value = 120
17:21:53.271 (loader): flash, block=121, bs=1024, auto=1
17:21:53.274 (loader):  gauge old value = 121
17:21:53.278 (loader): flash, block=122, bs=1024, auto=1
17:21:53.282 (loader):  gauge old value = 122
17:21:53.286 (loader): flash, block=123, bs=1024, auto=1
17:21:53.290 (loader):  gauge old value = 123
17:21:53.293 (loader): flash, block=124, bs=1024, auto=1
17:21:53.297 (loader):  gauge old value = 124
17:21:53.301 (loader): flash, block=125, bs=1024, auto=1
17:21:53.305 (loader):  gauge old value = 125
17:21:53.309 (loader): flash, block=126, bs=1024, auto=1
17:21:53.312 (loader):  gauge old value = 126
17:21:53.315 (loader): flash, block=127, bs=1024, auto=1
17:21:53.319 (loader):  gauge old value = 127
17:21:53.322 (loader): flash, block=128, bs=1024, auto=1
17:21:53.325 (loader):  gauge old value = 128
17:21:53.329 (loader): flash, block=129, bs=1024, auto=1
17:21:53.333 (loader):  gauge old value = 129
17:21:53.337 (loader): flash, block=130, bs=1024, auto=1
17:21:53.341 (loader):  gauge old value = 130
17:21:53.345 (loader): flash, block=131, bs=1024, auto=1
17:21:53.350 (loader):  gauge old value = 131
17:21:53.353 (loader): flash, block=132, bs=1024, auto=1
17:21:53.356 (loader):  gauge old value = 132
17:21:53.360 (loader): flash, block=133, bs=1024, auto=1
17:21:53.364 (loader):  gauge old value = 133
17:21:53.367 (loader): flash, block=134, bs=1024, auto=1
17:21:53.371 (loader):  gauge old value = 134
17:21:53.374 (loader): flash, block=135, bs=1024, auto=1
17:21:53.377 (loader):  gauge old value = 135
17:21:53.381 (loader): flash, block=136, bs=1024, auto=1
17:21:53.385 (loader):  gauge old value = 136
17:21:53.389 (loader): flash, block=137, bs=1024, auto=1
17:21:53.393 (loader):  gauge old value = 137
17:21:53.396 (loader): flash, block=138, bs=1024, auto=1
17:21:53.399 (loader):  gauge old value = 138
17:21:53.403 (loader): flash, block=139, bs=1024, auto=1
17:21:53.406 (loader):  gauge old value = 139
17:21:53.410 (loader): flash, block=140, bs=1024, auto=1
17:21:53.413 (loader):  gauge old value = 140
17:21:53.417 (loader): flash, block=141, bs=1024, auto=1
17:21:53.421 (loader):  gauge old value = 141
17:21:53.424 (loader): flash, block=142, bs=1024, auto=1
17:21:53.427 (loader):  gauge old value = 142
17:21:53.430 (loader): flash, block=143, bs=1024, auto=1
17:21:53.434 (loader):  gauge old value = 143
17:21:53.437 (loader): flash, block=144, bs=1024, auto=1
17:21:53.441 (loader):  gauge old value = 144
17:21:53.444 (loader): flash, block=145, bs=1024, auto=1
17:21:53.449 (loader):  gauge old value = 145
17:21:53.452 (loader): flash, block=146, bs=1024, auto=1
17:21:53.455 (loader):  gauge old value = 146
17:21:53.458 (loader): flash, block=147, bs=1024, auto=1
17:21:53.462 (loader):  gauge old value = 147
17:21:53.466 (loader): flash, block=148, bs=1024, auto=1
17:21:53.469 (loader):  gauge old value = 148
17:21:53.473 (loader): flash, block=149, bs=1024, auto=1
17:21:53.476 (loader):  gauge old value = 149
17:21:53.479 (loader): flash, block=150, bs=1024, auto=1
17:21:53.483 (loader):  gauge old value = 150
17:21:53.486 (loader): flash, block=151, bs=1024, auto=1
17:21:53.489 (loader):  gauge old value = 151
17:21:53.493 (loader): flash, block=152, bs=1024, auto=1
17:21:53.496 (loader):  gauge old value = 152
17:21:53.499 (loader): flash, block=153, bs=1024, auto=1
17:21:53.503 (loader):  gauge old value = 153
17:21:53.506 (loader): flash, block=154, bs=1024, auto=1
17:21:53.510 (loader):  gauge old value = 154
17:21:53.513 (loader): flash, block=155, bs=1024, auto=1
17:21:53.517 (loader):  gauge old value = 155
17:21:53.520 (loader): flash, block=156, bs=1024, auto=1
17:21:53.523 (loader):  gauge old value = 156
17:21:53.526 (loader): flash, block=157, bs=1024, auto=1
17:21:53.529 (loader):  gauge old value = 157
17:21:53.533 (loader): flash, block=158, bs=1024, auto=1
17:21:53.536 (loader):  gauge old value = 158
17:21:53.539 (loader): flash, block=159, bs=1024, auto=1
17:21:53.542 (loader):  gauge old value = 159
17:21:53.546 (loader): flash, block=160, bs=1024, auto=1
17:21:53.549 (loader):  gauge old value = 160
17:21:53.552 (loader): flash, block=161, bs=1024, auto=1
17:21:53.556 (loader):  gauge old value = 161
17:21:53.559 (loader): flash, block=162, bs=1024, auto=1
17:21:53.562 (loader):  gauge old value = 162
17:21:53.566 (loader): flash, block=163, bs=1024, auto=1
17:21:53.569 (loader):  gauge old value = 163
17:21:53.572 (loader): flash, block=164, bs=1024, auto=1
17:21:53.575 (loader):  gauge old value = 164
17:21:53.579 (loader): flash, block=165, bs=1024, auto=1
17:21:53.582 (loader):  gauge old value = 165
17:21:53.586 (loader): flash, block=166, bs=1024, auto=1
17:21:53.589 (loader):  gauge old value = 166
17:21:53.593 (loader): flash, block=167, bs=1024, auto=1
17:21:53.597 (loader):  gauge old value = 167
17:21:53.600 (loader): flash, block=168, bs=1024, auto=1
17:21:53.603 (loader):  gauge old value = 168
17:21:53.607 (loader): flash, block=169, bs=1024, auto=1
17:21:53.610 (loader):  gauge old value = 169
17:21:53.613 (loader): flash, block=170, bs=1024, auto=1
17:21:53.616 (loader):  gauge old value = 170
17:21:53.620 (loader): flash, block=171, bs=1024, auto=1
17:21:53.623 (loader):  gauge old value = 171
17:21:53.626 (loader): flash, block=172, bs=1024, auto=1
17:21:53.630 (loader):  gauge old value = 172
17:21:53.633 (loader): flash, block=173, bs=1024, auto=1
17:21:53.636 (loader):  gauge old value = 173
17:21:53.639 (loader): flash, block=174, bs=1024, auto=1
17:21:53.642 (loader):  gauge old value = 174
17:21:53.646 (loader): flash, block=175, bs=1024, auto=1
17:21:53.649 (loader):  gauge old value = 175
17:21:53.652 (loader): flash, block=176, bs=1024, auto=1
17:21:53.656 (loader):  gauge old value = 176
17:21:53.659 (loader): flash, block=177, bs=1024, auto=1
17:21:53.663 (loader):  gauge old value = 177
17:21:53.666 (loader): flash, block=178, bs=1024, auto=1
17:21:53.669 (loader):  gauge old value = 178
17:21:53.673 (loader): flash, block=179, bs=1024, auto=1
17:21:53.676 (loader):  gauge old value = 179
17:21:53.679 (loader): flash, block=180, bs=1024, auto=1
17:21:53.682 (loader):  gauge old value = 180
17:21:53.686 (loader): flash, block=181, bs=1024, auto=1
17:21:53.689 (loader):  gauge old value = 181
17:21:53.692 (loader): flash, block=182, bs=1024, auto=1
17:21:53.696 (loader):  gauge old value = 182
17:21:53.699 (loader): flash, block=183, bs=1024, auto=1
17:21:53.703 (loader):  gauge old value = 183
17:21:53.706 (loader): flash, block=184, bs=1024, auto=1
17:21:53.711 (loader):  gauge old value = 184
17:21:53.714 (loader): flash, block=185, bs=1024, auto=1
17:21:53.717 (loader):  gauge old value = 185
17:21:53.721 (loader): flash, block=186, bs=1024, auto=1
17:21:53.724 (loader):  gauge old value = 186
17:21:53.727 (loader): flash, block=187, bs=1024, auto=1
17:21:53.731 (loader):  gauge old value = 187
17:21:53.734 (loader): flash, block=188, bs=1024, auto=1
17:21:53.737 (loader):  gauge old value = 188
17:21:53.740 (loader): flash, block=189, bs=1024, auto=1
17:21:53.744 (loader):  gauge old value = 189
17:21:53.747 (loader): flash, block=190, bs=1024, auto=1
17:21:53.750 (loader):  gauge old value = 190
17:21:53.754 (loader): flash, block=191, bs=1024, auto=1
17:21:53.758 (loader):  gauge old value = 191
17:21:53.761 (loader): flash, block=192, bs=1024, auto=1
17:21:53.764 (loader):  gauge old value = 192
17:21:53.773 (loader): sending reboot
17:21:53.778 (loader): begin wait_until_offline
17:21:53.783 (loader): offline, waited 0
17:21:53.785 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:21:53.786 (ports 5): remove: loc=usb:0/140000/0/7/2
17:21:53.786 (ports 5): usb_remove: usb:0/140000/0/7/2
17:21:53.786 (ports 5): nothing new, skipping HID & Ports enum
17:21:53.790 (loader): end operation, total time = 1.893 seconds
17:21:53.797 (loader): set background IMG_REBOOT_OK
17:21:53.807 (loader): redraw timer set, image 14 to show for 1200 ms
17:21:53.922 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:21:53.937 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:21:53.941 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:21:53.944 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:21:53.948 (loader): HID/win32:  vid:046D pid:B01A ver:0003
17:21:53.952 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:21:53.956 (loader): HID/win32:  vid:0A5C pid:8502 ver:0000
17:21:54.998 (loader): redraw, image 9
17:21:55.169 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:21:55.170 (ports 5): nothing new, skipping HID & Ports enum
17:21:55.473 (ports 5): purge, name=hid#vid_16c0&pid_0478 (Teensy 4-Beta2) Bootloader, loc=usb:0/140000/0/7/2, age=1.687 sec
17:22:15.918 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
17:22:15.919 (ports 5): nothing new, skipping HID & Ports enum
17:22:15.920 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
17:22:15.920 (ports 5): nothing new, skipping HID & Ports enum
17:22:16.447 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:22:16.448 (ports 5): nothing new, skipping HID & Ports enum
17:22:18.201 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
17:22:18.203 (ports 5): nothing new, skipping HID & Ports enum
I can reprogram it again with just one display connected and use my test program for the library and it works fine (have to hit program button to get working again after the crash)... To make sure it was not the two displays stopping the program from working, I then tried reprogramming using the uncanny...
It crashed again... So to make sure that nothing major changed from @mjs513 version, I archived the sketch and included it...
  • uncannyEyes-190707a.zip
@defragster, thank you.
The time appears to be set reasonably by the TeensyLoader. I modified the example to report the time during setup. The example does not recognize that the Teensy is synchronized until it gets time from the source it expects, even though it already has the time from the loader.
If I understand correctly, the TeensyLoader wouldn't run if the Teensy were unplugged and replugged, so the Teensy would reflect the time as of last upload, not last start, so the Time library is still useful.
AFAIK : TeensyLoader passes and sets the current time - but only during programming upload - not sure in what case it won't 'adjust' to the time of upload. After that the T4 RTC is on its own - when T4 loses power without VBat (or other than keeps RTC core alive).
There was a posted sample that brings the 'current time' forward into the sketch - I didn't save the Post# - but here is a working sample of it in use.
>> Compile time is saved/shown in setup().
>> TeensyLoader sets PC time on upload - Auto or Button Press.
>> T4 Time goes to Zero when RTC loses power and restarts there without another Upload or time source to feed from.
  while (!Serial && millis() < 4000 );
  Serial.println("\nCompile Time:: " __FILE__ " " __DATE__ " " __TIME__);
#include <time.h>
  time_t tt,jj=0;
  tt = rtc_get();
  while ( tt == rtc_get() ) jj = micros();
  Serial.printf("@micros>>%u [ms>>%u] Time is %s", jj, millis(), ctime(&tt));
@KurtE
Just loaded your sketch as is with one minor change:
    eye[e].display->initR(INITR_144GREENTAB);
I ditched the offset for my displays.
Well using your connections on the T4B2 with the white wire on bottom and the latest breakout board it worked without a problem. I could not duplicate the issues you are seeing. Again using you latest changes to SPI and ST7735 libraries.
@mjs513 - @Paul - As mentioned in other thread.
I was playing with the uncanny eyes as modified by @mjs513 to work with our ST7735_t3 library, the program is up at: https://forum.pjrc.com/threads/5573...3-x-and-beyond?p=209650&viewfull=1#post209650
I made a few changes to his app on configuration as to work with your breakout boards, so configured the 2nd display to use pin 23(MCLK) and reset pin 20 (LRCLK)... Was working. Then made a code change to try it out and then when it uploads,
The Windows machine shows
Then stopped being able to upload and startup that program...
Was able to upload blink, after hitting program button. Then uploaded that app again... This time I had debug setup to Serial4:
This time had what looks like some debug stuff at the end...
Verbose info not sure if it will show much:
@KurtE - to confirm: This is a T4B2 MOD - either with White Wire or a PCB V#21 final T4 with wire internal?
> It happens when NO UART Serial wires are connected
> It does happen with a Single display?
> Does the Display(s) have any pullups on SPI pins?
Question: Does it Repro with NO display(s) physically plugged in? { I can try this }
@mjs513, @defragster @Paul
Note: I hacked it up with the debug stuff @defragster mentioned in posting on other thread. And first time crashed, but then ran again with that installed and it appeared to run fine...
C:\Users\kurte\Documents\Arduino\uncannyEyes\uncannyEyes.ino Jul  7 2019 18:01:58
 T4 connected Serial_tt ******* debug_tt port
>>> Reason for 'reset': 1 IPP_RESET_B :: done Reason
F_CPU==600000000   F_BUS==150000000 FreeMem(); 4293328812
Init
Create display #0
Create display #1
Reset displays
Init ST77xx display #0
Rotate
Init ST77xx display #1
Rotate
done
Display logo
8
8
Almost like it hit some very specific memory alignment...
Update: to questions above.
a) As I mentioned on previous post - It started happening again on newer board (with white wire and flex connector)... But then I added your debug library and it no longer happened. Before after it stopped working I added the FTDI cable to Serial4 to see if it saw anything... This one never caused the brownout issue (same one Paul was originally using)... When I was in that crash state, it would reproduce even with the T4 not plugged into breakout board (so nothing connected).
b) Right now it is running ok with 2 displays (both the ones different than Adafruit).
c) When it did start crashing, I had swapped to use one ST7735 thats memory is same as adafruit. So I had changed the display table to add an option field, so could use two different INITR values...
Will try that again... Runs fine right now with one of each, although one eye is not correct do to offsets.
Will try that again
@KurtE
Strange. I added in @defragster's debug and got this for output but its still running fine:
C:\Users\Merli\OneDrive\Desktop\uncannyEyes\uncannyEyes.ino Jul  7 2019 21:24:12
F_CPU==600000000   F_BUS==150000000 FreeMem(); 4293328804
Init
Create display #0
Create display #1
Reset displays
Rotate
Rotate
done
Display logo
8
8
I am using two of the adafruit ST7735R displays (https://www.amazon.com/gp/product/B00SK6932C/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1). Don't have any other ones to test with. Which do you recommend for me to get to give it try, if you don't solve it first.
@mjs513...
As I mentioned, I added the library and it is working fine and also tried programming int on the T4B2 Pre fixed/ribbon and it now runs as well. So somehow the condition maybe had to be just correct to mess it up...
All of this to see about the possible ways of speeding things up... i.e. verified pushColor() did not work ;)
@KurtE - Pulled the EYE sketch ZIP - and got these three lib ZIPs from KurtE github:
Using library SPI at version 1.0 in folder: T:\tCode\libraries\SPI
Using library Adafruit_GFX at version 1.5.5 in folder: T:\tCode\libraries\Adafruit_GFX
Using library ST7735_t3 at version 1.0.0 in folder: T:\tCode\libraries\ST7735_t3
T2B4 Mod on a breakout or just USB with no displays or UARTS - builds and uploads okay.
Init
Create display #0
Create display #1
Reset displays
Rotate
Rotate
done
Display logo
8
Then on Breakout with 7 Active UART Serial#'s from second T4 breakout and it uploads and runs the same - no issue.
Seems like a build memory init setup issue - will have to test again with the next TD1.47 beta when our sources are updated and in sync.
