manitou
Senior Member+
@manitou - I agree - just got my coffee and was getting ready to make the edits to use the quad timer for FreqCount. Will let you know when I get it done - still waking up here![]()
I just ran 75mhz test with two T4B2 (and common ground) and i too get a reduced count 68291533. So with single T4B2 the PWM/timer clocks must somehow be "sync'd" to enable proper counting of 75mhz signal. Not quite correct for 50mhz PWM, with two T4's get 48516240 ticks. Counts are OK with 37.5mhz from 2nd T4. Someone with a signal generator needs to measure the "effective range" of our quad timer external signal counter.
