defragster
Senior Member+
Given manitou's RTC to test running Millis and wanting confirmation ... Went back to the SetArmClock sketch and after a short run set it back to 600 MHz before exiting. Added in two serialEvent's and printed RTC to print with millis to see the clock stay in sync.
It seems more likely that dropout was from power cycling running power through the DMM to measure Current. Though as noted that affected the T4 it seemed until the 15 sec reset.
I see the T_3.? [3.1 or 3.6] dropped from T_ports list - did that once and restarted IDE and TLoader and it returned, now after testing - and swapping in my new Hub T_3.6 is missing now.
I put pins on a 3V battery holder in breadboard and it keeps time. Edited the code to not reset if it was bigger than the code value - not the linker value but the hardcoded one seeing that a new scheme is coming.
