Dear Forum Folks,
I am using a Teensy 4.0 in a prototype that needs to be reliable, but I'm having a few issues that are troubling me and I would like advice on making things work with as few hardware risks as possible. I'll try to enumerate the issues and questions for clarity.
Is there a "high reliability" version of the Teensy 4.0? Maybe I should be buying a different part number.
I've actually used the v3 teensies in hundreds of prototypes that have never had an issue so I'm really confused by this. Every other component on the board is in provably good condition after swapping the teensy for a new one, my analog circuit is on a separate power rail though I suppose.
Here are the Teensy connections.
Power Inlet:
And the Teensy Supply:
- It has run in a project for about a year on five different identical prototypes, including keeping several values in EEPROM safe over an extended period.
- One of the teensies permanently failed without any clear cause.
- The power is provided by a 5V switching regulator of my own design using a TPS629330. It has run continuously for years in several projects (schematic below).
- Not including the 2.2uH/22uF filter on the switching regulator, the Teensy has another 10uF right next to the socket where I plug it in.
- Every pin connection has a 50 ohm resistor on it both for protection and for reflections. (schematic below, some resistors located at source at peripheral).
- I cut the power trace to the USB port and provide power exclusively through the PCB it is plugged into.
- I am still using the USB port for data.
- I am using the pins under the chip with SMD pads because I am using the SPI1 interface.
- Is there any SMD part number that ends up with the pins all at the same height? It's frustrating having the SMD connector a little taller than the TH connector so the board is always tilted.
- Board level power entry comes from a 12V wall wart (schematic below).
- Has a reverse protection diode, fuse, 15V TVS diode, a T-filter, and a 10uF capacitor after all that. And then the custom power regulator (schematic below).
- After the teensy failure the power supply to the board has identical characteristics to others of the same model and all power supplies measure nominal voltages.
- I had a second working Teensy that I installed and after coming back after a bit it was blinking orange or red. I could not get the USB Serial port to work again even with power cycling. I reprogrammed the firmware (which I can't do in practice) and it even lost the EEPROM values! What could cause that? I didn't even know that was possible without I was able to reprogram it and recalibrate to save new EEPROM values, and it seems to still be there after power cycling but I don't even know how to intentionally delete the EEPROM without writing a custom sketch for it.
- I notice that the push button on the Teensy (which I know is not reset) seems to put it into a mode where USB Serial is not functional. Do other folks remove this button to avoid issues? I can power cycle (after the apparent total flash/eeprom erasure) and I can talk over USB Serial again.
Power Inlet:
