Teensy 4.0 Schematic Clarification
bthayer2
I was looking at the Teensy 4.0 schematic and researching the datasheet for the part TLV75733P. The datasheet says the IN pin requires a 1 µF or greater capacitor. However, the Teensy 4.0 schematic shows 2 capacitors both at 0.22µF as shown below. I am wondering if this is a mistake in the schematic. Should C16 be 1µF?
Snippet from datasheet:
7.1.1 section:
The TLV757P requires an output capacitance of 0.47μF or larger for stability. Use X5R- and X7R-type ceramiccapacitors because these capacitors have minimal variation in capacitance value and equivalent seriesresistance (ESR) over temperature. When selecting a capacitor for a specific application, consider the DC biascharacteristics for the capacitor. Higher output voltages cause a significant derating of the capacitor. As ageneral rule, make sure ceramic capacitors are derated by 50%. For best performance, use an outputcapacitance value no greater than 200µF.
Place a 1µF or greater capacitor on the input pin of the LDO. Some input supplies have a high impedance.Placing a capacitor on the input supply reduces the input impedance. The input capacitor counteracts reactiveinput sources and improves transient response and PSRR. If the input supply has high impedance over a largerange of frequencies, use several input capacitors in parallel to lower the impedance over frequency. Use ahigher-value capacitor if large, fast, rise-time load transients are expected, or if the device is located severalinches from the input power source.
Link is here to the datasheet I am looking at.
Thanks in advance.
I believe I found another potential issue worth discussing. I believe the K9 pin is missing from the Teensy 4.0 schematic for the MIMXRT1062DVL6B configuration. I believe it is supposed to be connected to Ground.
From my research, the wiring trace shared appear to connect K9 to ground and the Teensy 4.1 has this pin connected to ground.
Teensy 4.0 schematic:
Traced the microscopic wiring traces in the image that was attached and it looks like all 3 are connected.
Teensy 4.1 schematic showing all 3 pins connect to ground:
Yes, confirm, the K9 pin (signal NGND_KEL0) is missing from Teensy 4.0 schematic. But it is indeed connected to GND on Teensy 4.0 and Teensy 4.1.
Thanks, that K9 pin connection makes sense to me. It might be worthwhile to update the Teensy 4.0 schematic image to include it when you get a moment just to prevent others from asking the same thing.
For the C16 capacitor issue, I am probably going to use the 1uF value for that capacitor just to follow the datasheet more. I know this differs from the Teensy 4.0 schematic a little bit.
