pierrotm777
Hello,
I use a Teensy 4.0 as Telemetry simulator. I have no issue with Serial1 and Serial3 but the FrSkySportTelemetry library not work with the Serial2 and Serial4.
I use this example as test:
I use the Teensy core 1.57.3 and not the last 1.59.0 because I have some issues with the library TeensyVariablePlayBack 1.0.16, TeensyVariablePlayBack 1.1 and Core 1.59.0 crash my Teensy 4.0.
Thanks for your help,
Pierre
FrSky S-Port Telemetry library example
(c) Pawelsky 20210509
Not for commercial use
Note that you need Teensy LC/3.x/4.x, ESP8266, ATmega2560 (Mega) or ATmega328P based (e.g. Pro Mini, Nano, Uno) board and FrSkySportTelemetry library for this example to work
// Uncomment the #define below to enable internal polling of data.
// Use only when there is no device in the S.Port chain (e.g. S.Port capable FrSky receiver) that normally polls the data.
//#define POLLING_ENABLED
#include "FrSkySportSensor.h"
#include "FrSkySportSensorAss.h"
#include "FrSkySportSensorEsc.h"
#include "FrSkySportSensorFcs.h"
#include "FrSkySportSensorFlvss.h"
#include "FrSkySportSensorGasSuite.h"
#include "FrSkySportSensorGps.h"
#include "FrSkySportSensorRpm.h"
#include "FrSkySportSensorSp2uart.h"
#include "FrSkySportSensorVario.h"
#include "FrSkySportSingleWireSerial.h"
#include "FrSkySportTelemetry.h"
#if !defined(TEENSY_HW)
#include "SoftwareSerial.h"
FrSkySportSensorAss ass; // Create ASS sensor with default ID
FrSkySportSensorEsc esc; // Create ESC sensor with default ID
FrSkySportSensorFcs fcs; // Create FCS-40A sensor with default ID (use ID8 for FCS-150A)
FrSkySportSensorFlvss flvss1; // Create FLVSS sensor with default ID
FrSkySportSensorFlvss flvss2(FrSkySportSensor::ID15); // Create FLVSS sensor with given ID
FrSkySportSensorGasSuite gas; // Create Gas Suite sensor with default ID
FrSkySportSensorGps gps; // Create GPS sensor with default ID
FrSkySportSensorRpm rpm; // Create RPM sensor with default ID
FrSkySportSensorSp2uart sp2uart; // Create SP2UART Type B sensor with default ID
FrSkySportSensorVario vario; // Create Variometer sensor with default ID
#ifdef POLLING_ENABLED
#include "FrSkySportPollingDynamic.h"
FrSkySportTelemetry telemetry(new FrSkySportPollingDynamic()); // Create telemetry object with dynamic (FrSky-like) polling
#else
FrSkySportTelemetry telemetry; // Create telemetry object without polling
// Configure the telemetry serial port and sensors (remember to use & to specify a pointer to sensor)
#if defined(TEENSY_HW)
//telemetry.begin(FrSkySportSingleWireSerial::SERIAL_1, &ass, &esc, &fcs, &flvss1, &flvss2, &gas, &gps, &rpm, &sp2uart, &vario);//Teensy 4.0 OK
//telemetry.begin(FrSkySportSingleWireSerial::SERIAL_2, &ass, &esc, &fcs, &flvss1, &flvss2, &gas, &gps, &rpm, &sp2uart, &vario);//Teensy 4.0 not OK
//telemetry.begin(FrSkySportSingleWireSerial::SERIAL_3, &ass, &esc, &fcs, &flvss1, &flvss2, &gas, &gps, &rpm, &sp2uart, &vario);//Teensy 4.0 OK
telemetry.begin(FrSkySportSingleWireSerial::SERIAL_4, &ass, &esc, &fcs, &flvss1, &flvss2, &gas, &gps, &rpm, &sp2uart, &vario);//Teensy 4.0 not OK
//telemetry.begin(FrSkySportSingleWireSerial::SERIAL_2, &ass, &esc, &fcs, &flvss1, &flvss2, &gas, &gps, &rpm, &sp2uart, &vario);//LC OK
#else
telemetry.begin(FrSkySportSingleWireSerial::SOFT_SERIAL_PIN_12, &ass, &esc, &fcs, &flvss1, &flvss2, &gas, &gps, &rpm, &sp2uart, &vario);//Uno OK
// Set airspeed sensor (ASS) data
ass.setData(76.5); // Airspeed in km/h
// Set ESC sensor data
esc.setData(12.6, // ESC voltage in volts
22.1, // ESC current draw in amps
10900, // ESC motor rotations per minute
20000, // ESC current consumtion in mAh
45.6, // ESC temperature in degrees Celsius (can be negative, will be rounded)
6.7, // ESC SBEC voltage in volts
0.10); // ESC SBEC current draw in amps
// Set current/voltage sensor (FCS) data
// (set Voltage source to FAS in menu to use this data for battery voltage,
// set Current source to FAS in menu to use this data for current readins)
fcs.setData(25.3, // Current consumption in amps
12.6); // Battery voltage in volts
// Set LiPo voltage sensor (FLVSS) data (we use two sensors to simulate 8S battery
// (set Voltage source to Cells in menu to use this data for battery voltage)
flvss1.setData(4.07, 4.08, 4.09, 4.10, 4.11, 4.12); // Cell voltages in volts (cells 1-6)
flvss2.setData(4.13, 4.14); // Cell voltages in volts (cells 7-8)
// Set Gas Suite sensor data
gas.setData(-10.3, // Temperature #1 in degrees Celsuis (can be negative, will be rounded)
200.6, // Temperature #2 in degrees Celsuis (can be negative, will be rounded)
80000, // Rotations per minute
55000, // Residual volume in ml
73, // Residual percentage (0-100)
1230, // Flow in ml/min
1500, // Maximum flow in ml/min
1111); // Average flow in ml/min
// Set GPS sensor data
gps.setData(48.858289, 2.294502, // Latitude and longitude in degrees decimal (positive for N/E, negative for S/W)
245.5, // Altitude in m (can be negative)
100.0, // Speed in m/s
90.23, // Course over ground in degrees (0-359, 0 = north)
14, 9, 14, // Date (year - 2000, month, day)
12, 00, 00); // Time (hour, minute, second) - will be affected by timezone setings in your radio
// Set RPM/temperature sensor data
// (set number of blades to 2 in telemetry menu to get correct rpm value)
rpm.setData(200, // Rotations per minute
25.6, // Temperature #1 in degrees Celsuis (can be negative, will be rounded)
-7.8); // Temperature #2 in degrees Celsuis (can be negative, will be rounded)
// Set SP2UART sensor data
// (values from 0.0 to 3.3 are accepted)
sp2uart.setData(1.5, // ADC3 voltage in volts
3.3); // ADC4 voltage in volts
// Set variometer data
// (set Variometer source to VSpd in menu to use the vertical speed data from this sensor for variometer).
vario.setData(250.5, // Altitude in meters (can be negative)
-1.5); // Vertical speed in m/s (positive - up, negative - down)
// Set receiver data to be sent in case the polling is enabled (so no actual receiver is used)
telemetry.setData(90, // RSSI value (0-100, 0 = no telemetry, 100 = full signal)
4.9); // RxBatt (voltage supplied to the receiver) value in volts (0.0-13.2)
// Send the telemetry data, note that the data will only be sent for sensors
// that are being polled at given moment
telemetry.send();
Pierre
