Lavanya rajan
Hi all,
I am using a W5500 Ethernet module interfaced with a Teensy 4.0 via SPI. My goal is to send data from the controller to a cloud database using HTTP requests.
Before implementing the cloud communication, I wanted to first verify basic internet connectivity from the device. For this purpose, I tried to connect to the Google website (www.google.com) on port 80 using the Ethernet library.
The Ethernet initialization appears to be successful, and the device receives a valid static IP address. However, when attempting to connect to the server using, the connection fails. Any suggestions on how to debug or resolve this problem would be greatly appreciated.
Serial Monitor Resposne:
Begin Ethernet
Local IP : 172.25.3.210
Subnet Mask : 255.255.0.0
Gateway IP : 172.18.90.57
DNS Server : 172.18.90.50
Ethernet Successfully Initialized
Connecting to server...
Connection failed
Disconnecting...
Received 0 bytes in 0.0000, rate = nan kbytes/second
Web client
#include <Ethernet.h>
char server[] = "www.google.com";
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
#define MYIPADDR 172,18,7,165
#define MYIPMASK 255,255,0,0
#define MYDNS 172,18,90,50
#define MYGW 172,18,90,50
EthernetClient client;
unsigned long beginMicros, endMicros;
unsigned long byteCount = 0;
bool printWebData = true;
Serial.println("Begin Ethernet");
SPI.begin();
Ethernet.init(29); // CS pin for W5500
// Static IP configuration
IPAddress ip(MYIPADDR);
IPAddress dns(MYDNS);
IPAddress gw(MYGW);
IPAddress sn(MYIPMASK);
Ethernet.begin(mac, ip, dns, gw, sn);
// Check hardware
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield not found!");
while (true) delay(1);
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable not connected.");
Serial.print("Local IP : ");
Serial.println(Ethernet.localIP());
Serial.print("Subnet Mask : ");
Serial.println(Ethernet.subnetMask());
Serial.print("Gateway IP : ");
Serial.println(Ethernet.gatewayIP());
Serial.print("DNS Server : ");
Serial.println(Ethernet.dnsServerIP());
Serial.println("Ethernet Successfully Initialized");
Serial.println("Connecting to server...");
if (client.connect(server, 80)) {
Serial.println("Connected!");
client.println("GET /get HTTP/1.1");
client.println("Host: www.google.com");
client.println("Connection: close");
client.println();
Serial.println("Connection failed");
beginMicros = micros();
int len = client.available();
if (len > 0) {
byte buffer[80];
if (len > 80) len = 80;
client.read(buffer, len);
if (printWebData) {
Serial.write(buffer, len);
byteCount = byteCount + len;
if (!client.connected()) {
endMicros = micros();
Serial.println("Disconnecting...");
client.stop();
Serial.print("Received ");
Serial.print(byteCount);
Serial.print(" bytes in ");
float seconds = (float)(endMicros - beginMicros) / 1000000.0;
Serial.print(seconds, 4);
float rate = (float)byteCount / seconds / 1000.0;
Serial.print(", rate = ");
Serial.print(rate);
Serial.print(" kbytes/second");
while (true) {
delay(1);
Begin Ethernet
Connection failed
Disconnecting...
